Old 04-21-2016, 10:28 PM   #253
Ralle109
Ralle109's Avatar
Drives: Toyota GT86
Originally Posted by Rican_D View Post
I can't believe there's no amp.
As I said, no external, only the internal amp in the Toyota touch&go head unit
Ralle109 is offline   Reply With Quote
Old 04-22-2016, 10:58 AM   #254
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
I guess you learn something new everyday lol. Crazy how many small differences the same car can have.
Rican_D is offline   Reply With Quote
Old 04-22-2016, 12:00 PM   #255
armstrom
Drives: none
I installed on of the custom ROMs last night and everything was working great. This morning I get no response from the touch screen or any of the front panel buttons Back to the drawing board.
armstrom is offline   Reply With Quote
Old 04-23-2016, 02:28 PM   #256
Ralle109
Ralle109's Avatar
Drives: Toyota GT86
Chosen the correct MCU update?
Which Rom do you try?
I updated the OEM Rom without mcu update, worked fine.
I found out that a app put some data on the music only USB stick, removed it and now instand music at start.
Old 04-24-2016, 04:36 PM   #257
Rican_D
Rican_D's Avatar
If anyone sees joying post up another update on their website, please give us a heads up. I think we should keep that info up to date on this thread.
Old 04-25-2016, 12:18 PM   #258
FRSure
Drives: Toyota
What's the difference if I get the Double Din Universal unit ( 7 inches) instead of the toyota unit?
FRSure is offline   Reply With Quote
Old 04-25-2016, 07:52 PM   #259
socal_48
socal_48's Avatar
Drives: '15 FR-S RS 1.0
With the universal, you will need the toyota harness that you buy seperate
socal_48 is offline   Reply With Quote
Old 04-25-2016, 08:24 PM   #260
Devante
Crescent fresh at best.
Devante's Avatar
Drives: 2016 Scion FR-S - Asphalt
Are there any pros and cons?
I guess a universal one would work in any new car you get in the future.
Sent from my SAMSUNG-SM-N910A using Tapatalk
Devante is offline   Reply With Quote
Old 04-25-2016, 11:47 PM   #261
armstrom
Drives: none
The universal unit is available with a larger, higher resolution screen at the expense of the dvd/cd drive. I believe there's also a universal version with more ram and android 5.x vs the 4.4 available on the Toyota version. For me though I didn't like the look of the double din spacers against the silver of the brz dash. They look much better with the darker frs dash trim, imo. I may try to design and build a replacement trim piece to match a double din opening, but I would probably do both sides so I can match the color /finish
Sent from my XT1095 using Tapatalk
Old 04-26-2016, 04:08 AM   #262
Ralle109
Ralle109's Avatar
Drives: Toyota GT86
Yes, bigger screen higher resolution and in case of Germany around 160-200€ cheaper because german shipping
Old 04-26-2016, 04:48 AM   #263
Baymax86
Baymax86's Avatar
Drives: Whiteout Monogram
I have the universal 7" one. From my understanding the Toyota one is practically a direct fit and has an optical drive for movies and music, and 6" screen.
The universal has no optical drive, slightly bigger screen size (they are also sold with two different resolutions) but isn't a direct fit into the dash. Others you may see in this thread modified their brackets to allow it to fit better. Oh and there can be gaps in the sides of it. I haven't done anything to the brackets so I have gaps on the left and right and the trim plastic doesn't clear the unit so it doesn't sit flush with the rest of the dash.
It isn't drastically noticeable but it's there. I know there are ways to fix it but I haven't seriously looked into it. I believe pictured a few post up is a universal that fits well.
Effectively the two units as far as internals are exactly the same. Comes to screen size and if you use CD's. Oh and trying to get a neat fitment, which I want to pursue now..
Hope this jumble of info helps a little.
Sent from my Nexus 5X using Tapatalk
Shameless Instagram plug : @BaymaxGT86
Baymax86 is offline   Reply With Quote
The Following User Says Thank You to Baymax86 For This Useful Post:
FRSure (04-26-2016)
Old 04-26-2016, 08:12 AM   #264
FRSure
Drives: Toyota
Do I also need a Toyota harness ?
And is it plug and play?
Thank you
Old 04-26-2016, 09:47 AM   #265
Rican_D
Rican_D's Avatar
Thank you
If you order the universal ones then you need to add the toyota harness. If you get the toyota direct fit one, it includes the harness. All plug and play except for moving one of the pins in the harness.
Old 04-26-2016, 10:17 AM   #266
FRSure
Drives: Toyota
Thank you
I'm not too good with this stuff. If you don't mind, can you post a link on where I can get the toyota harness?
http://www.metraonline.com/part/95-8202
Would this bracket work?
To get this correct..
Car wire - > Harness - > Head Unit - > Install Bracket - > mount screws
Thanks once again
Another Android Head Unit Starscream15 Electronics | Audio | NAV | Infotainment 57 08-23-2015 12:41 AM
Dashlinq4 Android Head unit. Stock BRZ fitment. Toyota Universal. junglizste Audio/Visual, Electronics, Infotainment, NAV 3 01-08-2015 11:55 AM
Ca-Fi Dashlinq4 Android head unit universal Toyota phanguy Audio/Visual, Electronics, Infotainment, NAV 4 11-19-2014 11:57 AM
FS: T7019A Android Head Unit pheoxs Audio/Visual, Electronics, Infotainment, NAV 4 08-26-2013 05:05 PM
Android head unit drei Electronics | Audio | NAV | Infotainment 21 07-16-2012 02:42 AM
