Old 04-19-2016, 11:16 PM   #1
DeviantBlue
Remote won't unlock doors. Need help diagnosing problem.
Here are some details about the issue that the car is having:
- key can unlock the trunk wirelessly
-the lights do blink when pressing the unlock and lock buttons
-the drivers side unlocking mechanism stopped working first and a month later the passenger side followed suit.
-I can only lock/unlock the doors manually
Here is the solution that I came up with so far:
-Replace the door lock actuator on both doors
Does anyone have any other suggestions that I can try before spending the money on the replacement parts?
Thanks in advance!
DeviantBlue is offline   Reply With Quote
Old 04-19-2016, 11:52 PM   #2
steve99
Drives: FT86
Thanks in advance!
try your other remote
make sure battrey is good in remotes
assume car battery is good ?
if still no good remove a battery terminal, press brake pedal, then reconnect battery
try remotes again.
Old 04-20-2016, 12:17 AM   #3
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
Did you leave the spare key in the car somewhere?
justatroll is offline   Reply With Quote
The Following User Says Thank You to justatroll For This Useful Post:
steve99 (04-20-2016)
Old 04-20-2016, 03:12 PM   #4
DeviantBlue
try remotes again.
Tried both remotes. I also disconnected and reconnected the battery terminal to reset the ECU.
The symptoms are the same. Thanks for the suggestions.
Old 04-20-2016, 03:14 PM   #5
DeviantBlue
The spare key is not in the car or near it and the symptoms are the same. Thanks for your comment!
Old 04-20-2016, 03:50 PM   #6
It could be that the batteries on both remotes are low.
As suggested above, I'd replace the remotes batteries, before I started tearing the car apart......
Old 04-20-2016, 03:57 PM   #7
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
If you want to attempt to fix yourself, you need to start testing wires.
http://www.ft86club.com/files/BRZwiringi.pdf
Start on page 264
-alex
Old 04-20-2016, 04:01 PM   #8
DeviantBlue
Batteries are working ok since they can unlock the trunk wirelessly without any issues. I also recently replaced the battery on one of the remotes. Thanks for the suggestion.
The Following User Says Thank You to DeviantBlue For This Useful Post:
humfrz (04-20-2016)
Old 04-20-2016, 04:14 PM   #9
I know we are throwing out obvious things here but have you checked the fuses? I can not believe for one second that both actuators went for a shit.
Old 04-20-2016, 04:19 PM   #10
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
Anything else not working? I feel like its gotta be a fuse or relay that blew
Cockatoo is offline   Reply With Quote
Old 04-20-2016, 04:54 PM   #11
justatroll
justatroll's Avatar
When the key fob batteries start getting low, the dash Key Indicator will blink at you when you turn off the car.
The Following 2 Users Say Thank You to justatroll For This Useful Post:
humfrz (04-20-2016), Tcoat (04-20-2016)
Old 04-20-2016, 05:25 PM   #12
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
I noticed it blinks at you whenever you release the parking break too. Basically whenever you start to drive. It'll blink orange for a few seconds (10-15?) and beep at you like 3 times.
Old 04-20-2016, 06:02 PM   #13
Oh, good to know ...... I reckon I should "read the rest of the manual" ......
Old 04-20-2016, 06:12 PM   #14
DeviantBlue
I haven't checked the fuses yet. I'll do that when I get home from work. I'd like that to be the solution since it would be an easy fix. Thanks for your input!
Diagnosing high positive LTFT Tectoniic Software Tuning 22 05-03-2022 02:24 AM
Diagnosing a brake noise, need help.. Subie_Nubie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 12-27-2017 02:47 AM
Diagnosing low oil pressure BDotG Issues | Warranty | Recalls / TSB 6 02-29-2016 04:09 PM
Need help diagnosing engine noise and misfire Killerb92 Engine, Exhaust, Transmission 21 12-09-2015 11:14 PM
