Northern California NorCal
Old 05-03-2016, 04:15 PM   #7057
_Se7en_
Drives: Whiteout Scion FR-S
From what I understand (the Internet can correct me if I'm way off base) due to almost zero camber up front left (driver side) when making hard left turns you will get a slight positive camber. Continuously doing hard turns like during our drives can cause excessive tire wear on the outside.
Sent from my SM-N920T using Tapatalk
_Se7en_ is offline   Reply With Quote
The Following 3 Users Say Thank You to _Se7en_ For This Useful Post:
Clipdat (05-03-2016), finch1750 (05-03-2016), MisterSheep (05-05-2016)
Old 05-03-2016, 04:21 PM   #7058
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Cool, thanks for the insight. I wonder if I should even bother rotating them at this point. They also appear to be starting to dry rot/crack. They were installed in October of 2013.
Originally Posted by humfrz
I'm old and lazy
Old 05-03-2016, 04:24 PM   #7059
_Se7en_
Eh. You have some negative camber in the back. More than likely your rears aren't as back as your front (least went talking about the outside edge)
I'd rotate them if money is an issue. Should wear em out bit more even after another 10k of same driving habits. Otherwise I'd go for another set.
The Following User Says Thank You to _Se7en_ For This Useful Post:
Old 05-03-2016, 04:27 PM   #7060
Clipdat
Proud of BOXER
Clipdat's Avatar
Yeah, the outer edge of the rears look fine/normal. I will have them rotated and try to get another 10k out of them.
I'm old and lazy
_Se7en_ (05-03-2016)
Old 05-03-2016, 05:03 PM   #7061
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Anyone have any idea why the outer edge of my driver's side front tire is so worn down compared to the outer edge on my passenger side front?
BECAUSE NASCAR!
But seriously though, I agree with @_Se7en_ just rotate them if you want to eek out a few more thousand miles out of em. I personally like the "rearward cross" method of rotation to kinda even out the outer shoulder wear. What tires are you on? I just replaced my my RE11As recently. I think we got our tires around the same time and we probably do about the same amount of driving (back roads and short work commute).
Old 05-03-2016, 05:05 PM   #7062
Clipdat
Proud of BOXER
Clipdat's Avatar
I asked Neal about the cross rotation pattern and he recommended just a simple front to back swap instead. Shrug.
Yeah I saw you put on MPSS thanks to the oil cooler pics. I'm on Toyo T1 Sport. They apparently have a 20k treadwear warranty which I'm sure I've already violated by not rotating every 5k.
BECAUSE NASCAR!
I'm old and lazy
Old 05-03-2016, 06:34 PM   #7063
Clipdat
Proud of BOXER
Clipdat's Avatar
Look at this ridiculous plate I just saw in my work lot. I take offense to this, because the only way this would be appropriate is if this was a 1M, and it's not.
I'm old and lazy
MisterSheep (05-04-2016)
Old 05-03-2016, 06:39 PM   #7064
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
maybe it's a legit request for actualy M power that they couldn't afford?
Old 05-03-2016, 06:41 PM   #7065
finch1750
finch1750's Avatar
These are my alignment specs when I got the tires/springs/wheels put on 10k miles ago.
Dude. you really need more camber in front. get some SPC bolts and max them out. Itll help I think plus you should understeer less.
Old 05-03-2016, 06:43 PM   #7066
Clipdat
Proud of BOXER
Clipdat's Avatar
No can do, bro. My wheels are 17x9 +45 so I had to use a 3mm spacer to get them to fit and not rub the spring perch in front. Putting negative camber would push the tire right right into the spring perch. This is why I really want coilovers.
I'm old and lazy
Old 05-03-2016, 06:44 PM   #7067
finch1750
finch1750's Avatar
Hmm, I thought you were on coils. time for some or bigger spaces and ARP extended studs
Old 05-03-2016, 06:49 PM   #7068
Clipdat
Proud of BOXER
Clipdat's Avatar
Bigger spacers? I am already approaching mexipoke status in front.
Hmm, I thought you were on coils. me for some or bigger spaces and ARP extended studs
I'm old and lazy
Kaotic Lazagna (05-03-2016)
Old 05-03-2016, 07:20 PM   #7069
finch1750
finch1750's Avatar
lol. wasnt sure how bad the +45 made it. I guess even my +42 is pretty flush but the camber and mudguards help haha
Old 05-03-2016, 08:49 PM   #7070
finch1750
finch1750's Avatar
Never been to a music festival, but this is tempting
undefindedt (05-03-2016)
*Chat* Vancouver FR-S/BRZ Members Mumbo Jumbo Thread peazs CANADA 1397 06-28-2019 12:17 PM
NorCal (Bay Area) AutoX Thread! BlaineWasHere Northern California 1398 02-08-2019 01:27 PM
Mid-Atlantic Chat Thread clevrname Mid-Atlantic 5296 08-25-2016 01:30 PM
FS: Five Axis Five:AD Aero Kit w/ Rear spoiler Whiteout - NorCal Bay Area firebert Exterior Parts (Aero, Lighting, Etc.) 13 01-08-2013 11:07 PM
NorCal Bay Area ecutek tuning AsphaltLover Southern California 0 11-11-2012 12:38 AM
