Old 05-03-2016, 08:24 PM   #15
BRZnut
Drives: BRZ DGM Limited
Originally Posted by stevesnj View Post
Thats way high, should be no higher than 14.2-14.4 Shouldn't effect the LEDs since some can run at 24v but not always. Ask the Toyota service the specs on voltage reading.
I'll have to recheck those voltage readings from the radar dectector.
The new red top is on its way from Amazon. I'll report back if it corrects the flicker. (needed a new battery anyway)
Old 05-03-2016, 09:33 PM   #16
axelo
Drives: Whiteout frs
Its completly normal... Well at least in my case...i have creed led drls
it
axelo is offline   Reply With Quote
Old 05-03-2016, 10:48 PM   #17
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
it
Your kidding right? For once the default search emoticon doesn't apply here, also its not the same the BR-Z DRL is led factory not some retrofit bulb.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
clayrush (05-06-2016)
Old 05-04-2016, 07:25 AM   #18
BRZnut
Ya, and they never flickered before at idle. This is something new. My red top arrives today. Will install when I have time this weekend and see if it makes a difference.
Old 05-04-2016, 09:56 AM   #19
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Very interesting, the battery seems to make sense to me, I'm curious to see if this resolves your issue.
JazzleSAURUS is offline   Reply With Quote
Old 05-05-2016, 04:19 PM   #20
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Just in case the battery idea doesn't work, I traced my DRL flicker to the handbrake. The same circuit that lights handbrake on warning light in the instrument cluster switches the DRLs on and off. In my case a very slight movement of the hand brake lever would trip the switch. A small bump, my elbow hitting the lever, any shake at all in the idle and I'd be flashing people like Pee Wee Herman.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 05-05-2016, 08:30 PM   #21
axelo
Have fun looking for a reason for your flickering lights jajaja
Old 05-06-2016, 12:55 AM   #22
FRSBRZGT86FAN
Have fun with crap light output from some cree LEDs
Old 05-06-2016, 07:53 AM   #23
stevesnj
stevesnj's Avatar
The CREE and Phillips are probably the best out there. The end user not choosing the correct Lumens is usually the issue not the LED.
My 2016 Build thread
Old 05-07-2016, 07:35 AM   #24
BRZnut
New red top battery is in.........update to follow!
Old 05-07-2016, 09:52 AM   #25
BRZnut
FIXED! The stock LED DRL on my BRZ no longer flicker at idle. Seems it was the OEM battery getting weaker (3.5 years). Not sure why the new battery fixed it , but it did. Some other observations:
Car as expected now starts quicker and you can hear the difference in the sound of the starter.
When driving, voltage readings on my radar detector use to swing between 14.2 to 14.8 (AC is off). Now when driving its a steady 14.6.
When the car was off and I had the accessory on (with heater blowing) the voltage would drop quickly to 11.9-12.0. Now it stays at 12.6.
For those that are interested, got this red top here and it came in 3 days. I did use the tray they provide under the battery to make it the same height of the OEM battery:
[ame="http://www.amazon.com/Optima-Batteries-8020-164-Starting-Battery/dp/B000MS9VZK/ref=sr_1_1?ie=UTF8&qid=1462629143&sr=8-1&keywords=red+top+8020-164+35"]Amazon.com: Optima Batteries 8020-164 35 RedTop Starting Battery: Automotive[/ame]
The Following User Says Thank You to BRZnut For This Useful Post:
FRSBRZGT86FAN (05-07-2016)
Old 05-07-2016, 08:26 PM   #26
FRSBRZGT86FAN
Awesome I had a feeling that would fix it. @axelo troll somewhere else
Old 05-08-2016, 01:09 AM   #27
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
You definitely had a problem with the battery. My Radar Detector also tells me voltage (passport), and with the car off, it reads 12.6V.
N1rve
Old 05-08-2016, 09:55 AM   #28
BRZnut
Interesting..same as mine now with the new battery.
I guess those with the LED DRL can use the flicker sign as an indicator that it is time to replace the battery, before they get stranded. The flicker was very noticeable pulling up against a wall, or you can just look directly at them to see it. (but for those with auto, car needs to be in N for the DRL to stay on)
Interior Lights Flickering Skorov Electronics | Audio | NAV | Infotainment 14 05-01-2016 02:54 PM
Did anyone notice? FRSNewb Off-Topic Lounge [WARNING: NO POLITICS] 2 07-21-2014 02:59 PM
Sidemarker LEDs flickering CreinCrein Cosmetic Modification (Interior/Exterior/Lighting) 5 05-12-2014 08:53 PM
HID BULB FLICKERING HELP!! ijuliusx Cosmetic Modification (Interior/Exterior/Lighting) 3 05-24-2013 03:18 AM
Anyone else notice... Linseal Scion FR-S / Toyota 86 GT86 General Forum 5 06-03-2012 11:18 PM
