Old 04-23-2016, 06:39 PM   #1149
HLHachiRoku
Drives: 2015 HL FR-S
My new tune I finally finished putting together. Based off stage 2 91 uel, with help form @steve99 and @Wayno messages, posts and how to's. (still needs work(possibly), but need to put way more miles on it and logs. For now its running great! Performance mods (perrin drop in filter, jdl uel header/op) so far(custom catback, but that doesn't add performance imo)
WOT run, seeing some flkc, but nothing below 0.65 and only 1 flbk that wasn't bad at all. (seems to be in certain rpms, but car didn't feel any hesitation while getting on it) The car has way more pull, adv mult stayed at 1. Its only 88 out today, windy. AFR vs commanded seems decently close as well, yes?
http://www.datazap.me/u/hlhachiroku/...1-5-8-11-12-13
Here is a cruising log, small light pulls till ~6k. No flbk, or flkc to report! Again AFR vs commanded is decently close, yes?
Again I need to log and log and drive miles on it to get it in its happy place if it so needs it. I'm happy with the results so far, atleast 2nd to 4th gear run felt super strong. I could only imagine what it would be like with a turbo etc done to it, lol
Thanks again for all the help!
HLHachiRoku is offline   Reply With Quote
Old 04-24-2016, 03:01 AM   #1150
Dru670
Drives: 2016 Scion FR-S
Aight guys tonight I did a test run back to back comparing the new OFH Stg 2 UEL 91 Tune vs OTS Stg 2 UEL 91 Tune driving the same route (round trip) doing one 3rd gear pull on the on-ramp and cruise back home. I live in Las Vegas and only run 91 oct (current tank is on Chevron 91). Shiv doesn't recommend the new OFH tune if you in CA, NV and AZ btw, just wanted to see how this OFH specific tune performs on my 1320 UEL header compared the the base OTS stg 2 tune in the current conditions.
So, just wondering if you guys can tell me which tune seems better for my car...atleast for this night's test. I'm guessing Shiv's new OFH tune is not recommend for our Vegas heat.
Both logs in this link
http://www.datazap.me/u/dru670/ofh-s...og=1&data=5-13
Dru670 is offline   Reply With Quote
Old 04-24-2016, 03:14 AM   #1151
phrosty
Originally Posted by Dru670 View Post
Shiv doesn't recommend the new OFH tune if you in CA, NV and AZ btw...I'm guessing Shiv's new OFH tune is not recommend for our Vegas heat.
Nothing to do with heat. It needs high-quality gas.
phrosty is offline   Reply With Quote
Old 04-24-2016, 03:23 AM   #1152
Dru670
So in these logs the the OTS runs better than the OFH tune on our crappy gas?
Old 04-24-2016, 04:55 PM   #1153
Dru670
question when tuning for knock correction do I retard timing if there is knock even if the IAM remained at 1 when it knocked or only when IAM drops that's when I can retarted timing in the ignition base B?
Old 04-24-2016, 05:55 PM   #1154
steve99
Drives: FT86
if iam is solid at one , dont start pulling timing all over the place only look at pulling timing if your getting consistent knock in an rpm\load area over -1 in magnitude.
if it runns fine in cooler temps and only getting a bit og knock with hotter intake temps then look towards the iat compensation tables rarther than pulling timing from Base Timing B.
Yous should look at waynos timing tables he has smoothed the lumps and bumps just doing that can stop knock , note you have to look at base B and Knock correction MaxA togeater as they get added to form base ignition timing.
Old 04-24-2016, 06:13 PM   #1155
Dru670
Oh okay thanks.
Old 04-25-2016, 03:28 PM   #1156
HLHachiRoku
@steve99
What if the knoc is coming from going from cl to ol? What table/tables should I look at? I dont see any differences in mine verse waynos in the cl/op section =( iam is staying at 0.96 atm, but the transition is getting some knock and dropping the iam a tad each time
[||•]=(86)=[•||]
2015 Hot Lava FR-S (Sold)
OFT → My non sensor flexfuel UEL tune
Plus other mods
Old 04-25-2016, 05:02 PM   #1157
steve99
Drives: FT86
Originally Posted by HLHachiRoku View Post
@steve99
Have a look at afr vs commanded afr, you might be getting a lean condition on transition from cl\ol, might need to adjust load limits see waynos guide
Old 04-25-2016, 05:55 PM   #1158
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
@steve99
You can copy my cl fuel comp tables or you can do like kn does and remove the delays. The delays are there so the ecu can learn fuel trims.
Old 04-26-2016, 12:56 AM   #1159
HLHachiRoku
So the tables are already the same as I double checked @Wayno. Id rather not disable as it should be there since its there imo.
Thanks again!
@steve99 on waynos guide it says out dated on it as far as the load and axis numbers. Can this still apply? It is running leaner on the transition over and the timing dips down too I noticed.
[||•]=(86)=[•||]
Plus other mods
Old 04-26-2016, 01:16 AM   #1160
Wayno
Wayno's Avatar
The latest maps are always in the examples thread, not the guide.
Thanks again!
Old 04-26-2016, 01:23 AM   #1161
HLHachiRoku
Sorry @Wayno, I ment examples thread, it says (out of date) for the load limits, and in the tune 98 uel rich or tomei 98 uel rich these tables dont exsist, ive tried loading them alone with the correct definition but dont see that table. Im probably doing something wrong =( thank you!
[||•]=(86)=[•||]
Plus other mods
Old 04-26-2016, 08:14 PM   #1162
Dru670
Both the examples and guide thread say out of date.
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
