Old 04-29-2016, 12:27 PM   #491
steve99
Drives: FT86
Originally Posted by Dru670 View Post
Ah okay thanks. Is there anything else that must be done after scaling the MAF? Also, if I wanted to rescale the MAF again do I load the previous ots rom and log my drive and scale maf or do I use the current rom with the newly scaled MAF and log and adjust that one? Sorry just not sure because one instruction says to log tons and tons of data and repeat while another says just do 15 min normal and 10 highway 2-3 WOT and done.
You never usually get it correct the first time, usually takes three or so goes.
15min city 10 HI way and 3 wot runs is fine.
yes once you have updated maf scale use that for next runs, unless it produced really crap results.
Old 04-29-2016, 12:58 PM   #492
Ondreiko
RWD addicted
Ondreiko's Avatar
Drives: BRZ 6MT OFT OFH
Hi!
My opinion (as i did MAF scaling several times) is that you need log file for approx 30 min drive (or OFT logs only for 20 minutes? but it is sufficient anyway) preferably including 3-4 WOT pulls and then you scale your MAF loading your logs and appropraite tables of the ROM you drove into VGI tool, which works perfectly if you set everything properly. Then after 60 miles driving you make another log and do scaling again. Every time for scaling you use ROM which you drove for particular log. And i suggest you stop when you feel that your last version drives worse or not better than the previous one, and you use that previous version of the ROM then for any further tuning needs such load limits tables, what i am trying to learn with guru guys here now. and then i suggest you can look at the other parts of VGI tool, where some other useful things can be scaled or tuned so you can try em on.
Ondreiko is offline   Reply With Quote
Old 04-29-2016, 05:31 PM   #493
Dru670
Drives: 2016 Scion FR-S
Originally Posted by Ondreiko View Post
Hi!
Thanks will try that. BTW I live in Vegas and its starting to get warm...I read its best to log around 20-25c (68-77f) and we are soon to be hitting 80-90F am I still able to scale around those temps?
Dru670 is offline   Reply With Quote
Old 04-29-2016, 06:22 PM   #494
freerunner
freerunner's Avatar
Drives: GT86
Calibration is still possible. An advantage of a perfect calibration at 20°C ambient temp is the possibility to calibrate the temperature compensation tables later on.
freerunner is offline   Reply With Quote
Old 04-29-2016, 06:38 PM   #495
Dru670
I read somewhere if I remember correctly that LTFT can only be positive if IAM is 1?... I notice I'm at .52 IAM and LTFT is at around 3.90% is this bad?
Old 04-29-2016, 07:31 PM   #496
freerunner
freerunner's Avatar
Drives: GT86
FLKC can be positive if IAM is less than 1.
Old 04-29-2016, 11:26 PM   #497
Dru670
Do I have to reset and have IAM at 1 before I start doing some data logging for mad scaling?
Old 04-30-2016, 12:15 AM   #498
JB86'd
JB86'd's Avatar
Drives: JAWS
No. Now if you were adjusting timing and trying to tune out knock, the answer is yes.
JB86'd is offline   Reply With Quote
Old 04-30-2016, 12:49 AM   #499
Dru670
Can I make multiple logs say for closed loop 30min regular driving do a 20min and 10min log and combine the two or do I have to do 1 continuous 30min log?
Old 04-30-2016, 04:08 AM   #500
Kodename47
Kodename47's Avatar
Drives: UK GT86
Yes, you can use multiple log files. The tool does this for you as well.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-30-2016, 03:02 PM   #501
Ondreiko
RWD addicted
Ondreiko's Avatar
it is bad when you get IAM less 1 meaning your engine is knoking as you have either bad fuel or too lean mixture of wrong ignition timing as i assume.
Old 04-30-2016, 03:14 PM   #502
Ondreiko
RWD addicted
Ondreiko's Avatar
http://datazap.me/u/ondreiko/3004-wo...3-6-11&mark=13
Guys, here s my last log.
Picture is better with engine load limit 1.07 at 3800 rpm cell.
Please kindly comment if my intention to decrease (still cant load example picture but im trying anyway) some cells in MAF scaling table at 3.44V and some higher places is right in order to flatten the curves and dig out some more power probably.
And do i need to tweak engine load limits any further for the same purpose?
Thank you again,
Old 04-30-2016, 07:17 PM   #503
freerunner
freerunner's Avatar
Drives: GT86
Hey, looks good
I would not bother fiddling around with load limits any more.
Decrease value at 3.44V and call it a day.
Old 05-01-2016, 05:02 PM   #504
Ondreiko
RWD addicted
Ondreiko's Avatar
another log file
Guys, am i finished sclaing MAF and load limits?
http://datazap.me/u/ondreiko/v10010-...6-10-11&mark=8
I am going to scale IAT comp table now, can i start now or should i roll back to tune where my FLKC is 0 throughout the whole log?
AFR in Closed Loop Toyota John Software Tuning 39 07-07-2019 08:26 AM
BRZedit Fuel Trims, Closed to Open loop transiton mad_sb Engine, Exhaust, Transmission 32 08-06-2015 03:14 AM
Notes on injector / maf scalining using full time open loop mad_sb Software Tuning 40 03-03-2014 05:49 PM
Screencast: closed loop boost control with RaceRom jamesm Software Tuning 2 02-10-2014 02:23 PM
Screencast: experimenting with full-time closed loop fueling jamesm Software Tuning 2 12-27-2013 10:19 AM
