Old 05-02-2016, 05:49 PM   #1
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
Cool Get Your Subscriptions In, We're Doing a Budget 2JZ Swap!!
After talking to about 30 tire kickers over the past 6 months we have a customer who is actually having us do a 2JZGTE swap into his 2013 FRS. We get calls at least once a week from people who have seen our DRAGFRS build and records and they want to do it to their car, but no one wants to actually spend money to do it, they want it to happen with 5 grand and a JDM motor. We have a customer local to us who upon blowing his stock FA20 with a turbo kit decided to go 2J. This build overall is probably going to take place over the next 2 months. The customer is not in a hurry and we want to make sure we make our part purchases and moves carefully since this is the first budget street setup we have done.
I will not make updates every day or probably every week, but I will keep everyone updated on progress and have a final overall number at the end that can give people real world $$$ figures for what they are in for. I also hope to have a package of parts available that we can do for those that would be interested.
Thanks for reading and following along, stay tuned for updates!
-Brady
JDM 2JZGTE and R154 Manual Transmission
Preparing for the first test fitment ! Preliminary test fit is to check all the clearances, start sorting the mounts, and start picking out turbo manifold.
Update 5/25:
We have started ordering preventative/necessary parts for the engine. JDM engines are usually a little rough and have been sitting in a warehouse or on a boat for who knows how long. Here are the parts we are replacing:
Timing Belt
Water Pump
Water Pump Housing (The JDM water pump assemblies are completely wack)
Spark Plugs
Valve Cover Gaskets
PCV Breather Hoses
Thermostate
And this is only what we have found so far, I'm sure there will be more to come as far as that goes.
We are currently waiting on a couple of these to come but I couldn't resist at least sitting it in the car so to see where it is so far.
Up first in the hack and hammer game is the factory heater hoses and the diagonal cross bar mounts. These definitely have to be removed and the heater hoses need to be as short as possible.
I'll be back with more updates once we get some more parts on the engine and make some more room, hopefully we will get the engine to its final mounting point!
Pure Automotive is offline   Reply With Quote
The Following 15 Users Say Thank You to Pure Automotive For This Useful Post:
adrianfrs (09-12-2017), Baldoak (05-26-2016), CxG (01-14-2017), DAEMANO (05-02-2016), Draco_PR23 (05-03-2016), D_Thissen (05-02-2016), flippy (05-17-2016), FRSBRZGT86FAN (05-02-2016), hmong337 (05-03-2016), Hyperblu (10-12-2016), JonAvalon (05-02-2016), MisterSheep (05-04-2016), Sportsguy83 (01-06-2017), xkalelx (03-06-2017), zuldajin (05-06-2016)
Old 05-02-2016, 08:47 PM   #2
TofuJoe
Ohne Titel
TofuJoe's Avatar
Drives: 2017 BRZ PP ISM
In for the updates.
TofuJoe is offline   Reply With Quote
Old 05-02-2016, 09:14 PM   #3
pooch
pooch's Avatar
Drives: 2013 Scion FR-S (M/T)
Staying posted for updates
pooch is offline   Reply With Quote
Old 05-02-2016, 09:58 PM   #4
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Subscribed
Old 05-02-2016, 11:42 PM   #5
D_Thissen
D_Thissen's Avatar
Can't wait to see the results
Old 05-02-2016, 11:45 PM   #6
kcam86
Drives: Asphalt FR-S MT
Has 2 months past yet? If not wake me up then! Because this is exactly what I've been waiting for a real world estimate. Not this "Oh its going to be 20k+ " Or " I did it in my garage for 8k". My hopes it will break down what one could expect doing this swap and hopefully no bias is influenced by egos
kcam86 is offline   Reply With Quote
Old 05-02-2016, 11:59 PM   #7
FRSBRZGT86FAN
OOOHHH Can we start guessing how much the build will cost on a budget? I bet on $25k
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Old 05-03-2016, 01:43 AM   #8
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Subbed
hmong337 is offline   Reply With Quote
Old 05-03-2016, 02:00 AM   #9
ft86xtc
Drives: 2013 FRS
Have you decided what engine management you'll be using?
ft86xtc is offline   Reply With Quote
Old 05-03-2016, 02:05 AM   #10
86drift
86drift's Avatar
Drives: Toyota 86 GT
Surely if it was a budget swap it'd be non-turbo. They're bloody cheap here down under.
Strap a 2nd hand turbo on the side and it'd go hard.
86drift is offline   Reply With Quote
Old 05-03-2016, 07:49 AM   #11
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Guaranteed this will be $15k+ for absolutely no mods provided everything goes right, nothing is broken on the donor motor, with functioning cluster. Also, considering there's an estimation posted by Pure already, you could start there.
I'd expect more, though.
-slicktop
2013 Scion FRS
2JZ-GTE/V160 Swap Build Thread
slicktop is offline   Reply With Quote
Old 05-03-2016, 12:02 PM   #12
tysoNgwaNg
awesome.
tysoNgwaNg's Avatar
Drives: 1994 Toyota Celica, 2014 Scion FRS
Tuned in
tysoNgwaNg is offline   Reply With Quote
Old 05-03-2016, 02:31 PM   #13
kcam86
I wouldn't be surprised but given the fact there are motor mounts aND a few other things prefab I bet the biggest issue will be finding a source of reliable harnesses. Getting it to physically fit is easy but the wiring good grief......
Old 05-03-2016, 02:47 PM   #14
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Also in for results.
Budget V8 Swap (under $10,000) wutsaiu Engine Swaps 146 06-11-2018 08:53 AM
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
WTB A/T BRZ/FR-S CA Budget 21k Euan Want-To-Buy Requests 4 07-20-2015 11:50 PM
$2K Budget. What Would You Do? Skippman Electronics | Audio | NAV | Infotainment 46 02-22-2013 11:23 AM
There goes my MOD'ing Budget RedRocket Scion FR-S / Toyota 86 GT86 General Forum 35 10-19-2012 08:14 AM
