Old 05-01-2016, 03:42 PM   #491
pinetree
pinetree's Avatar
Drives: 2013 BRZ Limited
Hi everyone,
I know these tunes are for the OFH, but a few of us with the JDL UEL headers decided to run this tune and see if it's compatible. I never updated with my logs because I don't have Windows PC, but decided to install it on my mac.
Anyways, here's my recent data zap log running 91 oct (Shell), I know nothing about tunes other than what I've been reading on the forums. Well let me know if it looks good or if I should stick back to the old stage 2 tune. Thanks!!
http://www.datazap.me/u/pinetree/sta...=0&data=3-9-10
pinetree is offline   Reply With Quote
Old 05-01-2016, 05:02 PM   #492
headlikeahole
headlikeahole's Avatar
Drives: Ultramarine toyobaru
Originally Posted by pinetree View Post
Hi everyone,
It's not perfect but it's ok. You're seeing just enough knock to effect the IAM but doesn't seem to be drastic (still running smoother then stock tune on 91). You should really add RPMs to your log and try 2nd and 3rd gear pulls from 2000 to redline.
headlikeahole is offline   Reply With Quote
The Following User Says Thank You to headlikeahole For This Useful Post:
pinetree (05-01-2016)
Old 05-01-2016, 08:26 PM   #493
eSOLOR
eSOLOR's Avatar
Drives: Subaru BRZ
Originally Posted by headlikeahole View Post
Typically this kind of knock will correlate to a combination of a specific engine load and rpm. In the first log you can see that your load at 7000+ was around 1.3. The reason this knock doesn't appear in the other log could be because the loads were slightly lower at those rpm.
If you are consistently seeing FLKC over 1 - 1.5 at those rpm then it might be worth pulling a bit of timing. However unless your at a track day this probably wont be an issue.
So it's okay to use this tune and leave as is? Or is there something I should be adjusting?
eSOLOR is offline   Reply With Quote
Old 05-01-2016, 09:50 PM   #494
headlikeahole
Personally I would do more pulls and see if I could recreate that same knock you saw around 7000 rpm. If it was consistent then I would pull some timing in that area. If you're not comfortable with tuning then I would say just leave it as is. It's not drastic and you're probably not spending much time in that range anyway.
Old 05-01-2016, 10:09 PM   #495
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I just checked out the OFH calibration and it looks to have the same IAT compensation table as factory calibration. The folder says its OFH v1.0. Is this the new one or old one?
Intent > Content
Old 05-01-2016, 10:25 PM   #496
phrosty
Stock starts compensating around I believe 120 degrees, new OFH one starts around 80 degrees.
phrosty is offline   Reply With Quote
Old 05-01-2016, 10:31 PM   #497
solidONE
solidONE's Avatar
Looks the same to me...
Intent > Content
Old 05-01-2016, 10:34 PM   #498
steve99
Drives: FT86
Guys,
They changed the IAT vs ignition timing compensation table not the maf temp compensation table :-)
solidONE (05-01-2016)
Old 05-01-2016, 10:34 PM   #499
phrosty
The correct table is "Timing Compensation (IAT)".
Old 05-01-2016, 10:35 PM   #500
solidONE
solidONE's Avatar
Guys,
Oh... lol
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
steve99 (05-01-2016)
Old 05-04-2016, 08:57 AM   #501
Bzives
How big of a difference is it between the OFT stage 1 93 tune with stock header and the stage 2 93 UEL tune? I'm getting the Header near the end of May and wondering how noticeable its going to be..
Bzives is offline   Reply With Quote
Old 05-04-2016, 11:27 AM   #502
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Night and day. Header is best bang for the buck.
The Following 2 Users Say Thank You to NyC Zn6 For This Useful Post:
Bzives (05-04-2016), DocWalt (05-04-2016)
Old 05-04-2016, 11:32 AM   #503
Noxcyn
Noxcyn's Avatar
Drives: '15 Scion FR-S - Ashphalt (MT)
Plus that sound tho... I drive a lot with no music just listening to the UEL 😍
Noxcyn is offline   Reply With Quote
The Following User Says Thank You to Noxcyn For This Useful Post:
Bzives (05-04-2016)
Old 05-04-2016, 12:16 PM   #504
Dru670
Drives: 2016 Scion FR-S
first of all you will fall inlove with the sound and the power from 1st to 2nd and 3rd oooowweeee (and that's with my cheap 1320 UEL header. Those with big brand name headers probably get power close to turbo with their 600+ dollar headers lol jk)
Dru670 is offline   Reply With Quote
Just how noticeable is OFT+OFH and stage 2 tune? BBYZILA Software Tuning 58 03-20-2018 11:56 AM
OFT 2.0 Stage 1 93 Tune MurderRider Software Tuning 57 03-21-2016 12:30 AM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 08:15 PM
FA20club.com Turnaround Times On Modified Tune Files FR-S Matt Software Tuning 103 11-13-2013 01:48 PM
So whate does stage 3 tune do? I already have 2 Frsexxxy Engine, Exhaust, Transmission 17 05-14-2013 06:30 AM
