Old 04-14-2016, 09:20 AM   #15
JimR
JimR's Avatar
Drives: '15 FR-S, '92 Sentra SE-R
Most of the R1R's secret sauce comes from when it's shaved for autocross use. It's a squirmy tire that doesn't like to be ham-fisted at full tread. It falls off noticably on track when pushed past its temperature happy place. We ran them at a crapcan race on a Miata, and that was a mistake from a longevity standpoint. Not even a light, balanced car can make them last, especially in warmer climates. There is no cheating or malice on Toyo's part. Like the V1 Hankook, it's just an old tire design from a marketing era when 140TW is what sold. I bet if you ran them on the street and weren't side-scrubbing them all the time, they would last about the same as a lot of other high-end summer tires.
A bunch of organizing bodies moved the UTQG goalposts to 200TW, and what happened? Tires got even better. Tire technology isn't static. It's a competitive category, and manufacturers are advancing the grip/longevity/predictability point. UTQC means something. These are still tires that have to be safe for street use until they hit the wear bars, and they are doing a remarkable job of being everything to everyone.
It's excellent that so many solid choices now exist for so many applications. If you autocross, the RE71R tolerates a lot of heat cycles and grips fairly well down to nil tread without shaving half the tire off. That's a better value to autocrossers than 200TW's that turn to stone with a ton of tread left. Or if you track, you have legitimately streetable options that offer decent performance and longevity that best the old RA-1's/NT-01's for like money. Everyone can find the droid they are looking for.
JimR is offline   Reply With Quote
The Following 4 Users Say Thank You to JimR For This Useful Post:
kravi (10-25-2016), smg1138 (04-30-2017), strat61caster (04-14-2016), Tristor (08-28-2018)
Old 05-04-2016, 03:58 PM   #16
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
I am a believer that the VR-1s are basically RC-1s with treads cut in them. They grip relentlessly and are wearing great so far. They took all the heat of two 90 degree track days with 30 minute sessions and asked for more. I pushed the car as hard as I could and never once lost grip or felt greasy running them at 35 psi hot. I'm a happy first-time Maxxis customer!
The Following 9 Users Say Thank You to ATL BRZ For This Useful Post:
ajc209 (05-04-2016), BatStig (05-04-2016), bhmax (01-31-2019), CSG Mike (05-04-2016), Hyper4mance2k (06-15-2018), strat61caster (05-04-2016), Toyarzee (05-10-2016), Tristor (08-28-2018), wparsons (09-20-2016)
Old 05-04-2016, 04:38 PM   #17
Pat
Pat's Avatar
Drives: 2023 BRZ
I really like how you've put together your car. I always enjoy your pictures, too.
The Following User Says Thank You to Pat For This Useful Post:
ATL BRZ (05-04-2016)
Old 05-04-2016, 04:46 PM   #18
ajc209
Drives: GT86 Cosworth
35psi!!! Blimey. I run my AD08Rs at 28psi hot. They got up to 34psi (from 28cold) on my first session and they felt pretty greasy at that pressure.
ajc209 is offline   Reply With Quote
Old 05-04-2016, 05:07 PM   #19
ATL BRZ
ATL BRZ's Avatar
Lol well it's a good starting point I guess. I was just using recommendations from a few others who have been using them so far. It may be too high...
The Following User Says Thank You to ATL BRZ For This Useful Post:
ajc209 (05-04-2016)
Old 05-04-2016, 05:15 PM   #20
ajc209
I couldn't find any recommendations for this car so I looked around. Scoobie bugs eyes like 32-33psi. Renult Megans like 28-30psi. Lotus Elise like 26-28psi so I figured the 86 is somewhere between the latter two.
The Following 2 Users Say Thank You to ajc209 For This Useful Post:
ATL BRZ (05-05-2016), wparsons (09-20-2016)
Old 05-05-2016, 03:00 PM   #21
LavaLife
LavaLife's Avatar
Drives: 2015 Scion FR-S
Damn im running 35 to 37 PSI Hot on my RS-3's not as greasy as I was expecting. Aslo ran 34psi hot on a previous set of NS2r's those grip levels were extremely high with a 100/120TW very impressed with those tires but the RS3's seem a lot faster for some reason at a 200TW.
Thinking of going a full R-Comp for the next set of tires NT01's
LavaLife is offline   Reply With Quote
Old 05-05-2016, 03:40 PM   #22
CSG Mike
CSG Mike's Avatar
I generally run between 33 and 38 on this platform, with a typical "EHP" or entry level r-compound.
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
ajc209 (05-10-2016), BatStig (05-05-2016), kravi (10-25-2016), Tristor (08-28-2018)
Old 05-10-2016, 11:09 AM   #23
ajc209
How about specifically the AD08R?
Old 05-10-2016, 01:17 PM   #24
CSG Mike
CSG Mike's Avatar
Do you have pyrometer readings?
Old 05-10-2016, 02:08 PM   #25
ajc209
Nope so next time, when I have one, whats the target surface temperature?
Old 05-10-2016, 02:53 PM   #26
CSG Mike
CSG Mike's Avatar
I'm looking for a trend, rather than just a surface temp. Center higher than edges = too much pressure. Center lower than edges = too little pressure.
Outer hotter than mid/inner = not enough camber. Inner hotter than mid/outer = too much camber.
Take it with a grain of salt, as driving errors can produce irregular readings.
The Following 6 Users Say Thank You to CSG Mike For This Useful Post:
ajc209 (05-10-2016), kravi (10-25-2016), strat61caster (05-10-2016), Toyarzee (05-10-2016), Tristor (08-28-2018), wparsons (09-20-2016)
Old 09-17-2016, 04:59 PM   #27
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
@ATL BRZ Now that you've had these tires for a while what's your thoughts? I'm pulling the trigger in a set next week.
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
Old 09-19-2016, 01:29 PM   #28
kch
Senior Misanthrope
kch's Avatar
I have 5 track days on my set. I think 255 is too much tire for NA power, but I still like them a lot. Predictable, great grip, and they start to give good feedback at the limit. Plenty of life left in them.
Edit: I run them around 32psi hot, and around -2.5F/-1.8R. I could probably stand to have a smidge more camber.
The Following 3 Users Say Thank You to kch For This Useful Post:
Bramick (09-19-2016), CSG Mike (09-19-2016), Tristor (08-28-2018)
Maxxis Victra RC1 Review whataboutbob Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 12-18-2016 12:17 AM
Maxxis RC-1 tire notes Doozer Tracking / Autocross / HPDE / Drifting 26 06-11-2015 09:39 AM
FS: (4) Maxxis RC-1's 255/40/17 BeltedBiscuit Wheels and Tires 5 09-08-2014 09:38 AM
Hankook Ventus RS3... I have a 200TW RS3? CSG Mike Tracking / Autocross / HPDE / Drifting 41 05-24-2013 05:49 PM
new R compound from Maxxis Matt Andrews Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-08-2012 02:27 PM
