| View Poll Results: Do you have the described AT issues? | |||
| Yes, but I've ignored them |
41 | 34.17% |
| Yes, TSB fixed it |
14 | 11.67% |
| Yes, dealer fix did not help |
12 | 10.00% |
| No everything is fine |
53 | 44.17% |
| Voters: 120. You may not vote on this poll | |||
#141 |
Drives: 2005 SLK350, 2015 RS 1.0 FRS
Yeah I'm gonna go to a different dealership
Sent from my A0001 using Tapatalk |
#142 | |
Contract? /人◕ ‿‿ ◕人\
Stupid new girl greeter stuck the number sign on the roof without paper on the bottom and scratched the clear coat. Didnt see it until next morning. Then whoever changed my oil left their handprints all up the outside of A-pillar and my steering wheel. Also didn't notice until next morning. Wish you the best of luck, hopefully you can get things settled. |
#143 |
Drives: 2015 FRS Asphalt
Okay got my car back late this afternoon.
They didn't flash it because they said my VIN number was out of range and get this my ECU had the latest firmware for it. They said they test drove the car and didn't experience any hard shifting. I can't go to another stealership because Servco is the only dealer here in Hawaii for Toyota. They don't belong to Toyota USA as well. They have their own entity here. Oh, F@!#@ Me! other than that the car seemed fine after the service.
#144 | |
Escalate this immediately, its totally dealer prerogative as to whether or not they are willing to flash your car when it's out of the VIN range, in fact mine was as well. Ask to report a dealership for not fixing the issue share them this thread if possible, there's no way your ECU could have the firmware as it is related to the TCM and the updated logic most likely came out much later than when your car was built.
#145 | |
36 miles round trip to the dealer.I had better luck with Honda's in the past. LmaO! This will probably be the last time I buy any Toyota vehicle.
#146 | |
Best of luck. |
| The Following User Says Thank You to soulreapersteve For This Useful Post: | 86geek (04-18-2016) |
#147 | |
Not a troll
| The Following User Says Thank You to Cole For This Useful Post: | 86geek (04-18-2016) |
#148 |
Appointment made for next Monday at 8:15am. Will see if this time the dealer would perform the tsb reflash. Will keep yall posted.
#149 |
Just out of curiosity, how many people had their tcm reflashed and it did not help with this issue?
#150 |
None, although someone was having severe torque converter slip completely unrelated to the issues we were describing
#151 |
Drives: 2013 Scion FRS 10 Series AT
Just had TSB S-SB-0040-13 performed at the dealer for me and it seems this helped a lot. My shifts are buttery smooth! Hopefully it stays the same.
| The Following 3 Users Say Thank You to euthqt For This Useful Post: |
#152 | |
Awesome, and you have a 2013, that means all ATs can have better performance with that logic. If someone on here can get pay the money to get techstream professional diagnostic access we can get the rom file thats used to be flashed to the TCM so someone can figure out how to flash it using techstream.
#153 |
I have a 2015 that doesn't fall under the designated affected VINs, so its a bit Harder to get the flash done. However, Monday I'm not leaving until I get it done.
#154 |
I insist.
| AT Transmission Hard Shifting | MechEGR | Issues | Warranty | Recalls / TSB | 95 | 05-21-2017 11:54 AM |
| AT transmission hard shifting issues | calic | Issues | Warranty | Recalls / TSB | 44 | 11-09-2015 06:17 PM |
| 3 min fix for 2nd gear hard shifting | Black Tire | Engine, Exhaust, Transmission | 22 | 03-23-2014 12:13 PM |
| Transmission noise when up shifting after hard rev | 1Cor10:23 | Engine, Exhaust, Transmission | 2 | 09-03-2013 03:22 PM |
| Hard shifting into 2nd gear when cold | BMWDavid | BRZ First-Gen (2012+) — General Topics | 35 | 06-24-2012 02:22 PM |
