Old 05-03-2016, 08:55 AM   #3795
Northwest86
Drives: Velocity Orange 86 GT
I like Cupholders to and it's only 2 bolts. When I'm going to track days I usually just get everything in bottles /cans and use the doors. Your other option is pretty much a metal bar and bolting to the passenger seat rails without having to drill holes. They usually take about 5 minutes to make. Mightycarmods did a video recently about making one. If you have a drillbit, drill and a marker You can make one. Just get a steel offcut the size you want from a local fab shop.
Northwest86 is offline   Reply With Quote
Old 05-03-2016, 10:00 AM   #3796
ZionsWrath
Thanks
ZionsWrath's Avatar
Who sells a cup holder mount? I was looking at some posts and it looks like it bolts on from the top? I could work with that if so.
Old 05-03-2016, 10:11 AM   #3797
Northwest86
I'm sure someone sells mounts but I'm not sure who. The extinguisher uses the two bolts below the cup holders. My suggestion would be to find an extinguisher that comes with the bracket then go to whatever your local hardware stores are and find the right material that'll fit your car. Just decide If you want to go the centreconsole route or the seat route.
Old 05-03-2016, 03:53 PM   #3798
ZionsWrath
Thanks
ZionsWrath's Avatar
Been doing quite some googling today. Can't find anything useful, everything is custom made.
Best I saw was STM Fire Extinguisher but its New Zealand only. It's expensive and probably would cost twice as much to ship.
Other than that I got nothing.
Anyone ??
Old 05-04-2016, 04:25 PM   #3799
Uplink
Uplink's Avatar
Drives: anything you let me
Prefer just something I can buy. I have no fabrication equipment or experience.
Also I drive to my events I like my cup holder ^_^ If it is easy to bolt on and off sure but if I have to remove the center to reach the back side I'd rather not.
The regulation is
Did some looking around, only premade one I see is the STM one but its from NZ...
I didn't realize they upped the requirement this year. That kinda sucks if you're in a street car.
The one I originally used for the Vette was a Brey-Krause unit. It bolted between the seat and slider and tucked the bottle under your calves or same spot on the passenger side depending on where you can reach.
Generally speaking, you want it somewhere you can get it while belted in, just in case.
Uplink is offline   Reply With Quote
Old 05-04-2016, 07:52 PM   #3800
Antihero983
Autobot
Antihero983's Avatar
Drives: 2013 Subaru BRZ Premium
If I run the Skyline R32 brakes (front) and WRX 2 pots (rear) hat AutoX class will that bump me into?
2013 BRZ
1978 280Z
1972 Baja Bug
1996 Corolla
What the hell am I thinking...
Antihero983 is offline   Reply With Quote
Old 05-04-2016, 09:14 PM   #3801
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
STX, assuming they're not lighter or smaller than stock.
Old 05-04-2016, 10:11 PM   #3802
cjd
cjd's Avatar
Drives: 2017 BRZ
Lighter is fine (else the AP Sprint wouldn't be legal)
Diameter and thickness are the key dimensions, noted here (14.6 A in the rulebook):
Non-standard brake rotors may be used provided they are of equal or larger dimensions (diameter and thickness) and made of ferrous material (e.g., iron). Thickness includes the individual plates of a vented rotor, as well as the overall dimension. The diameter for replacement rotors is measured at the minimum outside dimension. Aluminum rotor hats are allowed. Cars originally equipped with solid (non-vented) rotors may utilize vented rotors. Cross-drilled and/or slotted brake rotors may be fitted provided all such voids are within the disc area and comprise no more than 10% of that area. Brake calipers and mounting brackets may be replaced provided they bolt to the standard locations and the number of pistons is equal to or greater than standard. A functioning emergency brake of the same type, operation, and actuation as OE must be present. Drum brakes may be replaced with disc brakes of a diameter equal to or greater than the inside diameter of the standard drum. Such conversions must be bolted, not welded, to the axle/trailing arm/upright and must include an integral, redundant emergency brake. Changes to backing plates/dust shields/brake lines to accommodate these changes are permitted but may serve no other purpose.
The Following 2 Users Say Thank You to cjd For This Useful Post:
Antihero983 (05-05-2016), DocWalt (05-04-2016)
Old 05-04-2016, 10:25 PM   #3803
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Correct, wrong wording. I meant to say smaller.
Old 05-04-2016, 10:40 PM   #3804
cjd
cjd's Avatar
Drives: 2017 BRZ
Uh... Not to be pedantic, but it's so much fun! You said smaller.
Old 05-05-2016, 10:38 AM   #3805
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Yeah yeah
The Following User Says Thank You to DocWalt For This Useful Post:
CSG Mike (05-05-2016)
Old 05-06-2016, 04:15 AM   #3806
Fricke
Drives: Toyota GT86
Oem aero
I can't do much about it in my class, but the options I have is this.
Oem GT86/BRZ wing vs TRD duck tail wing.
So my question is, is there any solid info on any off those 2 has the best (if any) possible effects on downforce/drag if any.
I know it's most likely, nothing at all
Fricke is offline   Reply With Quote
Old 05-06-2016, 08:14 AM   #3807
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
Originally Posted by Fricke View Post
Oem aero
OEM wing makes 1,5kg on downforce thanks to its weight :p
It's ugly and useless.
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
The Following User Says Thank You to MaximeT For This Useful Post:
ottoyu34 (05-06-2016)
Old 05-06-2016, 08:35 AM   #3808
cjd
cjd's Avatar
Drives: 2017 BRZ
It does reduce drag ever so slightly if I remember right.
The Following User Says Thank You to cjd For This Useful Post:
DocWalt (05-06-2016)
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
