Old 04-22-2016, 05:32 PM   #3725
CSG Mike
CSG Mike's Avatar
Originally Posted by jdmblood View Post
@CSG Mike
Hey Mike can you help me out with adjusting tire pressures? Ive been to a few track days already and still haven't figured out a formula on it. Still kinda clueless on the whole thing. Got a track day tommorow!!!
How do you want me to help you out? Do you have a tire gauge? What about a pyrometer? What kind of tires are you using?
jdmblood (04-22-2016)
Old 04-22-2016, 06:06 PM   #3726
jdmblood
jdmblood's Avatar
Drives: white subaru brz
I have a tire gauge but no temp gauge. I'm running a square setup on Bridgestone potenza re71r in 235.40.17.
jdmblood is offline   Reply With Quote
Old 04-22-2016, 06:18 PM   #3727
dp1
driving smoother faster
Drives: Sold
You need a pyrometer, metal probe is better than IR.
Is this what you are looking for?
http://949racing.com/using-a-tire-py...49-Racing.aspx
http://www.elephantracing.com/techtopic/tiretemp.htm
http://www.fluke.com/fluke/uses/comu.../racetracktemp
Google rocks
dp1 is offline   Reply With Quote
The Following User Says Thank You to dp1 For This Useful Post:
strat61caster (04-22-2016)
Old 04-22-2016, 06:39 PM   #3728
CSG Mike
CSG Mike's Avatar
I still don't know how you want me to help you out...
Are you looking for pressures? Do you want me to fly out to you and personally set your pressure? I'm not sure what kind of answer/response you're looking for.
Old 04-22-2016, 07:24 PM   #3729
jdmblood
jdmblood's Avatar
yea just like general pressures I should set my tires too. Like cold/hot..
Old 04-22-2016, 07:40 PM   #3730
CSG Mike
CSG Mike's Avatar
37 hot. No idea cold; I don't know what's in your tires or how you drive.
jdmblood (04-23-2016)
Old 04-22-2016, 09:24 PM   #3731
atlbrz
Drives: Hyper Blue BRZ
Try starting at 32lbs cold and go from there. It is almost always a good place to start on a lot of cars if you have no firm direction. The tires will generally gain 4-6 lbs when heated unless you are driving something like a 911 and I have see 10-15lbs gain on the rear on that car. Drive, learn and grow. I doubt very many people on this site drive are professionals, so have fun and learn.
atlbrz is offline   Reply With Quote
The Following User Says Thank You to atlbrz For This Useful Post:
Old 04-22-2016, 10:03 PM   #3732
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
I'll jump in because I can give more info...
Car weight: 2914lbs 55/45 50.5% cross weight
Tires: 245/45/17 RE71-Rs
On Tein SRCs 10k front/12k rear. Test of the suspension is stock. Not exactly sure how much the drop is, but I'm pretty sure you were the one who set up the height for the previous owner, so you might have it on hand somewhere.
Last track day I was playing with damping settings, so I left the tires at 33psi hot all weekend so it wouldn't throw off my damping changes.
Next set of tires will be 235/40/17 NT01s, got a PSI guesstimate for me?
ScionOfHorus is offline   Reply With Quote
Old 04-22-2016, 10:27 PM   #3733
CSG Mike
CSG Mike's Avatar
27 cold as a starting point, bleed as needed. 30psi if on nitrogen.
ScionOfHorus (04-23-2016)
Old 04-23-2016, 03:01 AM   #3734
Northwest86
Drives: Velocity Orange 86 GT
Yep I started at 28 PSI with track surface temps are 38 Degrees. Bleed to 32 works well if you don't have a pyrometre. (get one, you just spent 1500-2000 on tyres/wheel. $100 is nothing)
At the end of the day the fronts were 24 when cold and 27 on the rears.
Northwest86 is offline   Reply With Quote
The Following User Says Thank You to Northwest86 For This Useful Post:
CSG Mike (04-23-2016)
Old 04-23-2016, 05:37 PM   #3735
aciddemon
Drives: 2013 FRS
What were your hot temps when starting with those?
aciddemon is offline   Reply With Quote
Old 04-23-2016, 06:52 PM   #3736
dp1
Drives: Sold
What's the consensus for the lowest oil pressure on track where anything lower is considered dangerous, i.e., "set up your oil pressure gauge to change color at 50psi or lower and to alert/blink at 40psi or lower"? I just installed the pressure gauge. @CSG Mike? @Racecomp Engineering? What should one do if such low pressure is reached - pull into the pits and cool off?
Old 04-23-2016, 10:06 PM   #3737
Northwest86
That was running around 31-31.5 Psi Hot
Old 04-24-2016, 12:28 AM   #3738
CSG Mike
CSG Mike's Avatar
no symptoms? You're okay.
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
