-   Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) (https://www.ft86club.com/forums/forumdisplay.php?f=42)
-   -   test for really smooth paint (https://www.ft86club.com/forums/showthread.php?t=103346)
notout86 03-23-2016 12:54 AM
I came across this tip recently and it is great. AFTER washing, rather than run your bare hand over the paint, stick your hand in one of those zip-seal plastic bags and feel through that.
Also see post # 8 below.
RichardsFRS 03-24-2016 07:42 AM
Whats the test for specifically?
go_a_way1 03-24-2016 08:09 AM
I am assuming fallout, but I rather run my hand over the car onces its soaped during a wash like your supposed to to minimize risk of scratching the paint.
ZOMFGAARON 03-24-2016 08:12 AM
[ame]http://youtu.be/1R47_TewxTw[/ame]
Atticus808 03-24-2016 10:34 AM
pretty much to check if you should clay bar or not
notout86 03-27-2016 03:06 AM
Yes. All the replies are on the money. Wash first then you only run your hand in the plastic bag over the paint lightly. You are just detecting fallout etc embedded in the paint. You are not trying to get them off.
The paint can feel like sandpaper as the plastic goes over the crud if you have a lot of it. Then you can clay or even carefully scratch the particles off with a fingernail. A fingernail does not seem to damage but do not drag the particle over the paint. It is tedious but lots of people have scratched paint using clay.
KL 03-27-2016 10:59 AM
Gently being the operative word. That said, if the car and bag are clean, you'll only be feeling for embedded particles (that would need clay to remove them), which won't get dragged across the paint to scratch it... because they're embedded. I don't know if this was mentioned but this is intended to be done AFTER washing/drying the paint.
So, unless the paint is super soft and/or you get grit/dirt/whatever caught between the bag and the paint, the baggie test has a very low risk of damaging the finish.
notout86 04-16-2016 08:05 PM
If you are wondering why bother getting off particles you can feel but not actually see, it is worth doing for a couple of reasons
1) they are likely to be ferro-magnetic e.g. from rail tracks. They will be attached to steel panels by weak magnetic attraction and with time actually get into the clear coat because they will grow as they rust there. You may see tiny rust spots eventually. At least one car maker goes back and forth continually spraying water over new cars awaiting shipment to wash off industrial fallout.
Treatment with an oxalic acid wash is needed if left too long.
Regular washing and waxing can prevent.
2) after washing your car, if the paint is truly clean, with practice you can get a slow smooth flow of water from the hose and drag off the water as a "sheet" , leaving the paint dry. Particles on the paint will grab the water and you will have to dry.
Tcoat 04-18-2016 05:54 AM
Test for really smooth paint.
Drag a bikini model across the car.
Is suit stays on all is good.
If suit comes off paint is rough but who cares?
http://myasto.com/blog/wp-content/up...14/10/GT86.jpg
humfrz 04-18-2016 11:33 AM
That picture has been photo-chopped ........ I don't see any big dents in the hood ....... :slap:
WHAT!! ........did I miss something ....... :sigh:
humfrz
Tcoat 04-18-2016 12:50 PM
humfrz
They gently placed her there with a crane.
http://www.operatornetwork.net/image...obile_girl.jpg
humfrz 04-18-2016 01:16 PM
Now, THOSE ...... WOULD put a couple of dents in the hood of an FR-S/BRZ ..... I don't care how gently a crane let her down ...... :eyebulge:
humfrz
notout86 04-18-2016 07:19 PM
You have trivialised what is a very serious topic. You should NEVER drag something as heavy as her across the paint as the tiniest bit of grit will scratch. Also, if you MUST use her, the bikini must be given a good brushing down to ensure no grit is on it and preferably it should be made of microfibre. I am also annoyed that you attracted several "likes" while I have received none.
Clipdat 04-20-2016 12:36 PM
ew, get the fuck off my hood.
