Old 03-23-2016, 12:54 AM   #1
notout86
Drives: GTS 86 auto
test for really smooth paint
I came across this tip recently and it is great. AFTER washing, rather than run your bare hand over the paint, stick your hand in one of those zip-seal plastic bags and feel through that.
Also see post # 8 below.
GTS86 Auto (Australia)
Last edited by notout86; 04-16-2016 at 08:12 PM. Reason: added "AFTER washing" (thanks KL post #7)
Old 03-24-2016, 07:42 AM   #2
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
Whats the test for specifically?
Back from bancation in Banopolis where I laid on the beach with a beer between my legs. I at night and ate at sun rise
RichardsFRS is offline   Reply With Quote
Old 03-24-2016, 08:09 AM   #3
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I am assuming fallout, but I rather run my hand over the car onces its soaped during a wash like your supposed to to minimize risk of scratching the paint.
Old 03-24-2016, 08:12 AM   #4
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
[ame]http://youtu.be/1R47_TewxTw[/ame]
Old 03-24-2016, 10:34 AM   #5
Atticus808
Atticus808's Avatar
Drives: Splash Mountain
pretty much to check if you should clay bar or not
Atticus808 is offline   Reply With Quote
Old 03-27-2016, 03:06 AM   #6
notout86
Drives: GTS 86 auto
Yes. All the replies are on the money. Wash first then you only run your hand in the plastic bag over the paint lightly. You are just detecting fallout etc embedded in the paint. You are not trying to get them off.
The paint can feel like sandpaper as the plastic goes over the crud if you have a lot of it. Then you can clay or even carefully scratch the particles off with a fingernail. A fingernail does not seem to damage but do not drag the particle over the paint. It is tedious but lots of people have scratched paint using clay.
Old 03-27-2016, 10:59 AM   #7
KL
Drives: 2013 SWP BRZ
Gently being the operative word. That said, if the car and bag are clean, you'll only be feeling for embedded particles (that would need clay to remove them), which won't get dragged across the paint to scratch it... because they're embedded. I don't know if this was mentioned but this is intended to be done AFTER washing/drying the paint.
So, unless the paint is super soft and/or you get grit/dirt/whatever caught between the bag and the paint, the baggie test has a very low risk of damaging the finish.
KL is offline   Reply With Quote
The Following 2 Users Say Thank You to KL For This Useful Post:
go_a_way1 (03-28-2016), notout86 (03-27-2016)
Old 04-16-2016, 08:05 PM   #8
notout86
Drives: GTS 86 auto
If you are wondering why bother getting off particles you can feel but not actually see, it is worth doing for a couple of reasons
1) they are likely to be ferro-magnetic e.g. from rail tracks. They will be attached to steel panels by weak magnetic attraction and with time actually get into the clear coat because they will grow as they rust there. You may see tiny rust spots eventually. At least one car maker goes back and forth continually spraying water over new cars awaiting shipment to wash off industrial fallout.
Treatment with an oxalic acid wash is needed if left too long.
Regular washing and waxing can prevent.
2) after washing your car, if the paint is truly clean, with practice you can get a slow smooth flow of water from the hose and drag off the water as a "sheet" , leaving the paint dry. Particles on the paint will grab the water and you will have to dry.
Old 04-18-2016, 05:54 AM   #9
Test for really smooth paint.
Drag a bikini model across the car.
Is suit stays on all is good.
If suit comes off paint is rough but who cares?
The Following 10 Users Say Thank You to Tcoat For This Useful Post:
Cole (04-18-2016), Dadhawk (04-22-2016), DAEMANO (04-18-2016), emutcfut (04-19-2016), G-awesome (04-21-2016), Jfheisenberg (04-18-2016), meWant (04-20-2016), MTpockets (04-18-2016), notout86 (04-18-2016), qitorr (04-19-2016)
Old 04-18-2016, 11:33 AM   #10
That picture has been photo-chopped ........ I don't see any big dents in the hood .......
WHAT!! ........did I miss something .......
Old 04-18-2016, 12:50 PM   #11
They gently placed her there with a crane.
Old 04-18-2016, 01:16 PM   #12
Now, THOSE ...... WOULD put a couple of dents in the hood of an FR-S/BRZ ..... I don't care how gently a crane let her down ......
Old 04-18-2016, 07:19 PM   #13
notout86
Drives: GTS 86 auto
You have trivialised what is a very serious topic. You should NEVER drag something as heavy as her across the paint as the tiniest bit of grit will scratch. Also, if you MUST use her, the bikini must be given a good brushing down to ensure no grit is on it and preferably it should be made of microfibre. I am also annoyed that you attracted several "likes" while I have received none.
The Following 2 Users Say Thank You to notout86 For This Useful Post:
KL (07-23-2017), Tcoat (04-21-2016)
Old 04-20-2016, 12:36 PM   #14
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
ew, get the fuck off my hood.
Originally Posted by humfrz
I'm old and lazy
Respect BRZ (04-25-2016)
Project Smooth whiteout SmsAlSuwaidi Cosmetic Modification (Interior/Exterior/Lighting) 32 04-04-2015 04:20 PM
Break-in and Smooth Shifting Chad86 Scion FR-S / Toyota 86 GT86 General Forum 21 08-06-2014 04:31 PM
Slow is smooth, smooth is fast B3ND3R Other Vehicles & General Automotive Discussions 43 03-21-2014 11:24 PM
[QLD] 2 SMOOTH number plates PuGZoR Australia Classifieds 4 08-16-2012 02:44 AM
