Old 05-02-2016, 07:09 AM   #183
MaXimus
Meh!
MaXimus's Avatar
Drives: Satin White, 86, Manual
I posted a while back after having the dealer change TOB around 60k. I'm now on 86k and seems having similar issue.
I even consciously leave the car in neutral at lights, avoid over shifting/downshifting. I wanna get a camera into that hole to have a proper look.
RAYS TE37V 17X9 / MICHELIN 245/40/R17 / KW V3 / RACESENG TOP HATS / MOTUL 5.1 + BRAIDED LINES / FERODO DS2500 BRAKE PADS / NEXUS 7 IN DASH / VDS UEL HEADERS / CRAWFORD POWER BLOCKS/ K&N DROP IN FILTER / Custom 3 inch header back catless exhaust / Varex 3in Muffler / HT AUTO LIP KIT / VALENTI TAIL LIGHTS / MORIMOTO PROJECTOR + HID.
MaXimus is offline   Reply With Quote
Old 05-02-2016, 09:47 AM   #184
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
besdies OEM, is there better one for TOB?
Old 05-02-2016, 12:17 PM   #185
seant2h
Drives: 2013 BRZ 6MT LTD
I posted my TOB experience in another thread...
Originally Posted by seant2h View Post
I commute 94 miles per day, mostly highway with about 0.5 miles on each end and below is what happened to mine after 88k miles. Also for anyone who says I don't know how to drive stick, I have had several manual cars in the past 18 years: two Hondas, one Hyundai, a Saturn and this car and I have driven this car less miles than any one of them and none of them have I ever replaced the clutch or TOB... Until today.
seant2h is offline   Reply With Quote
Old 05-02-2016, 11:03 PM   #186
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
^ ew... at least it's still one assembly. lol
Intent > Content
Old 05-03-2016, 09:11 AM   #187
zc06_kisstherain
Drives: SWP BRZ
did you replace it with OEM again? or other better quality aftermarket one?
Old 05-03-2016, 10:47 AM   #188
extrashaky
Drives: 2014 BRZ Limited
Originally Posted by Coheed View Post
My TOB is starting to make more noises. Now when I rev high (5000rpm) with the clutch depressed, it makes noise. The first few times I heard it, it sounded like someone was honking their horn at me. Just a faint honk noise. Now it is getting more frequent, and I am planning on getting a new clutch set soon to resolve this issue.
15000 miles and TOB already taking a shit.
That doesn't sound like a bad throwout bearing. When a TOB goes bad, it makes different pitches/volumes of noises when you engage and release the clutch in neutral. I had one go out in my old Triumph, and close to the end it would sing several different notes when the clutch was let out or in while the car was sitting still.
Find a 20% off coupon and go pick one up at Harbor Freight. They work fine. And you can use it to check yourself for polyps.
Old 05-14-2016, 11:02 AM   #189
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
I've never heard one quite like this. I've had several fail, but this is quite different. I'll get some video of it. You get some vibration in the pedal as well with the clutch depressed at higher rpm. I can replicate the noise at will most times. It seems to resonate around 5k rpm.
Well, it's either that, or perhaps a thrust bearing issue, which isn't a known problem with the FA20 to my knowledge.
Coheed is offline   Reply With Quote
act throwout bearing blown Engine, Exhaust, Transmission 0 08-30-2015 02:17 AM
Clutch Spring Removal & Throwout Bearing DemonRawr Issues | Warranty | Recalls / TSB 2 05-13-2015 08:08 PM
Release Bearing or Pilot Bearing Cal3000 Engine, Exhaust, Transmission 11 01-27-2015 10:39 PM
Friday Ruined... mbh1101 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 07-20-2013 01:58 PM
How do you know that your day is already ruined? IloveBaldEagles Scion FR-S / Toyota 86 GT86 General Forum 4 12-03-2012 09:58 AM
