#2899 | |
Drives: GT86
| The Following User Says Thank You to DeaconRoc For This Useful Post: | solidONE (05-07-2016) |
#2900 |
Thanks
GOing for alignment this week.
I have OEM crash bolt in top hole and camber plate. The bolt gave me -1.5, currently running -2.6, going to try -3 Does it make a difference if I remove the bolt and do all the camber with the plate? Is one way better/worse or doesn't make a difference? I'm taking my wheels off today anyway for brake fluid.
#2901 |
Drives: '15 Ultramarine FR-S
I recently had an alignment done on my car which has camber bolts in the front as well as camber plates on my coilovers. After the alignment, one of my camber plates is at a different position than the other one. So my question is, since now my scrub radius is most likely different side to side, how will it affect driveability and safety?
#2902 |
Drives: 2013 WRB BRZ 6MT
I broke a front swaybar end link at my last track day. I talked to a few people at the track the day I broke it and they suspected it was because it was an OEM end link used on HKS Hipermax 4 GT coils with stickier 200tw tires. The coils were bought used and the guy who sold them to me couldn't get the HKS ones off his car without destroying them so he gave me his OEM end links. Anyways, the end link is busted now so I need to get new ones but I don't know much about them so looking for suggestions on what to get. Is there anything in particular that I should know/look for? The car is daily driven with occasional track and autocross duty. I was looking at the Whiteline adjustable end links but I also see a non adjustable Perrin endlink around too. Just looking for some direction on what I should get.
#2903 | |
Are you running different offset wheels on either side? |
#2904 | |
driving smoother faster
Drives: Sold
I use Whiteline front and rear end links. Links on two diagonal corners weakened after 20+ track days so I'm replacing all four with same but new Whiteline parts. Apparently they are wear and tear item with track/ax use. |
#2905 |
#2906 |
The hub still rotates around a fixed point. The lower ball joint, so while that radius may be at a different plane with regards to the ground, it's still the same radius, and you said you have camber bolts and camber plates, and you've just had an alignment, so your camber values should be the same, if you got what you paid for. With the very small amounts of negative camber you're dealing with, it's not enough notice a difference in scrub. Even the mathematical difference in scrub is minute.
#2907 | |
#2908 | |
| The Following User Says Thank You to Tokay444 For This Useful Post: | Marat (05-09-2016) |
#2909 | |
- Andrew |
| The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post: | wparsons (06-06-2016), ZionsWrath (05-10-2016) |
#2910 |
Drives: 2013 WRB Subaru BRZ
Hello! So I am set on buying a set of Yellow springs and want to know if it is worth it to get the full starter lite kit on a street car that is only a daily driver? The camber bolts are very cheap, but is it necessary? same with the rear bushings, those are pricer, but I honestly don't plan on going all out, just want a little lowering. I am having an awesome shop do a custom alignment after the spring install, so having them make use of the other parts would not be an issue as well. Really can't decide...I did do an autoX event and plan on doing another (since it was raining), but I am not in it for the time, just go to have fun. I love the oem handling already, would those two parts really make a difference worth it to someone who isn't competitive at all?
#2911 |
Drives: 2023 BRZ
Get camber bolts at a minimum. They are the best handling improvement for the dollar you can make. Camber plates make a big difference even over camber bolts, but it doesn't sound like you want to go down that road just yet. I wouldn't worry about bushings given your goals.
| The Following 2 Users Say Thank You to Pat For This Useful Post: | kev60625 (05-09-2016), Racecomp Engineering (05-10-2016) |
#2912 |
Drives: Scion FR-S | 6MT | Ultramarine
I have the Tarmac IIs waiting to be installed. I figure I'm going to have to order some rear LCAs anyways. What do you guys recommend for something that will be STX legal and can stand up to some sporadic track use?
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
