Old 04-28-2016, 04:10 AM   #15
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by aslanteye View Post
I'm supercharged and I leave it in sport mode with a manual transmission. I'm getting about 230 ish miles for about 10 or so gallons. Mostly city driving. If I'm on the highway it's above 30 miles per gallon
Sent from my SM-N910T using Tapatalk
The manual has a sport mode!? I think you're confusing it with VSC sport
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
mdm (04-28-2016)
Old 04-28-2016, 05:44 AM   #16
Hotrodheart
Hotrodheart's Avatar
Originally Posted by Haseebali31 View Post
I have filled my tank up to the brim maybe 5 times now and I have noticed that I only get 230 miles to the tank before the gas light comes on. I am guessing its because I'm not shifting at a low enough RPM? Or because I don't use 6th gear when driving 45 mph.
So... few questions for you experts out there.
When should I shift gears for maximum MPG?
and
Can I use 6th gear on normal(service) roads?
Well, if you want better MPG's... pretty much do the opposite of what you are doing now.
On a serious note, for any given level of acceleration, higher gear/more throttle is more efficient than high revs/less throttle.
Unless you run it on maple syrup like @Tcoat
Hotrodheart is offline   Reply With Quote
The Following User Says Thank You to Hotrodheart For This Useful Post:
Tcoat (04-28-2016)
Old 04-28-2016, 06:25 AM   #17
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
I hope when Toyota releases the 86s they don't grossly over hype their mpg. These cars are said to get 34mpg, yet I've seen no one get 34mpg. Mustang Camaro, Corvette all get better than that or about the same as these cars with a V8
Back from bancation in Banopolis where I laid on the beach with a beer between my legs. I at night and ate at sun rise
RichardsFRS is offline   Reply With Quote
Old 04-28-2016, 06:31 AM   #18
I get 36!
I am also at constant speed on the highway 98% of my time.
Drive it at the recommended shift points and stay off the gas and you can get the listed mileage. Drive it with any fun and you won't. The same applies for the listed values on the V8s if you lay on that pedal a lot.
86kahl (04-29-2016), FRSBRZGT86FAN (04-28-2016)
Old 04-28-2016, 06:44 AM   #19
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
I get around 26 MPG city, that's with a 8 mile commute to work never going over 60. If I travel the interstate to work for a 28 mile commute where I cruise @ 80 I get 29ish MPG.
Trueweltall is offline   Reply With Quote
Old 04-28-2016, 07:00 AM   #20
Zyo81
Drives: '13 Firestorm FR-S, 99 Mustang GT
If I strictly work commute (6.2 miles takes about 35-40 minutes) I get 22 mpg.
Mix of work and everything else is about 26 mpg.
If I get past the beltway and get on real highways on a major road trip I get 35mpg.
I drive however I want, but typically in traffic it's 20-50 percent throttle shifting between 4 and 5k, cruising between 2900 and 3400 rpm.
The first two numbers match up with a 98 integra gsr I had. But with the 6th gear in the fr-s the highway is way better, I think I got 28 highway in the gsr, sometimes even less. Cruising hundreds of miles in VTEC yo doesn't get good gas mileage, who would have thought?
Zyo81 is offline   Reply With Quote
The Following User Says Thank You to Zyo81 For This Useful Post:
Tcoat (04-28-2016)
Old 04-28-2016, 07:37 AM   #21
Cruise control at 50 mph in 3rd gear at 4k+ rpm with no interruptions will get better fuel economy than bumper to bumper stop and go city/commute traffic with you short shifting never revving past 2k rpm under 25 mph.
Your driving conditions are the most important factor in your fuel economy.
I have literally experienced a 12 mpg tank back to back with a 30 mpg tank.
Edit: Tips, I keep the engine above 2k rpms typically, you can safely run it between 1.5k-2k rpm without issue if you don't try to accelerate out of it by putting your foot to the floor (downshift instead). I usually go to 3rd at 25 mph, 4th at 30mph, 5th at 35, 6th at 45 and I get high to mid 20's in commute traffic both city streets and freeway.
http://www.fuelly.com/car/scion/fr-s...7974/fuelchart
I can actually pinpoint changes in my life and to the car in this graph such as moving cities to reduce commute, girlfriend moving in, changing away from the Michelins to stickier Dunlops, track days, etc.
Need to get me a Fuelly account and see how flat a line I can create! You will be able to see weekends very clearly I am sure!
FRSBRZGT86FAN (04-28-2016), strat61caster (04-28-2016)
Old 04-28-2016, 08:11 AM   #22
If I zoom out enough mine is flat (below is my fuel mileage since purchased (@80,000miles).
The interesting part is that the trend line has risen over time.
Bristecom (04-28-2016), Tcoat (04-28-2016)
Old 04-28-2016, 08:26 AM   #23
Mim
Mim's Avatar
Drives: MY11 Maxima 350st, MY15 BRZ
19.8MPG in the AT. Treat every tank like its your last I say.
MY15 CWP A/T BRZ | Leather heated seats | STI CAI filter, A/T leather shifter, strut brace, V-brace, draw stiffener, battery tie down, Radiator cap, Oil cap, push start button | TRD door stabilizer | YoSpeed STI console garnish | Pioneer AVIC-F70DAB + Rev-camera, TS-WX710A sub | JL speakers, Amp | TOMS' Clear Brake Lights | Cusco 4.556 FD | Driveshaft Shop aluminum shaft | Tein FlexZ, EDFC AP+GPS | Crawford BPB
Mim is offline   Reply With Quote
The Following 2 Users Say Thank You to Mim For This Useful Post:
86kahl (04-29-2016), Tcoat (04-28-2016)
Old 04-28-2016, 09:30 AM   #24
Guru Woodman
Guru Woodman's Avatar
Drives: 2015 BRZ Sport Tech CWP
I consistently get 33 mpg. The car is stock, I don't baby it nor do I hoon.
Guru Woodman is offline   Reply With Quote
The Following User Says Thank You to Guru Woodman For This Useful Post:
Dadhawk (04-28-2016)
Old 04-28-2016, 09:52 AM   #25
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
The in dash average mpg tells me I'm getting 26.3 with mostly stop and go commuting but I have not reset that thing in forever or done the E85 corrections. With E85 at $1.85 a gallon I'm not too worried about MPG
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
Old 04-28-2016, 10:21 AM   #26
RichardsFRS
Only 27 to 29 here
Disclaimer in 86s brochure. Drive it with some common sense. LOL
Well my wife could also manage 27 out of the GT where I only got 19 or so
The Following User Says Thank You to RichardsFRS For This Useful Post:
Tcoat (04-28-2016)
Old 04-28-2016, 10:27 AM   #27
Only 27 to 29 here
I can set the cruise at 75mph and do my 2 hour each way commute without even touching a pedal for 1 hour and 50 minutes so pretty tough to get better mileage for me.
Old 04-28-2016, 11:17 AM   #28
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
those arent very accurate really. gotta calc miles traveled and gallos filled. But yeah that cheap I wouldnt worry either
Gas mileage? Otterbrawten Northwest 28 04-27-2016 10:07 PM
400+whp Mileage Reaper Engine, Exhaust, Transmission 28 02-02-2016 01:59 PM
Gas Mileage AVodka14 Issues | Warranty | Recalls / TSB 32 03-03-2014 10:34 PM
Gas Mileage frosty86 Hawaii 12 10-09-2012 04:56 AM
How much mileage do you have on your car now? iff2mastamatt Other Vehicles & General Automotive Discussions 82 01-11-2012 01:48 AM
