Old 04-26-2016, 09:54 PM   #7085
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
Originally Posted by camelflage View Post
Yes, 210 non intercooled. I stopped by mach v and talked to Dan, he's been running a 210 in traffic around here, with the stock headers, for about 15k miles or so with no issues. I think he's around 215hp.
I don't track the car, just daily about 20 miles / 45 minutes each way, not too long in stop and go. I decided against more power because I want to not worry about it. If I up the boost I'm going to want to build the motor to make it extra reliable and then I'm getting into new clutch, full exhaust, and on and on replacing every part I think might be a weak point with higher power levels. At that point it's smarter for me to sell the car and go get a used m3.
The cat issue is interesting, as I wouldn't expect the addition of a Supercharger to spike the egt enough to burn out the cats. Dan is dyno tuning mine after the install, so maybe some of the canned tunes are running on the rich side to be safe and fouling the cats in the process.
Sent from my HTC6500LVW using Tapatalk
You don't need to do any motor building with the 210, even at the most boost it can push.
I'm running the smallest pulley available for the 210, which is 69mm. It overspins the blower at 6900rpm, and created 12psi. It only makes 260whp. Clutch begins to let out 3-350whp, and I currently have a buddy pushing 441whp on stock internals..
The 210 is notorious for heat soak, especially since it sounds like most of your driving is stop/go traffic, per say. Once it heat soaks, you're gonna have no power, which is why I'm curious you went non-intercooled. Hell, even with the intercooler version, I still get the notorious heat soak issue.
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
Old 04-26-2016, 10:17 PM   #7086
camelflage
Drives: pinto power
Well that's actually good to know, that if I want to play with the setup down the road I'm not going to be pushing things to their limit.
I guess I'll just see what happens with the heat soak and if I need an intercooler I'll get one.
camelflage is offline   Reply With Quote
Old 04-26-2016, 10:35 PM   #7087
SpeedWi
SpeedWi's Avatar
Drives: 2014 BRZ (SOLD)
You will want more. I promise. You will get use to it and for a couple hundred dollars more you can get more hp. Then it will happen again until you reach running the 69mm on E85. That's when the next chunk of change comes. Some make the jump while others keep going back and forth about making the jump. a larger blower or turbo hmm. Then boom a 30k car is now in corvette price range.
Supercharged 2014 DGM Limited
SpeedWi is offline   Reply With Quote
The Following 3 Users Say Thank You to SpeedWi For This Useful Post:
CK_Bladesmith (04-27-2016), riboyster (04-27-2016), Rifle (04-26-2016)
Old 04-26-2016, 10:38 PM   #7088
Rifle
Rifle's Avatar
+1.
295WHP/220TQ
Old 04-26-2016, 11:26 PM   #7089
stockysnail
Just the tip
stockysnail's Avatar
Never stop modding. I'm tried to cure the car modding addition by buying a Ducati Hypermotard SP last Saturday. We'll see how that goes.
The Following User Says Thank You to stockysnail For This Useful Post:
Dream20b (04-27-2016)
Old 04-27-2016, 12:12 AM   #7090
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
In that case just get a Vette . Even a c5 z06 is insanely fun!Name:  ImageUploadedByTapatalk1461730388.824244.jpg
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 04-27-2016, 12:22 AM   #7091
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
This is where I am right now. I've had the 210 for about 2 months and heatsoak is definitely a killer. Next major mod is definitely gonna be an intercooler and 69mm. Can't wait to be able to afford it. AFTER the marriage
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
The Following 2 Users Say Thank You to riboyster For This Useful Post:
continuecrushing (04-27-2016), Rifle (04-27-2016)
Old 04-27-2016, 01:25 PM   #7092
camelflage
Drives: pinto power
I'm aware of this game. I've capped myself at 10k between now and the end of the year, that's the most I'm willing to spend on a car that I'm going to get rid of in the fall of next year.
Old 04-27-2016, 06:33 PM   #7093
walletsr
Drives: 2014
Well I have a 335 for sale if your want to upgrade
walletsr is offline   Reply With Quote
Old 04-27-2016, 06:33 PM   #7094
Dream20b
Y u do dis?
run while you still can.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
The Following 2 Users Say Thank You to Dream20b For This Useful Post:
continuecrushing (04-27-2016), riboyster (04-28-2016)
Old 04-27-2016, 06:53 PM   #7095
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
bro you'll be lucky to afford tacobell after marriage!
The Following 2 Users Say Thank You to continuecrushing For This Useful Post:
Dream20b (04-27-2016), riboyster (04-28-2016)
Old 04-27-2016, 07:03 PM   #7096
stockysnail
Just the tip
but hunny, if we get married at the courthouse we can use the money to upgrade my car instead! If she's more of a car nut than you that would work and no wonder you married her!
The Following 2 Users Say Thank You to stockysnail For This Useful Post:
Old 04-27-2016, 07:15 PM   #7097
Rifle
Rifle's Avatar
Can someone do me a favor? I'm not exactly sure if I have an issue, but someone who can check their system for me will be able to tell in a minute.
I had the Intercooler pump fail on me. No big deal. Swapped the pump and I'm good. My issue now is, the side that pumps the fluid into the heat exchanger in front of the radiator feels like it's pressurized and pushing fluid. The return out of the heat exchanger feels dead and limp. I'm not even sure if it's pushing fluid. Can anyone turn their car on and check their heat exchanger lines and see if they feel movement. For me, the top one on the heat exchanger is, the bottom one isn't. The bottom one is also the one that feeds into the front of the charger.[/
295WHP/220TQ
Old 04-28-2016, 12:36 AM   #7098
riboyster
riboyster's Avatar
Well she already let me get the supercharger so fair is fair. Probably gonna get the intercooler in a few months when we have a couple weeks apart while moving. If all goes well, there won't be anything to notice
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
