#3781 |
Drives: 2023 BRZ
It looks like you're seeing some of the same things I experienced. Check out my other post here.
I would align the car with the camber plates in the middle setting to be halfway between what you want on the street and what you want on the track. You may want to build in a little headroom for more camber than what you think you'll need at the track. Maybe max around 3.7, give or take a couple tenths. Also, check out this post and this post. Align your cars with the camber bolts. Then, understand what the settings are for each mark on your camber plates so you can adjust them as needed at the track. This will likely require knowing how much each mark of adjustment on the camber plate indicates. |
| The Following User Says Thank You to Pat For This Useful Post: | ZionsWrath (04-29-2016) |
#3782 |
Thanks
Don't need a street setting as right now I don't drive it on the street enough to matter. And when I do it's is either to the track or driving for fun. But I think I should get a pyrometer and test different notches on the plates per those posts.
#3783 | |
Drives: Fr-s
#3784 |
Shibby!
Drives: '14 White FR-S, '01 turbo mini taco
Same for my PMU CR's... crumbling on outside edges of pad. Is it only when chunks start in the middle of the pad that it is considered compromised and needs replacement?
#3785 | |
Drives: '22 BRZ
#3786 | |
#3787 |
Drives: Subaru BRZ
Are you always supposed to left foot brake during turns that doesn't require a downshift?
#3788 |
Drives: Velocity Orange 86 GT
Thats preferance. Knowing how to left foot brake can be beneficial but isn't 100% required.
#3789 |
You can brake however you want, as long as you get the required braking done. Some people predominantly left foot brake, while others don't. Those that come from karting backgrounds left foot brake a lot.
#3790 |
driving smoother faster
Drives: Sold
Apparently my Front-Right and Rear-Left Whiteline sway bar links (end links) are getting a little worn though not compromised yet...after two full track seasons. Not concerned and looking to refresh - what should I replace them with? Hoping for answers from hard core track junkies, like @CSG Mike, @Racecomp Engineering, etc.
I am also contemplating http://racerxfabrication.com/frs-brz...nsion/full-kit, if anyone has had experience. 20+ track days/year. Thanks |
| The Following User Says Thank You to dp1 For This Useful Post: | CxG (05-02-2016) |
#3791 |
Thanks
Recommend a fire extinguisher and mount?
If I want to run with PCA this year I am required to have one.
#3792 |
Not sure on the Regulations but usually a 1kg version will fit. Just make sure it has expiry dates on it so that they can check that and fits into the right standards. I made a bracket for the Centre Console. It's pretty easy with a piece of plate or two. Mine was a little over-engineered with a 10mm Piece of Alluminium and milled sections for weight savings/I was bored.
| The Following User Says Thank You to Northwest86 For This Useful Post: | ZionsWrath (05-03-2016) |
#3793 | |
Thanks
Prefer just something I can buy. I have no fabrication equipment or experience.
Also I drive to my events I like my cup holder ^_^ If it is easy to bolt on and off sure but if I have to remove the center to reach the back side I'd rather not. The regulation is Quote:
![]() Last edited by ZionsWrath; 05-03-2016 at 08:47 AM. |
| The Following User Says Thank You to ZionsWrath For This Useful Post: | CxG (05-03-2016) |
#3794 | |
Drives: Sold
I received a friendly PM yesterday and I ordered new Whiteline links. They worked well for me and they are a "wear and tear item" so I don't mind replacing them every couple of years as needed. Thx |
| The Following User Says Thank You to dp1 For This Useful Post: | CSG Mike (05-03-2016) |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 09:54 AM |
