PMok
Old 05-09-2016, 11:09 PM   #1
KennethTheJet
Drives: 2014 Raven Scion FRS
Which is more reliable?
Sorry if I did not read ahead, I just been so curious for an answer. I am stuck between a supercharger and a turbo.
Supercharger= HKS V3 or Kraftwerks
Turbo= Full blown turbo base kit or Greddys
Which will be more reliable and reasonable for a daily driver?
Thanks in advance!
KennethTheJet is offline   Reply With Quote
Old 05-09-2016, 11:10 PM   #2
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Full blown or Greddy
Freeman is offline   Reply With Quote
Old 05-09-2016, 11:39 PM   #3
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
In terms of a SC, HKS.
In terms of a TC, Greddy.
Out of those two? HKS supercharger. OR Cosworth :p
MS, CSCS, TSAC-F, CPT
The Following 2 Users Say Thank You to weederr33 For This Useful Post:
R2RO (05-10-2016), zeal86 (05-10-2016)
Old 05-10-2016, 03:53 AM   #4
morswestford
morswestford's Avatar
Drives: 2013 Subaru BRZ
is the HKS V3 better than the jackson racing kit? why would someone choose the HKS V3 over JR?
morswestford is offline   Reply With Quote
The Following User Says Thank You to morswestford For This Useful Post:
JDKane527 (05-10-2016)
Old 05-10-2016, 08:13 AM   #5
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Fullblown all the way.
Aslong as you clamp all the evap lines, install a catchcan and delete pcv, install cooler, upgrade your clutch and stick with the map FBM gives you.
I've had no issues really. Oil leak was caused by the factory pcv valve on the crank case not allowing enough presure to leave the crankcase case. Oil cooler was basicly a must. Evap lines just like to pop off when hot. Factory clutch will slip with any bigger turbo setup, SC not so much but hp is way lower. Unless running a higher boost pulley upgrade.
Regardless of what you pick. The choice isn't easy and none of them is just slapped on. You will need supporting mods to keep the car happy or you won't have it for long.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 05-10-2016, 08:47 AM   #6
R2RO
R2RO's Avatar
Drives: 2013 FR-S, 2013 FR-S(2JZ Build)
You kinda throw reliability out the window when you add forced induction to this car in stock form.
But,
SC wise I'd say: HKS since the KW has belt issues from what I've read over the years
TC wise I'd say: Greddy since its proven, but FB is also a great choice!
R2RO is offline   Reply With Quote
The Following User Says Thank You to R2RO For This Useful Post:
Antihero983 (05-11-2016)
Old 05-10-2016, 09:10 AM   #7
GsxrMe
GsxrMe's Avatar
But,
KW would be king if they had an auto tension pulley. But ya KW eats belts for lunch sadly.
2014 Subaru BRZ
Old 05-10-2016, 10:40 AM   #8
Andew727
Drives: Scion FR-S
save money in your budget for an engine rebuild and buy any kit you like best... that is the reliable route. there are too many weak points on the car that begin to fatigue wear and fail once boost is introduced. the heads and rods are the first thing to replace. make sure you get an oil cooler with any kit.
Andew727 is offline   Reply With Quote
The Following User Says Thank You to Andew727 For This Useful Post:
R2RO (05-10-2016)
Old 05-10-2016, 01:17 PM   #9
djdnz
1337
Drives: 2013 BRZ WRB S/C
The two SC options you picked are the ones that seem to have the most issues. Why not consider JRSC or Edelbrock?
djdnz is offline   Reply With Quote
Old 05-10-2016, 01:31 PM   #10
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
I have heard countless stories of the JRSC kit's supplied tune being complete garbage and it's needed to get a custom tune, and then once getting a custom tune there seems to be boost leaks due to the BPV.
Instagram: trevor.parque
Old 05-10-2016, 01:37 PM   #11
uRBAN_Metal
Drives: '13 BRZ
Care to explain how a tune could cause a bypass valve to leak?
Out of all the kits they have sold, I have only heard of one instance where a bypass valve wasn't functioning properly, and even though it was a used kit, JR still took it back to replace it under warranty. The kit is perfectly reliable even with the CARB tune. The CARB tune just doesn't make as much power as a custom tune. No need to get it if you don't live in California.
uRBAN_Metal is offline   Reply With Quote
The Following 3 Users Say Thank You to uRBAN_Metal For This Useful Post:
CSG Mike (05-10-2016), Keenercarguy (06-07-2016), Summerwolf (06-09-2016)
Old 05-10-2016, 01:41 PM   #12
MisterSheep
Killed Scion
@PMok care to touch up on the subject?
Old 05-10-2016, 01:46 PM   #13
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
KW is reliable if you know how to adjust your belt properly... been running mine for 15-20k now with 0 issues.
That being said the JR kit is also very good (I've seen to many hks product failure in the last years to recommend them at this point)..
Turbo Full blown is great stuff
fumanchu1 is offline   Reply With Quote
Old 05-10-2016, 02:22 PM   #14
CSG Mike
CSG Mike's Avatar
Have you actually experienced a JRSC with the supplied tune? It's seamless.
The stories originate from people who decide that they *DONT FOLLOW GUIDELINES* and run the CARB tune with aftermarket headers...
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
brianhj (07-03-2016), Jackson Racing (06-09-2016), R2RO (05-10-2016)
What's the most reliable turbo for DD Domjeezy Forced Induction 58 01-13-2016 07:59 AM
How reliable are the twins? SquadRogue Scion FR-S / Toyota 86 GT86 General Forum 60 12-13-2014 01:58 PM
WTB reliable HID kit 4300k H11 86WRX Want-To-Buy Requests 6 01-03-2014 04:38 PM
Most reliable F/I kit? official_george Forced Induction 103 05-14-2013 01:00 PM
Reliable LED kit companies? skoodge Cosmetic Modification (Interior/Exterior/Lighting) 4 05-27-2012 11:38 PM
