Old 05-06-2016, 10:24 PM   #1
jeppythedude
Drives: 86 GTS
Thumbs up Custom Audio System
This is my Idea for my 86 haven't seen it done before
custom fiberglass subwoofer/speaker enclosures in rear seat side panels
the enclosure would be raised up from the side panel
has anyone done it before, and would it work, would be great to see pics of something like it done
Subwoofers 10" wide 6"deep
Speakers 4" wide
jeppythedude is offline   Reply With Quote
Old 05-06-2016, 11:04 PM   #2
GeorgeJFrick
GeorgeJFrick's Avatar
Drives: 2013 Subaru BRZ Limited LR
I think you would have to do a custom fiberglass impression of the area behind it; then trim it and do some foam or padding.
Then you'd have to build the enclosure for the renders you've done and find some really solid mounting (partially bu using the custom impression for tight fight).
But the trunk lends itself much better to this; and there are some really sweet installs. It's not my 'thing' anymore; but I've seen some sweetly done trunks that could beat this method. Some guys have hard wood floors in the trunk with subs.
That said, this would be a lot of work and you'd need software to help with the enclosure calculations. It could be pretty sweet as a show car; but not worth it on a DD.
GeorgeJFrick is offline   Reply With Quote
Old 05-07-2016, 01:04 AM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Pretty much the same thought I had.
Yes it could be done, some have already done it. Your Google-fu is weak, but just takes a bit of work, but not hard.
However 10" subs would be too big. I would go with either 8" or 6" subs.
I wouldn't bother keeping the 4" full range speakers.
Then only issues I see is panel rattles. But there's always a fix for that.
Enclosure size is pretty simple, no need for fancy software, just good ol' math. The way I figured out the internal volume on my custom set ups was to fill it with water. Measure it, do the math, go from there. Simple, just add a garbage bag so you don't ruin the enclosure.
Old 12-26-2017, 01:39 AM   #4
Larkin
Larkin's Avatar
Drives: 2013 FR-S, manual, asphalt
Well not quite a 10 inch sub, these are some damn beastly 6.5 components! RE XXX's are the best all around 6.5 I have ever owned. I also have a pair up front, custom fab'd 4 inch dash mounts, and dual 10 inch subs. I will post pics of my whole build once I finish, I just have a few more details to fabricate and some equipment to purchase. It's a pretty insane sound system, the loudest and cleanest I have ever experienced, and I have been installing car stereos since the 90's.
Larkin is offline   Reply With Quote
The Following User Says Thank You to Larkin For This Useful Post:
Chimera (12-26-2017)
fibreglass, subwoofer
New Audio System: OEM Audio+ Reference, Audison Prima 8.9, or Hertz Energy setup? gamjatang Electronics | Audio | NAV | Infotainment 10 12-04-2015 05:12 PM
FS: OEM Audio Plus BRZ System 400+ Skippman Audio/Visual, Electronics, Infotainment, NAV 5 09-07-2015 06:20 PM
Custom Audio Set-up kylethomas23 Electronics | Audio | NAV | Infotainment 35 11-03-2014 06:08 PM
Alpine audio system upgrade w/ custom sub enclosure rjm86 Electronics | Audio | NAV | Infotainment 11 06-24-2014 12:16 AM
Custom audio in the FRS Kwise1 Scion FR-S / Toyota 86 GT86 General Forum 1 11-12-2012 07:27 AM
