#253 |
Drives: Toyota GT86
#254 |
Drives: Asphalt FR-S
#255 |
Drives: none
I installed on of the custom ROMs last night and everything was working great. This morning I get no response from the touch screen or any of the front panel buttons
Back to the drawing board.
#256 | |
Drives: Toyota GT86
Which Rom do you try? I updated the OEM Rom without mcu update, worked fine. I found out that a app put some data on the music only USB stick, removed it and now instand music at start.
#257 |
If anyone sees joying post up another update on their website, please give us a heads up. I think we should keep that info up to date on this thread.
#258 |
Drives: Toyota
What's the difference if I get the Double Din Universal unit ( 7 inches) instead of the toyota unit?
#259 |
Drives: '15 FR-S RS 1.0
With the universal, you will need the toyota harness that you buy seperate
#260 |
Crescent fresh at best.
Drives: 2016 Scion FR-S - Asphalt
#261 |
Drives: none
The universal unit is available with a larger, higher resolution screen at the expense of the dvd/cd drive. I believe there's also a universal version with more ram and android 5.x vs the 4.4 available on the Toyota version. For me though I didn't like the look of the double din spacers against the silver of the brz dash. They look much better with the darker frs dash trim, imo. I may try to design and build a replacement trim piece to match a double din opening, but I would probably do both sides so I can match the color /finish
Sent from my XT1095 using Tapatalk |
#262 |
Drives: Toyota GT86
#263 | |
Drives: Whiteout Monogram
The universal has no optical drive, slightly bigger screen size (they are also sold with two different resolutions) but isn't a direct fit into the dash. Others you may see in this thread modified their brackets to allow it to fit better. Oh and there can be gaps in the sides of it. I haven't done anything to the brackets so I have gaps on the left and right and the trim plastic doesn't clear the unit so it doesn't sit flush with the rest of the dash. It isn't drastically noticeable but it's there. I know there are ways to fix it but I haven't seriously looked into it. I believe pictured a few post up is a universal that fits well. Effectively the two units as far as internals are exactly the same. Comes to screen size and if you use CD's. Oh and trying to get a neat fitment, which I want to pursue now.. Hope this jumble of info helps a little. Sent from my Nexus 5X using Tapatalk
Shameless Instagram plug : @BaymaxGT86
#264 | |
Drives: Toyota
And is it plug and play? Thank you |
#265 |
If you order the universal ones then you need to add the toyota harness. If you get the toyota direct fit one, it includes the harness. All plug and play except for moving one of the pins in the harness.
#266 | |
Drives: Toyota
![]() I'm not too good with this stuff. If you don't mind, can you post a link on where I can get the toyota harness? http://www.metraonline.com/part/95-8202 Would this bracket work? To get this correct.. Car wire - > Harness - > Head Unit - > Install Bracket - > mount screws Thanks once again |
| Another Android Head Unit | Starscream15 | Electronics | Audio | NAV | Infotainment | 57 | 08-23-2015 12:41 AM |
| Dashlinq4 Android Head unit. Stock BRZ fitment. Toyota Universal. | junglizste | Audio/Visual, Electronics, Infotainment, NAV | 3 | 01-08-2015 11:55 AM |
| Ca-Fi Dashlinq4 Android head unit universal Toyota | phanguy | Audio/Visual, Electronics, Infotainment, NAV | 4 | 11-19-2014 11:57 AM |
| FS: T7019A Android Head Unit | pheoxs | Audio/Visual, Electronics, Infotainment, NAV | 4 | 08-26-2013 05:05 PM |
| Android head unit | drei | Electronics | Audio | NAV | Infotainment | 21 | 07-16-2012 02:42 AM |
