#3725 | |
#3726 |
Drives: white subaru brz
#3727 | |
driving smoother faster
Drives: Sold
Is this what you are looking for? http://949racing.com/using-a-tire-py...49-Racing.aspx http://www.elephantracing.com/techtopic/tiretemp.htm http://www.fluke.com/fluke/uses/comu.../racetracktemp Google rocks |
#3728 | |
Are you looking for pressures? Do you want me to fly out to you and personally set your pressure? I'm not sure what kind of answer/response you're looking for. |
#3729 | |
yea just like general pressures I should set my tires too. Like cold/hot.. |
#3730 |
#3731 |
Drives: Hyper Blue BRZ
Try starting at 32lbs cold and go from there. It is almost always a good place to start on a lot of cars if you have no firm direction. The tires will generally gain 4-6 lbs when heated unless you are driving something like a 911 and I have see 10-15lbs gain on the rear on that car. Drive, learn and grow. I doubt very many people on this site drive are professionals, so have fun and learn.
#3732 | |
Drives: 2015 Series.Blue BRZ
Car weight: 2914lbs 55/45 50.5% cross weight Tires: 245/45/17 RE71-Rs On Tein SRCs 10k front/12k rear. Test of the suspension is stock. Not exactly sure how much the drop is, but I'm pretty sure you were the one who set up the height for the previous owner, so you might have it on hand somewhere. Last track day I was playing with damping settings, so I left the tires at 33psi hot all weekend so it wouldn't throw off my damping changes. Next set of tires will be 235/40/17 NT01s, got a PSI guesstimate for me?
#3733 | |
#3734 |
Drives: Velocity Orange 86 GT
Yep I started at 28 PSI with track surface temps are 38 Degrees. Bleed to 32 works well if you don't have a pyrometre. (get one, you just spent 1500-2000 on tyres/wheel. $100 is nothing)
At the end of the day the fronts were 24 when cold and 27 on the rears. |
#3735 |
Drives: 2013 FRS
What were your hot temps when starting with those?
#3736 |
Drives: Sold
What's the consensus for the lowest oil pressure on track where anything lower is considered dangerous, i.e., "set up your oil pressure gauge to change color at 50psi or lower and to alert/blink at 40psi or lower"? I just installed the pressure gauge. @CSG Mike? @Racecomp Engineering? What should one do if such low pressure is reached - pull into the pits and cool off?
#3737 |
#3738 | |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 09:54 AM |
