Old 04-30-2016, 09:41 PM   #393
Keenercarguy
Mountain Runner
Keenercarguy's Avatar
Drives: 2013 Subaru BRZ Limited 6MT
Originally Posted by cmihaylov View Post
That's the sound mine was having and the dealer replaced the throwout bearing, pressure plates (because they collapsed) and the clutch itself. Definitely get it checked out.No issues since then - 11k miles.
Did they try anything else first? How many miles were on te car when you brought it in? Which warranty was it covered under, powertrain?
2013 BRZ 6MT Limited: "Quick as Hell, on a Budget" Build • Ceramic Coated Gruppe-S UEL/OP • Konig Hypergrams • RS4 200tw • Koni Yellows, Eibach Springs • Ferodo DS2500's
Keenercarguy is offline   Reply With Quote
Old 04-30-2016, 09:42 PM   #394
cmihaylov
They didn't try anything else first...I had to leave for diagnostics for a coue if days and tha's what they came up woth. Car had about 17k miles then.
cmihaylov is offline   Reply With Quote
Old 04-30-2016, 09:44 PM   #395
Keenercarguy
Mountain Runner
They didn't happen to say which warranty it was under did they? I am at 53,000 miles so I only have the power train warranty remaining, I assume it would be covered under that as part of the transmission…?
Old 05-01-2016, 05:26 AM   #396
ZZT86
ZZT86's Avatar
Drives: BR86
Originally Posted by roddy View Post
I didn't have time to read through all 18 pages to see if anyone else has posted this experience, so sorry if it is a re-post. My car is just starting to make this noise after a good drive, and I may have a solution...
Years ago, I had a Civic that did this, and it took me a while to figure it out. I tried to lube the pivot point where the rod from the slave cyl meets the clutch fork, and that would mask the issue for a bit, but it would always come back. Eventually, I flushed out the "clutch fluid" and replaced it with new brake fluid. The noise went away and never came back. A co-worker had this issue with his Civic last year, and I suggested he try the same thing. He did and the noise went away.
I don't know why it works (probably something to do with brake fluid being hygroscopic and absorbing moisture from the air), but it has for me in the past, and I'm betting new fluid will make a difference. For the $5 worth of fluid and a few minutes of your time, it is worth a try before dismissing the idea.
I tried this but unfortunately it hasn't worked for me :/ I'm gunna try the gob of grease on the main pivot as per Ultramaroon & see what happens then.
ZZT86 is offline   Reply With Quote
Old 05-01-2016, 07:51 AM   #397
roddy
roddy's Avatar
Drives: '13 Ultramarine
Thanks for posting back...it was worth a try. Mine is squeak free for the time being. Probably a good idea to change the fluid every couple of years anyway. Let us know if lubing the pivot point takes care of it for you.
Old 05-01-2016, 10:28 PM   #398
ZZT86
ZZT86's Avatar
Drives: BR86
@roddy - no worries pal, it's definitely worth trying & besides I'm not of the dealers opinion the clutch fluid needn't ever be changed !
Old 05-02-2016, 12:21 AM   #399
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
@Pat.Thornton
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
FRSek (06-07-2016)
Old 05-06-2016, 03:44 PM   #400
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
I've had this problem for at least 2 years now(started around 40K), up now at 72k. It will slightly resurface its ugly head here and there but mostly I just feel the grittiness of the clutch pedal.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 05-07-2016, 01:04 PM   #401
Joshuarers
Drives: Man
Send a message via ICQ to Joshuarers
Clutch peddle loud squeak
Cable would be my first guess, it may have stretched a bit or something. Can you start it in gear with your foot on the clutch?
Joshuarers is offline   Reply With Quote
Old 05-07-2016, 01:49 PM   #402
Welcome to the forum. Terrible guess.
brianhj (05-15-2016), Mr Nerd (05-11-2016), nickmerronesucks (05-11-2016)
Old 05-30-2016, 12:00 PM   #403
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Using Google translate, it seems this article might be relevant: "Clutch release bearing abnormal noise".
http://ameblo.jp/zn6-86-fa20/entry-12164068390.html
https://translate.google.com/transla...-text=&act=url
Guillaume is offline   Reply With Quote
The Following 2 Users Say Thank You to Guillaume For This Useful Post:
JB86'd (06-07-2016), Sigh-on-Rice (05-31-2016)
Old 05-31-2016, 06:52 AM   #404
ZZT86
ZZT86's Avatar
Drives: BR86
This is interesting - will have to try this out.
Old 05-31-2016, 10:52 AM   #405
Tt3Sheppard
Didn't realize you can remove that metal part of the transmission.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
Old 06-11-2016, 10:52 PM   #406
heatherger
Drives: 2013 FRS
Hey everyone,
Just wanted to give my success story on this.
My clutch began squeaking maybe 5,000 miles ago. I now have 41,000 on my car. It was quiet, but then ended up being super loud, just like in the video of the original poster and probably what most of you are experiencing. Took my car in and explained how others were having the same issue as myself. They seemed to be a little hesitant at first, as the sound somehow stopped squeaking after we dropped it off. We mentioned the clutch fork and throw out bearing, etc. Ended up having the transmission replaced under warranty. My car was in the shop for less than a week. I have the paper with everything replaced on it. Squeak is gone, and my clutch feels like new. Only thing I paid for was the clutch plate, but I didn't have an issue as I saw their receipt after everything was said and done. :0
I went in the dealership expecting to be told it was "normal" but I am very pleased with everyone there.
If anyone has any questions, message me and hopefully I can help. This is pretty much my second post here as I have been lurking around hehe.
heatherger is offline   Reply With Quote
Loud 'Squeak' Noise From Clutch? Brndn704 Issues | Warranty | Recalls / TSB 23 07-20-2020 08:58 AM
Upgraded Clutch Squeak Rybot Issues | Warranty | Recalls / TSB 116 10-09-2019 02:10 PM
Clutch pedal adjustment gone wrong? Clutch issues. PulpBrah Engine, Exhaust, Transmission 12 03-06-2017 04:08 PM
Clutch Squeak CatDaddysBBQ Issues | Warranty | Recalls / TSB 4 07-14-2015 06:44 AM
Clutch pedal squeak. merino_frs Engine, Exhaust, Transmission 1 08-25-2014 01:00 AM
