Old 05-05-2016, 02:15 AM   #1191
Hyperblue302
Hyperblue302's Avatar
Drives: 2016 BRZ, 94 Integra GSR
Originally Posted by FR-Slide View Post
First time trying this, I hope I logged the correct parameters and got enough variance in driving. It was wet out and still traffic on most of the roads, so WOT pulls were basically impossible.
Can anyone tell me if this looks safe/acceptable for e85 tune?
http://www.datazap.me/u/pbthomas/log...=1-2-5-9-12-14
Just learning myself here, your fuel trims are within the ±5 range so that's good. Flck was minimal and your advance multiplier stayed at 1, which is great.
Hyperblue302 is offline   Reply With Quote
The Following User Says Thank You to Hyperblue302 For This Useful Post:
FR-Slide (05-05-2016)
Old 05-05-2016, 12:05 PM   #1192
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by Dru670 View Post
Would MAF3 be the better of the 3?
Yes.
The 1st lot of data for MAF1 was minimal. To get the best results you should reduce the dV/dt parameter but this requires more logging time as you discard more. I tend to set mine to 0.3/0.25 but then I like logs of 45 mins or longer when I do this.
.: Stealth 86 :.
Kodename 47 DJ:
Old 05-05-2016, 02:47 PM   #1193
Dru670
Drives: 2016 Scion FR-S
Originally Posted by Kodename47 View Post
Yes.
Should I flash the MAF1 rom or MAF3 rom if I wanted to do more logging to scale the maf and improve it?
Dru670 is offline   Reply With Quote
Old 05-05-2016, 04:24 PM   #1194
Kodename47
Kodename47's Avatar
Drives: UK GT86
No matter which one you do, the results should be the same. However sense would suggest you continue with the most recent and therefore the more accurate.
.: Stealth 86 :.
Kodename 47 DJ:
Old 05-08-2016, 02:23 PM   #1195
AlexEla
Drives: 2013 Pearl White Subaru BRZ Limited
First time posting in here. Just installed Borla V2 UEL yesterday and flashed the Stg. 2 UEL E85 Tune.. Let me know if everything is okay . Idle and cruising:
http://datazap.me/u/alexela/lunabuil...log=0&data=1-9
AlexEla is offline   Reply With Quote
Old 05-09-2016, 11:07 AM   #1196
COO86L
COO86L's Avatar
Drives: 2015 86 GTS + Mitsi Lancer GSR
I think I've done this right. Never used datazap before but here we go
EcuTek
Sprintex SPS 210
700CC DW injectors
Zeitronix flex fuel
http://www.datazap.me/u/coo86l/delic...0cc-revision-1
COO86L is offline   Reply With Quote
Old 05-09-2016, 03:38 PM   #1197
G-awesome
Drives: 2015 Firestorm Scion FRS
So I'm a total rookie at this but I've been lots of reading and experimenting lately to try to optimize my tune over the past few weeks and wondering if anyone can guide me in the right direction to smooth out the flkc and fuel trims even further.
I started off with the OFH 93 tune as a base tried applying Wayno's settings to see if I'm getting better results.
I'm running the following parts:
- auto transmission
- JDL catted UEL header
- stock overpipe/frontpipe
- TRD catback
- Perrin drop-in filter
- gas is Chevron 94 octane
Here's the logs for the following:
original OFH 93 UEL tune: http://www.datazap.me/u/gawesome/201...data=1-5-11-12
original OFT 93 UEL tune: http://www.datazap.me/u/gawesome/201...data=1-5-10-11
OFH custom tune with Wayno's auto throttle map, always-on radiator fan, 'Stg2 UEL 98 v101.AU.Rich A01G UEL' base timing b and AVCS tables:
http://www.datazap.me/u/gawesome/201...0&data=1-10-11
OFH custom tune with Wayno's auto throttle map, always-on radiator fan, 'Stg2 UEL 98 v101.AU.Rich A01G UEL' base timing b and Shiv's JDL E85 AVCS tables:
So from my rookie observations, all seems to being dropping IAM slowly with the 1st custom tune being the better of the 3 tunes. It looks like the OFH custom tune with Wayno's maps seems to be less erratic with flkc with the exception of the ltft being weirdly higher at -8 compared to the other two around -4ish which I don't really understand. I haven't scaled my maf yet btw for all 3 tunes.
Or maybe I'm just starting with an overly aggressive tune since I did use the OFH tune. But IAM and flkc looks worse on the OFT tune though?
I'm wondering if the erratic flkc at higher rpms be a fuel issue? Or is this something that just needs refining? I could try to fuel up with the next best gas here (Shell 91oct) and reflash with a 91 tune to test it out.
G-awesome is offline   Reply With Quote
Old 05-09-2016, 04:31 PM   #1198
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
@G-awesome the calibrations you've loaded are typically used on non-catted header setups, I believe. So, it may be that the ignition advance is simply too aggressive or the acvs table not well suited for your setup. I'd load a stg 1 calibration and log just to see if the flkc goes way. A number of different things can be causing your problem though. Exhaust vibration due to improper installation, bad gas, unsuitable calibration. Although the 3rd log using wayno's 98ron cam and ignition calibration looks the least worrisome.
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
G-awesome (05-09-2016)
Old 05-09-2016, 05:50 PM   #1199
G-awesome
Good point! I've been obsessing over the stage 2 UEL tunes since I got the header installed that I totally forgot to give the stage 1 a shot again.
Old 05-09-2016, 08:40 PM   #1200
solidONE
solidONE's Avatar
If the stg 1 come turns out to be free of knock (relatively) then you will have ruled out the vibration cause. Though, with a stg 1 calibration i think its safe to say you will not be taking full advantage of your headers. I'm sure ideally it's somewhere between a stg1 and stg2. Or you can try to find somebody with catted uel headers and use their cam and ignition maps as a starting point.
Intent > Content
Old 05-10-2016, 06:26 AM   #1201
Votlon
Votlon's Avatar
Drives: Scion FRS || Ducati 899
Do you guys use a software when analyzing the csv's or just know what your looking for .-.
Votlon is offline   Reply With Quote
Old 05-10-2016, 11:22 AM   #1202
Ondreiko
RWD addicted
Ondreiko's Avatar
Drives: BRZ 6MT OFT OFH
Hi!
here is the log i made during track session yesterday. Tuned by OFT based on v.101 Wayno's tune (+ custom MAF scale). my opinion the engine was working properly:
http://datazap.me/u/ondreiko/mrw-log...zoom=7419-7481
and i am going to make some final minor changes to MAF scaling (as excellent VGI's tool shows) in field of OL mode basing on this log.
Ondreiko is offline   Reply With Quote
Old 05-10-2016, 12:36 PM   #1203
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Would be quicker to just multiple 3.71 and 3.91 cells by 1.01 and call it a day. Don't need any tools.
http://datazap.me/u/ondreiko/mrw-log...mark=2852-2895
Originally Posted by Ondreiko View Post
Hi!
Old 05-10-2016, 01:07 PM   #1204
G-awesome
looks like I'm still dropping iam and flkc with the stage 1 93 uel tune...hmm http://www.datazap.me/u/gawesome/201...data=1-5-10-11
looks like I'm gonna check the hardware for leaks, vibrations, etc.
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 02:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 01:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 10:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 05:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 10:27 AM
