Old 04-24-2016, 09:43 PM   #1
toeout
TRMotorsport FF10 17x9 +45mm wheels
I bought a set and I think they look good. I didn't see any pictures of these wheels, so I took a few for people contemplating these.
The weight was 1.76 lbs more than the stock setup, per wheel. This is with brand new 245/40/17 Michelin PSS vs stock Primacy with about 10K on them. So new vs new difference should be even less.
5mm spacers, -3.3 camber front, -2.2 in the back.
toeout is offline   Reply With Quote
The Following User Says Thank You to toeout For This Useful Post:
hmong337 (04-25-2016)
Old 04-25-2016, 12:39 AM   #2
Pat
Pat's Avatar
Drives: 2023 BRZ
I like it. All business.
Old 04-25-2016, 12:51 AM   #3
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Very nice!
hmong337 is offline   Reply With Quote
Old 04-25-2016, 12:47 PM   #4
Icecreamtruk
Drives: Track preped NA FRS
Are you using the spacers with stock studs? Is there enough tread on the stud with the spacers to say, run it on the track? I have a new set of wheels that I might need a 5mm spacer to fit (17x8 ET 46) since I have -3 camber up front and stock suspension (will probably rub on spring).
Icecreamtruk is offline   Reply With Quote
Old 04-25-2016, 01:17 PM   #5
toeout
I'm on ARP studs. With the stock studs I used 3mm spacer and autocrossed the car frequently. That said, the number of threads left for the lugnut to grab didn't really instill a lot of confidence in me. With stock suspension, I'd expect +45 and up offset to rub on the spring perch
Old 04-25-2016, 01:35 PM   #6
JimR
JimR's Avatar
Drives: '15 FR-S, '92 Sentra SE-R
Looks pretty butch with the 17x9's.
Here's my Firestorm on the 17x8" size of the same wheel:
http://www.ft86club.com/forums/showp...24&postcount=4
JimR is offline   Reply With Quote
TRMotorsport FF10 17x8 +45mm JimR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 07-04-2018 06:06 PM
BNIB 17x9 45mm RPF1 qbcsvt Want-To-Buy Requests 0 05-28-2015 10:19 PM
WTB: Enkei Raijins (18x8.5 45mm and 18x9.5 45mm) Shedd22 Want-To-Buy Requests 3 04-03-2015 01:15 PM
FS (NNJ): Enkei RPF1 Wheels (17x8", 45mm, 5x100, Set/4) Silver w/Center Caps dvnguyen Wheels and Tires 1 01-27-2014 10:33 AM
