Old 03-07-2016, 02:11 AM   #155
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
It doesn't matter if you get more power and prevent bogging down running it leaner. Anything under 11.5 in that area will feel shit generally.
Originally Posted by solidONE View Post
^ It would be a good idea for those of you messing with the load limits to log the cam timing as well to better determine whether the lean spots are caused by scavenging effect. The valvetrain noise caused by aggressive overlap may also contribute to knock, or rather "knock". (in quotations because this may not be real knock)
The Following User Says Thank You to Wayno For This Useful Post:
solidONE (03-07-2016)
Old 04-26-2016, 12:24 AM   #156
Dru670
Drives: 2016 Scion FR-S
is this v86 MAF Scale an improved version over the OTS stg 2 tune in terms of a drop in filter and silicone intake pipe?
Dru670 is offline   Reply With Quote
Old 05-04-2016, 05:23 PM   #157
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
their is a FLKC (fine learning knock correction table ie learned knock table, so yes ecu learns where knock happens and stores it. While we log FLKC and see it instantaneously its also stored for a period in a table similar to the one below.
their is a whole lot of algorithms applied by ecu to work out if it will decrement or increment iam and when it will return the flkc timing it stores. When you see positive FLKC this is the ecu returning some stored flkc
that learned table is storred in ram and gets cleared on ecu reset or flash
their is a whole lot of info on romraider site
see the flashing-RESET-Learning link below
the romraider guys have done it with learning view but its not set up for brz/86 ecu
Has this table been defined on the FRS/BRZ?
Intent > Content
Old 05-04-2016, 09:08 PM   #158
steve99
Drives: FT86
No
The flkc table is actually in the RAM area ie random access mamory that is lost on complete power off of ecu.
The ROM or flash area is a differnt mamory area in ecu and is non-volitile ie its permanent untill you re-flash it.
tunes and definitions are for the ROM or flash memory area of the ecu. A "tune" that you flash contains a mixture of program instructions and tables/data, these are intermingled throughout the rom/tune.
A definition is an index into this mess of instructions and tables and it allows romraider to extract the tables from the correct locations in the rom/tune and display/scale them into a human readable form, which you can then edit/change and then reflash to alter the "tune" of the engine.
Each time the recompile a new rom calid these tables and instructions and ram locations can change, this is why you need to carefully match definitions and roms, and why the logging ram address are often different between different calid
The FLKC table above is created in ram a different area by the program instructions in the ROM area, the ram also holds all those logging addresses you read out with tactrix or oft or ecutek. The RAM is like a scratchpad temporary working area the ecu uses for high speed calculations and temporary storage of run time data.
The ROM is like the hard disk on your computer and the RAM is like the RAM on your computer.
The program above showing the FLKC stored table access,s the ram area of the ecu to read that data, it possible the oft guys could display it but would require someone to wade through the program code to see where its written to in RAM for each separate rom calid.
also it would require 64 ram addresses to be read, which would be quite slow, although that data is not likely fast changing, you clould probably interleave it.
But i doubt anyone is going to go to the trouble
The Following 3 Users Say Thank You to steve99 For This Useful Post:
solidONE (05-05-2016), tato.valverde (05-05-2016), Tvars (10-19-2016)
Old 05-04-2016, 11:14 PM   #159
Wayno
Wayno's Avatar
Did you try shiv's scales first? They likely don't need to be updated.
Old 05-05-2016, 01:37 AM   #160
Hyperblue302
Hyperblue302's Avatar
Drives: 2016 BRZ, 94 Integra GSR
lol
Hyperblue302 is offline   Reply With Quote
Old 05-05-2016, 12:16 PM   #161
Kodename47
Kodename47's Avatar
Drives: UK GT86
The boundaries are defined in most defs:
Fine Correction Rows (RPM)
Fine Correction Columns (Load)
.: Stealth 86 :.
Kodename 47 DJ:
solidONE (05-06-2016)
Old 05-06-2016, 04:36 AM   #162
solidONE
solidONE's Avatar
Now to figure out what each of these tables do exactly. I suppose these table control what is being stored onto the table steve99 posted. I should be able to reduce the amount of knock correction is being applied or speed up the rate in which the computer increase the IAM after having subtracted due to knock events stored by changing some of these values, I assume.
