Old 06-17-2012, 11:39 PM   #113
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
Sounds like I will be ordering my class magnets tomorrow for next weekend
Bill, if you are in the mood for a trek the GLSS divisional event #2 is in MI next weekend, 2 days at a long, fast, albeit a little broken up, asphalt lot. It's going to be a good time!
Sccabrz192 is offline   Reply With Quote
Old 06-18-2012, 07:57 AM   #114
MTeator
First 86
Good news.
My first attempt at an alignment for the car blew. I made it too lively. I underestimated the front grip I was able to get with the additional front camber. Any mid corner throttle just brought it around.
Gonna throw it back up on the rack today and adjust it again. I think it's going to be an amazing CS car with some development.
Scion First 86 in Lexington KY - Firestorm 6MT - Delivered May 17, 2012
Mods: Motegi 17x7 TrakLites, BFG Rivals, K&N 33-2300 Filter, Nameless Perf. Track Pipe, TRD springs & rear bar, Hotchkis front bar (eh), Kask trailer hitch
MTeator is offline   Reply With Quote
The Following User Says Thank You to MTeator For This Useful Post:
jdrxb9 (06-18-2012)
Old 06-18-2012, 08:13 AM   #115
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Originally Posted by MTeator View Post
Good news.
yep...know the feeling...couldn't put ANY throttle down as it wanted to just spin and spin...:LOL: heres what was suggested to me on Nasioc on my Build Thread..
Originally Posted by solo-x View Post
Are you actually running zero rear toe on a rear drive car? If so, that's probably a LARGE part of your over steer issue. Try an 1/8" total toe in on the rear and put the rear bar back on, see if that fixes your over steer issue.
so I am going to take his adivce...since all I have known is AWD Subies... and see what happens..
Bill
Scooby South is offline   Reply With Quote
The Following User Says Thank You to Scooby South For This Useful Post:
jdrxb9 (06-18-2012)
Old 06-18-2012, 08:25 AM   #116
MTeator
First 86
Bill
I came from an ES MR2 which I had to beg to rotate. I'm thinking the same amount of toe in for the rear and either 0 or slight out for the front.
Old 06-18-2012, 08:37 AM   #117
Scooby South
Conedancer
I ran 0 and 0... the front end was Planted, that is with -2.4 of front camber.. and -.5 on the rear... mine was like a top..
Bill
Old 06-18-2012, 08:42 AM   #118
MTeator
First 86
Bill
I was neutral rear and I think 1/8 out in the front.
I've only got 1.3/1.4 camber in the front (just using the smaller upper bolt) and my rear is messed up (0.3/1.9)
Old 06-18-2012, 10:40 AM   #119
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
When you say smaller upper bolt, do you mean the OEM bolts? I thought they were limited to about .75 on camber
Kido1986 is offline   Reply With Quote
Old 06-18-2012, 10:49 AM   #120
MTeator
First 86
Yes, the OEM bolts. We also loosened the top of the strut. Pushed on it real hard and torqued it all down and that's where we ended up.
Old 06-18-2012, 10:54 AM   #121
Kido1986
Dodging cones
Kido1986's Avatar
Sorry for a dumb question, any safety issues with that? I want to run competitively (eventually) locally in C-stock so as much front camber is possible. I'm still learning as I've only gotten serious about suspension modding in the past year or so on my Mazda and it's on coilovers with camberplates so it's a little easier.
Old 06-18-2012, 11:16 AM   #122
MTeator
First 86
From adjusting it in this manner? No.
Old 06-18-2012, 12:47 PM   #123
jdrxb9
jdrxb9's Avatar
Drives: ND2, formerly BRZ (MT/CBS)
Just a quick post to agree with MT and Bill - the car is easy to get loose. I was feeling it last weekend (6/9-10), but coming from FWD 10+ years ago, I wasn't sure if I was interpreting it correctly. This weekend (6/17), I had a pretty damn good driver take a ride along or two and then a couple fun runs and he agreed the car is loose. My RWD driving still has a LONG way to go, so I don't want to chase setup too much, but I am going to put it back on the rack and dial in some rear toe in and see how that goes before I put on a front bar.
jdrxb9 is offline   Reply With Quote
Old 06-18-2012, 12:50 PM   #124
Scooby South
Conedancer
yeeeep...same with me
Bill
Old 06-18-2012, 01:07 PM   #125
ubersoph
Keep in mind, my frame of reference is autocrossing Miatas (both stock and modified) for the past 3 years. Also my setup was on stock alignment and stock sways, only change was switching tires to Dunlop Star Specs.
That said, I didn't feel like the car was insanely loose. The tail end would step out, but every time it did that I could tell it was happening before it happened, felt similar to an AP2 S2000 suspension setup. I did get faster when I didn't get the car stupidly sideways all over the place, but the car felt controllable and fairly easy to drive.
I'm thinking when I do my alignment, I might keep the F/R Camber bias pretty close to whatever is stock to keep the same kind of behavior at the limit. Also thanks again Bill for hooking me up with the camber bolts
ubersoph is offline   Reply With Quote
Old 06-18-2012, 01:30 PM   #126
MTeator
First 86
it's not, with the stock setup I just wanted "a little more loose" and way the crap overshot it.
Which autocross class? jpdarty7 Tracking / Autocross / HPDE / Drifting 66 06-21-2012 05:53 PM
FORMULA D Round 1 Long Beach 2012 Discussion Thread Kids Heart Off-Topic Lounge [WARNING: NO POLITICS] 0 04-08-2012 02:43 AM
GT5 Stock GT86 Competition - March 2012 Deslock Off-Topic Lounge [WARNING: NO POLITICS] 34 04-01-2012 07:39 AM
2012 Mercedes A-Class Revealed ZetaVI Other Vehicles & General Automotive Discussions 12 03-06-2012 02:15 PM
GT5 Stock GT86 Competition - February 2012 Deslock Scion FR-S / Toyota 86 GT86 General Forum 100 03-01-2012 07:14 AM
