Old 04-30-2016, 12:10 PM   #7127
Jeremiahlee34
Drives: FRS innovate supercharged
Originally Posted by Rifle View Post
You'll need an oversided pulley. You can push maybe 2 more psi than the 210 on stock internals (safely), and that's about 14psi.. You can always try turning it up until it pops, I guess. Or just build the motor before you do anything, then upgrade. Because even @smudge blew a hole in his block with the 335.. and his car was built. Admittedly, he had a faulty part.. but still. The 335 is a beast!
Thank you for the info. Ugh I really wanted to get the upgrade too. But DEFINITELY do not want to blow the motor.
So I have two follow up questions.
1: if I pumped the same 12 psi as I have with the 69mm on the 210, would there be any gains with the 335, tq, heat soat, peak numbers at lower rpm, ect?
2: if I did build out the motor, what parts would blow first, I.e what should be replaced to handle say 375whp.
I just know there are a million option and I could waste a crap ton of money. Lol.
Again thank you for the info.
Jeremiahlee34 is offline   Reply With Quote
Old 04-30-2016, 12:57 PM   #7128
walletsr
Drives: 2014
You would need rods those are the weak part of the engine. Those break at low rpms due the torque. Before you even get that far as I said you would need new clutxh, injectors, pump and run e85. If you don't have e85 you would need to lower compression ao you could run pump gas. Cheapest price for built block is 3k with your block being built or 5k with a new block
walletsr is offline   Reply With Quote
Old 04-30-2016, 02:17 PM   #7129
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
Probably less heat soak if still 12psi on the 335.
260whp / 210tq with 12psi on 93 with the 210.
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
Old 04-30-2016, 03:02 PM   #7130
Chrisbrz14
Chrisbrz14's Avatar
Drives: Subaru Brz
What do you guys think about the oil around the plastic barb?
Chrisbrz14 is offline   Reply With Quote
Old 04-30-2016, 05:16 PM   #7131
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
You might have the wrong hose on that vacuum port. I THINK brake booster goes there, although I'd have to check. Otherwise, you're just condensing crank case gasses right there. Consider an oil catch can. You can do your own for about $30. I just did a couple weeks ago.
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 04-30-2016, 05:32 PM   #7132
Chrisbrz14
Chrisbrz14's Avatar
Drives: Subaru Brz
Yeah I'm ordering a radium can tonight, it's been hooked up like that for 16,000 miles so I'm hoping I had it right lol.
Old 04-30-2016, 05:37 PM   #7133
riboyster
riboyster's Avatar
Haha yeah as long as it runs well at idle you should be okay. And yeah, I'm not surprised with the leakage after 16k miles. If it was less than 1 thousand, then something would be up for sure.
The low pressure crank case vent is ALWAYS pumping out smelly vapor. I'm venting to atmosphere so it's something I've been working on for a while now.
Old 04-30-2016, 10:57 PM   #7134
walletsr
Drives: 2014
If no one wants to trade for my 335 I may just have to put it back on with a bigger pulley.
Old 05-01-2016, 01:07 AM   #7135
Rifle
Rifle's Avatar
That's the EGR relocated hose. Twist the barb so it's facing the firewall tight. Also, add a hose clamp.. just did it today.
Sidenote!
Finally fixed my airlocked intercooler issue. Drained the whole system, removed the heat exchanger, back pressured the whole system, fixed 2 small leaks, refilled the system, burped the system (which took a stupid long time), and it seems to have fixed my timing concern, and is no longer pulling timing underload, infact, it's ADDING timing! yaaaay!
295WHP/220TQ
The Following 3 Users Say Thank You to Rifle For This Useful Post:
Chrisbrz14 (05-01-2016), CK_Bladesmith (05-01-2016), riboyster (05-01-2016)
Old 05-01-2016, 04:16 PM   #7136
chargedup
Drives: SC BRZ
Hey guys, noticed one of my pullys was loose today..tried to tighten but it was already tight, just out of balance? what's the solution here?
chargedup is offline   Reply With Quote
Old 05-01-2016, 04:42 PM   #7137
Chrisbrz14
Chrisbrz14's Avatar
Drives: Subaru Brz
You mean your tensioner pulley?
The Following User Says Thank You to Chrisbrz14 For This Useful Post:
chargedup (05-01-2016)
Old 05-01-2016, 04:47 PM   #7138
chargedup
Drives: SC BRZ
Right
Might add that I bought the car with the sprintex kit and completely new to the 86 so have no idea what's going on.
Old 05-01-2016, 04:55 PM   #7139
tegunulgener
tegunulgener's Avatar
Drives: Dark Side
It should be like that, it's a tensioner
Sent from my HTC One M9 using Tapatalk
tegunulgener is offline   Reply With Quote
The Following User Says Thank You to tegunulgener For This Useful Post:
Old 05-04-2016, 01:51 AM   #7140
Rifle
Rifle's Avatar
Make sure you upgrade the hoses to higher vacuum lines. Stock Radium lines hold 30psi vacuum and collapse under load of the 210. I replaced with 250psi 8AN race hose. Like $16 for 10 feet.
295WHP/220TQ
The Following User Says Thank You to Rifle For This Useful Post:
stockysnail (05-04-2016)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
