Old 08-18-2013, 07:41 AM   #1
sho
Drives: s2000
Wheel Directory: Volk Racing CE28 18x9.0 +43
Heres my white 86 with CE28RT's
Wheels: 18x9 +43
Tires: hankook RS3 245/40
Coilovers: Ohlins R&T
Photos taken right after the install. Apologies for the phone pic quality
sho is offline   Reply With Quote
The Following 8 Users Say Thank You to sho For This Useful Post:
adprokid (08-19-2013), humanshield (08-19-2013), JackSmiley (08-18-2013), Kami Speed (06-10-2015), melon (08-18-2013), mfbmike (08-19-2013), SuperDave (05-19-2016), xia (08-18-2013)
Old 08-18-2013, 10:41 AM   #2
red1993sol
Drives: 2013 white BRZ
Looks good!! Nice coilovers also!
red1993sol is offline   Reply With Quote
Old 08-18-2013, 10:48 AM   #3
melon
melon's Avatar
Drives: Toyota 86
Love the wheels.,.
BTW, What's the Rear Skirt your using?
melon is offline   Reply With Quote
Old 08-18-2013, 12:56 PM   #4
BRZ NA
Drives: WR blue
How much camber r u running? rolled fenders?
BRZ NA is offline   Reply With Quote
Old 08-18-2013, 05:06 PM   #5
sho
Drives: s2000
Originally Posted by melon View Post
Love the wheels.,.
they are the aero kit / nur spec toyota rear skirts
The Following User Says Thank You to sho For This Useful Post:
melon (08-19-2013)
Old 08-18-2013, 05:12 PM   #6
sho
Drives: s2000
didn't have to roll the fenders
camber would be all over the place as I haven't got an alignment done since the install of the coils the night before
Old 08-19-2013, 10:18 PM   #7
humanshield
Drives: bucket
i was going to ask how you liked the coilovers but i see from the post above it sounds a bit early for you to answer. i like the setup so far!
humanshield is offline   Reply With Quote
Old 08-19-2013, 10:59 PM   #8
sho
Drives: s2000
I gave it a few runs around last night before dropping the ohlins more from its recommended height settings and test it out again and well what i can tell you is that i'm glad i replaced the zero3s
the difference is noticed pretty much straight away. I personally think its worth the extra coin for the comfort and handling
all that's left is a wheel alignment and track time
humanshield (08-20-2013)
Old 08-20-2013, 12:52 AM   #9
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
Proper coilovers and worth the extra money.
adprokid is offline   Reply With Quote
Old 12-03-2013, 10:32 PM   #10
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Added to the Wheel Directory:
http://tinyurl.com/86wheels
Old 08-06-2014, 10:02 AM   #11
BUMBLEDOG
Drives: GT86
nice wheel, want more photo of your car
BUMBLEDOG is offline   Reply With Quote
Old 06-10-2015, 12:40 PM   #12
liquidsky44
liquidsky44's Avatar
Drives: AVO Turbo Subaru BRZ / Subaru WRX
Size:  266.9 KBName:  ImageUploadedByTapatalk1433954006.687934.jpg
Size:  192.3 KBName:  ImageUploadedByTapatalk1433954176.709084.jpg
I'm on KW Clubsports and Essex AP Sprint kit. Rubbers: Michelin Pilot Super Sports 245 40 18 and there is no issue with rubbing at all at full lock and under load.
AVO Turbo|Essex AP Sprint Kit|AVO Overpipe|HKS Hi-Power Spec L Catback|Cusco Engine Mounts|Whiteline Bushings|KW Clubsport|Defi Advance ZD|AEM Wideband Failsafe Gauge|Greddy ProFec Boost Controller|Tomei 2Way LSD|AEM Water/Meth Kit|PBM Angle Kit + Kunckles|Flatwell LCA|HKS Oil Cooler|Greddy High Cap. Diff Cooler|Sard ATF Oil Cooler|CSF Radiator|
liquidsky44 is offline   Reply With Quote
Old 05-03-2016, 04:55 PM   #13
Ryan_86
Ryan_86's Avatar
Drives: 2016 Scion FRS - Steel
any spacers?
Ryan_86 is offline   Reply With Quote
Old 05-04-2016, 06:58 PM   #14
liquidsky44
Originally Posted by Ryan_86 View Post
any spacers?
The pics above are without spacers, but I'm running with front 3° and rear 1° camber settings. Currently I'm on 15mm spacers front and back with the same camber settings and it look much better now.
Wheel Directory: Volk Racing TE37 18x10.0 +44 Jesse@JDLAutodesign Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 59 12-14-2017 07:04 PM
Wheel Directory: Volk Racing TE37 17x8.0 +36 / 17x9.0 +36 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 46 05-06-2014 12:19 AM
Wheel Directory: Volk Racing SE37 17x8.0 +38 diss7 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 12-03-2013 10:39 PM
