Old 06-17-2012, 11:24 PM   #281
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
run it stock with the new tires... what size??? if it were me..I would go with 235/40/17 StarSpecs..they fit on the stock wheel and should offer a decent amount of grip ...and see where you stand with it...I did that last weekend..then I changed a bunch of stuff...some worked...others things...not so sure.....
Bill
Scooby South is offline   Reply With Quote
Old 06-17-2012, 11:28 PM   #282
kanundrum
Drives: 2013 Whiteout FR-S
I have new RPF1's so most likely going with 245 haven't order them yet but our Autox has no rules like scca about tire widths etc so just going for some wider ones all around the car.
Old 06-17-2012, 11:28 PM   #283
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Good info!
Old 06-17-2012, 11:30 PM   #284
BlaineWasHere
Grip>Drift
Drives: FRS
Ever think about a slight staggered set up? 245/265? I don't even know. This will be my first RWD car for autoX.
Old 06-17-2012, 11:36 PM   #285
kanundrum
Read earlier info. THis is basically bad idea will also prevent tire rotation in the future.
Old 06-18-2012, 12:03 AM   #286
Bamixam
Bamixam's Avatar
Drives: SWP Subaru BRZ Limited MT
Hey Bill do you have an update on your stock option BBS wheels with no TPMS in them? Does the TPMS light come on at all?
Bamixam is offline   Reply With Quote
Old 06-18-2012, 08:26 AM   #287
Scooby South
Conedancer
not me...but its the course....so you can see.......everycorner was thottle-on oversteer for me...
Bill
Old 06-18-2012, 08:28 AM   #288
Scooby South
Conedancer
From my Build Thread on Nasioc
Originally Posted by solo-x View Post
Are you actually running zero rear toe on a rear drive car? If so, that's probably a LARGE part of your over steer issue. Try an 1/8" total toe in on the rear and put the rear bar back on, see if that fixes your over steer issue.
going to take his advice and run the 1/8" toe in ...in the rear and see how it does...
Bill
Old 06-18-2012, 10:49 AM   #289
ubersoph
After about 50 miles or so, the light blinks a bunch and then it stays on solid. After that every time you start the car it blinks a little then stays solid.
Does not affect TCS - verified this at the same event that Bill was at
ubersoph is offline   Reply With Quote
The Following User Says Thank You to ubersoph For This Useful Post:
Scooby South (06-18-2012)
Old 06-18-2012, 10:50 AM   #290
ubersoph
Bill
Hey what about looking at the stock alignment, and then just increasing camber with the same difference in camber front to rear? The car felt awesome with just tires this weekend so maybe the stock alignment isn't such a bad way to start.
Old 06-18-2012, 10:58 AM   #291
Scooby South
Conedancer
I would still check the factory settings..as mine was 'crabbing'... positive on one side...negative on the other..
Bill
Old 06-18-2012, 11:05 AM   #292
xwd
Bill
Man I miss autocrossing in Milwaukee. Did you ever have to shift to 3rd in the BRZ or bang off the limiter? When you weren't spinning?
Old 06-18-2012, 11:19 AM   #293
ubersoph
Definitely a 2nd gear course.
Old 06-19-2012, 07:45 AM   #294
Scooby South
Conedancer
OK...quickie poll:
KW Variant 3's or AST 4150's...
KW Positives: Available NOW...Well known National Champion endorsed. Bump and Rebound adjustment. compatible spring rates..can use a 2.5 in spring, Stainless steel bodies, helper springs. can be integrated with plates.
AST 4150 Positives: Proven performance, Contingency program, can be integrated with Plates. comes with 2.5 in springs, Individual Height adjustment not interferring with Spring Pre-load.
Negatives:
KW: kinda funky adjustment points, not really height adjustable unless you consider spring preload, Stainless steel bodies
AST: Single adjustable, Steel bodies for the front Struts. not available till Julyish????
which would you go with...or is there something that you would consider???
BC?
Tein?
Koni inserts?
Bill (getting antsy for good suspension)
Subaru/Scion warranty and autocross Ribface Tracking / Autocross / HPDE / Drifting 55 06-17-2015 08:30 PM
Will you Autocross your 86? Ribface Tracking / Autocross / HPDE / Drifting 131 06-22-2012 05:48 PM
Which autocross class? jpdarty7 Tracking / Autocross / HPDE / Drifting 66 06-21-2012 05:53 PM
FR-S at a CA Autocross oneday Scion FR-S / Toyota 86 GT86 General Forum 57 03-26-2012 03:38 PM
