Old 04-28-2016, 11:21 AM   #29
mdm
not a twin owner
mdm's Avatar
Drives: 2016 Veloster Turbo DCT
Originally Posted by Zyo81 View Post
(6.2 miles takes about 35-40 minutes) I get 22 mpg.
~10 mph average speed, probably stop-and-go most of the time... that explains the mpg
mdm is offline   Reply With Quote
Old 04-28-2016, 11:26 AM   #30
mdm
not a twin owner
mdm's Avatar
The interesting part is that the trend line has risen over time.
Is this over ~2.5 years? I think I see a periodicity. Might be clearer if you added moving average over 8 or 10 data points.
If I am right, the trend itself may be spurious, showing up only because you started driving in one of low-mpg periods (winters?) and now you are in summer high-mpg period.
Old 04-28-2016, 12:42 PM   #31
extrashaky
Drives: 2014 BRZ Limited
Originally Posted by RichardsFRS View Post
These cars are said to get 34mpg, yet I've seen no one get 34mpg.
I got 36 on one trip where I was on long, straight back roads with a 55 mph limit and no other traffic but cops. I put the cruise on 60 and took a nap.
I can set the cruise at 75mph and do my 2 hour each way commute without even touching a pedal for 1 hour and 50 minutes so pretty tough to get better mileage for me.
You'll get better mileage if you slow down to 60 and take a nap.
Old 04-28-2016, 12:45 PM   #32
I slow down to 60 on that stretch of highway and I am going to have a truck go right over me!
And where did I say I didn't already nap?
Old 04-28-2016, 12:47 PM   #33
Vyconis
Vyconis's Avatar
Drives: 2015 Hot Lava FR-S
Gas Mileage
I usually get over 320 miles a tank ( corrected from gallon )depending on my driving. Spirited driving will never get great gas milage. Driving Ms. Daisy slow cruising will get you better gas mileage.
2015 Scion FR-S - 6 speed manual
tC RS 2.0 #0664 - 5 speed manual (Given to my father)
Canon Rebel T2i DSLR
Vyconis is offline   Reply With Quote
Old 04-28-2016, 12:58 PM   #34
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
100% city driving. I get 18-22 MPG. It is what it is.
jawn is offline   Reply With Quote
Old 04-28-2016, 12:59 PM   #35
mdm
not a twin owner
mdm's Avatar
Originally Posted by Vyconis View Post
I usually get over 320 miles a gallon
I presume you accidentally dropped the decimal point. Be careful, once nuclear war almost started because of a similar mistake.
Old 04-28-2016, 01:01 PM   #36
I usually get over 320 miles a gallon depending on my driving. Spirited driving will never get great gas milage. Driving Ms. Daisy slow cruising will get you better gas mileage.
The car manufacturers want to talk to you!
mdm (04-28-2016)
Old 04-28-2016, 01:27 PM   #37
Close to 4 years. Here it is averaged by month. It does have a seasonal pattern to it, but does appear to go up over time. The dips and peaks I can explain, and look more drastic than they are because of the axis limits.
BTW, I have posted each tank in my owner's journal OP.
mdm (04-28-2016)
Old 04-28-2016, 01:45 PM   #38
extrashaky
Pretty sure he meant per tank.
But that doesn't really tell us anything, since there's a 2.4 gallon reserve. If he runs the tank down close to empty, that's 25.6 MPG. If he stops immediately once the light comes on, that's 31.7 MPG. Saying "I get X mileage per tank" is almost as meaningless as comparing insurance rates.
The Following 2 Users Say Thank You to extrashaky For This Useful Post:
mdm (04-28-2016), Tcoat (04-28-2016)
Old 04-28-2016, 02:20 PM   #39
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
...and it seems many folks never learned how to calculate miles-per-gallon.
billwot is offline   Reply With Quote
Old 04-28-2016, 02:27 PM   #40
billwot
those arent very accurate really. gotta calc miles traveled and gallos filled. But yeah that cheap I wouldnt worry either
I calculate miles-per-gallon at every fill-up. It generally reads about 1 mpg higher than actual.
My indicated MPG ranges from 31.5-34.5. Calculated is 30-33.5
The Following User Says Thank You to billwot For This Useful Post:
finch1750 (04-28-2016)
Old 04-28-2016, 02:29 PM   #41
aslanteye
aslanteye's Avatar
Drives: 2014 base frs
Originally Posted by FRSBRZGT86FAN View Post
The manual has a sport mode!? I think you're confusing it with VSC sport
The VSC Sport mode isn't a sport mode?
Sent from my SM-N910T using Tapatalk
aslanteye is offline   Reply With Quote
Old 04-28-2016, 02:30 PM   #42
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
how many miles are you at now?
Gas mileage? Otterbrawten Northwest 28 04-27-2016 10:07 PM
400+whp Mileage Reaper Engine, Exhaust, Transmission 28 02-02-2016 01:59 PM
Gas Mileage AVodka14 Issues | Warranty | Recalls / TSB 32 03-03-2014 10:34 PM
Gas Mileage frosty86 Hawaii 12 10-09-2012 04:56 AM
How much mileage do you have on your car now? iff2mastamatt Other Vehicles & General Automotive Discussions 82 01-11-2012 01:48 AM