Edit: I've decided to make some small conservative changes to a few of the fine correction tables and see what kind of effect it will have. Reduce the knock correction per knock event from -.65 to -.35. Increased the positive limit from 3.5 to 4.0. Reduced the "no knock" delay period from 125 to 100. I suppose I'd have to really wring the engine out to the point where IAM get reduced to see the effects on some of the changes. Also I dont have any sort of a "baseline" log to really compared it to. So this is all for shits and giggles, butt dyno type deal.
A little test log before applying the changes and reflashing my ecu:
http://datazap.me/u/solidone/z6-test...og=0&data=1-11
Little ticky-tack -.65 FLKC corrections here and there. Nothing major.
Intent > Content
Old 05-08-2016, 12:11 AM   #163
solidONE
solidONE's Avatar
http://datazap.me/u/solidone/z6-kc1?...zoom=1969-4752
Here's the 1st log after having applied the changes in the above post. The effect it had on FLKC was just as expected. In areas where I would have gotten -.69 FLKC before the adjustment to the "Potential change" table I'm now seeing -.34 FLKC instead. Since I did not changed the maximum flkc of -5, I don't believe I've compromised too much in terms of safety compared to the stock tables. I hope.. What do y'all think?
Here's a quick second log I took just now with a 3rd to 4th pull and 3rd gear pull right after.
http://datazap.me/u/solidone/z6-kc1?...1&zoom=447-966
Looks like the FLKc still managed to go to -.69 here toward redline.
Another thing that I think is interesting is that before I made the changes, there were many instances where FLKC only goes up to -.29 even though the value in "potential change" table was -.65.
log right before I applied the changes above, with -.29 FLKC in many areas:
http://datazap.me/u/solidone/z6-test...3166-2524-3588
Intent > Content
Old 05-08-2016, 05:29 AM   #164
Kodename47
Kodename47's Avatar
Drives: UK GT86
Stored timing retard plus an increment of added timing?
Beware that increasing the Positive FLKC limit may impact on IAM increasing if below 1.
.: Stealth 86 :.
Kodename 47 DJ:
Old 05-08-2016, 03:46 PM   #165
solidONE
solidONE's Avatar
That makes sense, but it's impossible for me to know 100% without the ability to log or view the stored FLKC values.
The intent of changing the the positive limit and decreasing the delay period value is to cause the IAM to recover a bit quicker than it does with the stock table. I'd have to drive the car pretty hard or get a bad tank of gas to see the effects. I will try to capture it in a log and compare it to a old log to see the difference this change made.
Intent > Content
Old 05-08-2016, 07:45 PM   #166
Kodename47
Kodename47's Avatar
Drives: UK GT86
The delay I understand however, based on the usual logic, I would assume that the positive limit could lengthen IAM recovery. I'd suggest that one the limit is reached the multiplier increases regardless. By making this higher then in some circumstances you'll need more positive FLKC before IAM increases. This is all relatively irrelevant anyway as one would hope you're not facing 3.5/4 degrees of FLKC retard in the 1st place.
Also, to make the delay obvious then reduce it by half. Probably not a bad idea on a car running well dialed in.
.: Stealth 86 :.
Kodename 47 DJ:
solidONE (05-09-2016)
Old 05-09-2016, 01:58 AM   #167
solidONE
solidONE's Avatar
The increase in the positive limit is to deal with those rare instances where IAM inexplicably drop under cruising low load steady throttle. Not sure if you've had this happen on your personal car, but I've see it quite a few times. Usually this happens while commuting on the highway flowing with traffic in 6th gear. Dont know exactly why this happens but it seems like a "glitch" of some sort. Or maybe bad gas? I dont know.
As far as the delay goes, I didn't want to get too greedy right off the bat, if you know what I mean. lol
Intent > Content
Old 05-09-2016, 02:21 AM   #168
Wayno
Wayno's Avatar
In my experience nothing is inexplicable. Better solving the actual issue which causes IAM drop in the first place than working around it and creating more complexity.
Maximum weight in the trunk? djmm Scion FR-S / Toyota 86 GT86 General Forum 20 08-13-2015 12:40 PM
“Maximum Attack” Scion FR-S stugray Scion FR-S / Toyota 86 GT86 General Forum 13 02-01-2015 09:45 PM
PA: Rays Gram Light 57 Maximum 5x100, 17x8, +43 (Price Reduced!) Needs more cowbell Wheels and Tires 20 02-22-2013 11:03 AM
MAXIMUM you would pay for a TRD Supercharger installed? FRiSson Forced Induction 24 11-04-2012 01:08 AM
MR-S Effect... Dimman CANADA 11 09-06-2011 12:49 PM
