Old 05-06-2016, 10:26 PM   #155
FRS Justin
Drives: 2013 Asphalt FRS
I really don't think its a brand specific failure considering N/A , Turbo and S/C have all failed for one reason or another...... So to place blame on a individual brand is probably more speculative than factual.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 05-07-2016, 01:52 AM   #156
johan
Drives: '14 981CS, '99 NB1
Originally Posted by Jaden View Post
I looked at the graph...
I was going by what he was saying... and I'm perfectly calm...
Jaden
Graph was for a WRX which has better rods, he was saying it would be dumb to do the same thing on an FR-S.
johan is offline   Reply With Quote
Old 05-07-2016, 03:21 AM   #157
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
then said he was doing it...lol
I know what he was saying and what the graph was for. I was saying it was comparing apples to oranges because it had lower compression and much higher boost...
I said it would be foolish to try and run the same amount of boost on a stock bottom end FA20 and he said he was doing it already.
I said you can't have it both ways... If you're doing it already and it's not safe you're either not very smart or you WANT to see it grenade...
Jaden
Jaden is offline   Reply With Quote
Old 05-07-2016, 04:35 AM   #158
VitViper
Drives: '15 FRS
What if I told you... boost is irrelevant?
I can drop a 72mm turbo on the car and make 500hp on 7psi.
What then?
VitViper is offline   Reply With Quote
The Following 7 Users Say Thank You to VitViper For This Useful Post:
#maverick# (05-08-2016), BRZoomTX (05-07-2016), CSG Mike (05-07-2016), DriftinFRS (05-08-2016), EAGLE5 (05-07-2016), GhostOp86 (05-08-2016), Guff (05-07-2016)
Old 05-07-2016, 12:46 PM   #159
seito23
Drives: Corn Juice junkie
the volume of mixture, in conjunction with timing, fuel and richness is where the magic happens.
seito23 is offline   Reply With Quote
Old 05-07-2016, 02:51 PM   #160
Mvhs09
Drives: Brz
Wow... This discussion about boost and motors is really long but anyways...
Vit has tuned two of my three cars that I've had, and plan on him tuning my brz too. He knows his stuff, and has tuned many. He has a great reputation. He knows what he's doing. Plain and simply, he's awesome. Nice job on your frs Vit. Make my brz awesome like you've made my civics.
Note: take what he says Seriously.. He tunes for a living for a reason. He's not some random troll like us.
Mvhs09 is offline   Reply With Quote
Old 05-07-2016, 03:05 PM   #161
johan
Jaden
:facepalm:
What then?
This conversation has become pointless lol.
Old 05-07-2016, 06:19 PM   #162
seito23
To be fair, in between people giving Vit a hard time... Vit has taken it in stride and kept sharing some good nuggets of info.
The other stuff is just.
@ VIT
The Following 2 Users Say Thank You to seito23 For This Useful Post:
stevemp5 (05-07-2016), VitViper (05-16-2016)
Old 05-08-2016, 01:44 AM   #163
Jaden
Road-hole
I"d say no you can't...
What then?
VE won't let you...
You can only fit so much air in 4 86x86 combustion chambers.. boosting it allows you to fit more...
Yes that turbo will flow enough air to make 500 hp at 7 psi, but there's no way you will ever get enough air into a 2l engine to make 500 hp at 7 psi...
Jaden
Old 05-08-2016, 02:23 PM   #164
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
VE won't let you...
Jaden
*whoosh*
You should just stop buddy, because this post clearly shows you have no idea how turbos actually work. Again, PSI != CFM. You've been told this already, yet you're still arguing based on boost level.
Just stop... you're embarrassing yourself at this point.
'13 WRB BRZ ~470whp // Instagram // YouTube
BRZoomTX is offline   Reply With Quote
Old 05-08-2016, 04:16 PM   #165
seito23
VE won't let you...
Jaden
VE? where's your TAF to show this isn't possible? I think you may be confusing volume and velocity. Our FA20 heads flow as much as some V8's, adjusting other variables 500hp is easy. Not breaking something in the process, that is why you hire guys like VIt.
You said,"You can only fit so much air in 4 86x86 combustion chambers.. boosting it allows you to fit more..." So which is it? only so much or boosting fits more?
Even if those COULD shock the piston and by extension the rod. <phrasing>
He is using timing AND PSI and boost by gear to minimize stress.
sit back and enjoy the show.
/the end
Old 05-08-2016, 09:09 PM   #166
Jaden
Road-hole
no you obviously don't understand...
Originally Posted by BRZoomTX View Post
*whoosh*
I never said psi equals cfm. I said the opposite...
Here let me spell it out for you.
you have three factors here...
You have the volume of air that will fit in the chambers... You have the volume of air that the turbo supplies at a given boost level, and you have the boost level.
Regardless of which turbo you have, you still can only flow so much air into the chamber.
With a bigger turbo, you have more flow at a given boost level, but there is STILL a limit to what the chamber can fit and flow.
To get to a certain level of flow, you HAVE to increase the boost level regardless as to what the turbo is CAPABLE of FLOWING...
SHOW me ANY instance of a 2.0l engine making 500 hp on 7 lbs of boost. You can't because it doesn't exist...
Jaden
The only way a turbo capable of flowing 35lbs a minute of air at 7 psi is going to actually be able to flow that air into a 2.0l engine AT 7PSI is if it's a compound boost setup and then your final boost level will be MUCH higher. You need to flow 35 lbs a minute of air into the engine to make 500 hp and I'm sorry, you just can't do that at 7 psi on a 2.0l engine
Old 05-08-2016, 09:23 PM   #167
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
- 'nuff said. Might as well be talking to a brick wall.
Old 05-08-2016, 10:11 PM   #168
Jaden
Road-hole
im he oned talking to a brick wall...
where is this magical 2.0l making 500 hp at 7 psi... brick wall?, you need to be looking in a fucking mirror.
The heads in this car are REALLY good at flowing air, but you AREN'T going to be making 500 hp on this car on less than 15 lbs of boost..sorry...
Jaden
p.s. so you're making 470 whp on your brz... What level of boost are you running again???? must be 6 right? stop, you're embarrassing yourself...lol Oh I know, you've got too small of a turbo...
2013 White Turbo FR-S (450whp) (Update) (For Sale Again) Synack Cars for Sale/Trade 40 02-27-2016 12:55 AM
2006 STi 450whp $25000 JoeShmoe Cars for Sale/Trade 0 08-28-2014 04:46 PM
450whp Turbo FRS - TR3 Performance JPxM0Dz FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 02-19-2014 12:40 PM
Auto-Craft Japan Turbo FT86 BPAuto Forced Induction 5 05-21-2013 10:57 AM
ft86 turbo RWD or AWD? CyberFormula Scion FR-S / Toyota 86 GT86 General Forum 31 01-18-2010 04:11 AM
