Old 04-28-2016, 03:55 PM   #1
Riftur
Riftur's Avatar
Weird Issue u0100 u0122
I just did my first tune using OFT 3 days ago. Everything seemed fine but I decided to check fault codes and I had a u0100 and u0122 through the torque app (no CEL ever came on or anything other warning light). I am using a bluetooth adapter for the torque app. I tried clearing the codes but they come right back. Once I got home from work and hooked up my OFT it did not find any codes. i switched back to the bluetooth adapter and torque and it found the codes again but OFT does not see them still. I dont understand whats going on. I never had any fault codes in torque until I did my first tune. Any idea?
Riftur is offline   Reply With Quote
Old 04-28-2016, 04:48 PM   #2
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
From what i can find those codes are triggered whenever the car loses communication with the ECM(u0100) or other systems(u0122: possibly vehicle dynamics control?). As long as the car is operating ok you should be fine. Make sure you are continuing to log to see if anything is out of whack.
I know every time I flash a different tune I get a p0700 which signals that it lost communication with the TCU but as soon as I clear it it does not come back until I flash a different tune.
I use the OFT for flashing and logging so i have not checked with torque to see if I get those u codes as well but in my unprofessional opinion that code was generated due to the split second the car loses communication with whatever system during a flash.
EDIT: Doing a bit more digging and came across this http://www.obd-codes.com/u0100
It does seem to go towards the worst possible scenario but it did say the u0100 would probably have a CEL with it
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
The Following User Says Thank You to Tectoniic For This Useful Post:
Riftur (04-28-2016)
Old 04-28-2016, 04:53 PM   #3
Riftur
Riftur's Avatar
Last night I used Carista to turn off the seat belt beep and day time running head lights and a couple other settings. I wonder if one of those settings I changed could be causing this. I only changed options like those so i really don't think so.
Old 04-28-2016, 04:55 PM   #4
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
Yeah, I wouldn't think those would have anything to do with it but I haven't messed with carista at all
Old 04-28-2016, 05:12 PM   #5
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
I use carista all the time and ran the beta for some time, no issues and no canbus codes like you're getting. Do you leave the adapter in all the time?
Old 04-28-2016, 05:30 PM   #6
Riftur
Riftur's Avatar
Yes cause I monitor the car with torque most of the time.
Old 04-28-2016, 05:48 PM   #7
FRSBRZGT86FAN
That explains the U0 errors, I got the same along with some sort of startability error P1604 once with a bluetooth dongle OBD2, alot of them do that.
Old 04-28-2016, 06:19 PM   #8
Riftur
Riftur's Avatar
That's the first time it's happened and I have been using torque like this for months now. I am very glad you had this issue. I was about to flash back to stock and see if it fixed it but the car runs much better since I tuned it. Lol
Old 04-28-2016, 06:37 PM   #9
FRSBRZGT86FAN
The more expensive OBD-II dongles don't do that I believe otherwise this wouldn't be a widespread issue, is your a mini one?
Old 04-28-2016, 07:01 PM   #10
Riftur
Riftur's Avatar
mini and cheap lol
Old 04-28-2016, 07:08 PM   #11
FRSBRZGT86FAN
mini and cheap lol
That explains it , the BAFX one I have doesn't do that
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Riftur (04-28-2016)
Old 04-28-2016, 07:45 PM   #12
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
P0700 isn't from flashing, it's from connecting a device to canbus while it's not fully powered down.
The Following User Says Thank You to Wayno For This Useful Post:
Tectoniic (04-28-2016)
Old 04-28-2016, 07:55 PM   #13
Riftur
Riftur's Avatar
I assume one of these. Hope its not the second one.
[ame="http://www.amazon.com/BAFX-Products-34t5-Bluetooth-Android/dp/B005NLQAHS/ref=sr_1_1?ie=UTF8&qid=1461887769&sr=8-1&keywords=BAFX+obd2"]Amazon.com: BAFX Products 34t5 Bluetooth OBDII Scan Tool for Android Devices: Automotive[/ame]
or
[ame="http://www.amazon.com/Bluetooth-Products-PIC18F2480-Check-Engine/dp/B01BX3PW9G/ref=sr_1_4?ie=UTF8&qid=1461887769&sr=8-4&keywords=BAFX+obd2"]Amazon.com: Bluetooth OBD2 Scan Tool by BAFX Products, PIC18F2480, For Check Engine Light: Automotive[/ame]
Old 04-28-2016, 08:33 PM   #14
FRSBRZGT86FAN
It's totally the first one:
I had the first one after I bought one of the mini units off eBay for super cheap. The mini ones tend to cause these U0 issues as I said before also one morning I got a P1604 although the car has not once missed a beat on start up. After getting and using the BAFX one I had 0 issues with erroneous codes.
Weird hot start issue mike the snake Software Tuning 21 01-18-2021 07:03 PM
Weird OFT issue omfg5041 Software Tuning 2 12-05-2016 11:53 AM
Weird issue with my 13' Subaru BRZ Dico Issues | Warranty | Recalls / TSB 11 02-08-2016 10:37 AM
Weird issue with oft not reading cel fenton Software Tuning 7 09-14-2014 12:26 PM
weird issue after BPB & OFT install DAN_BRZ Engine, Exhaust, Transmission 10 06-10-2014 09:53 PM
