Old 04-20-2016, 10:14 AM   #1
nwscoobie
Drives: 2015 Duramax HC, 2013 FRS
Exterior lens from BRZ and FRS interchangeable?
Does anyone know if the outside lens on the BRZ and FRS are interchangeable? I need to replace them on the brz headlights but need to make sure they are the same shape. I am not sure if they are due to the oem boomerang.
Thanks!
nwscoobie is offline   Reply With Quote
Old 04-20-2016, 10:56 AM   #2
Diode Dynamics
Diode Dynamics's Avatar
The housings are different on the FRS and BRZ
The lenses can't be swapped
Nick C.
John C.
Diode Dynamics
The Following User Says Thank You to Diode Dynamics For This Useful Post:
Tcoat (04-20-2016)
Old 04-20-2016, 12:09 PM   #3
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Nick C.
Even tho the headlights 100% fit both cars? That's odd
lbroskee is offline   Reply With Quote
Old 04-20-2016, 01:32 PM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
Headlight works as a unit. Reflector/lense/light source, their properties and relative spatial placement work together to produce specific shape and strength light beam as per specs and legal requirements. Mixing parts of "similar" units instead of replacing whole unit imho is asking for potential problems, even if parts from one's headlights mechanically fits and could be mounted in other's. Resulting light beam might be within specs, or might be not, i wouldn't want to experiment and be told at MOT to fix lights and repurchasing stock lens back.
Diode Dynamics (04-20-2016)
Old 04-20-2016, 02:49 PM   #5
nwscoobie
Reason I asked this I was able to score a BRZ headlight loaded on ebay for next to nothing shipped to me. I bought one that has some very small scratches I could sand out but other lights on there have broken exterior housing lens.
I m just guessing they would be the same do to the same mounting position.
I want to part my FRS lights out and use the exterior lens, I will know for sure in a couple days when I receive one headlight. Now I am on the hunt for another, for 80 bucks its worth a try, I am a experienced retrofitter as well so that helps
Are these HU's interchangeable? SisterBlue22 Electronics | Audio | NAV | Infotainment 20 08-08-2022 06:09 PM
Interchangeable parts..? Yamajee Engine, Exhaust, Transmission 8 07-12-2014 11:49 AM
*LEGIT USDM TOM'S TAILS US LEGAL! RED LENS & CLEAR LENS $450 AUTHORIZED DEALER!!!* Vicious LED Exterior Parts - Lighting 121 04-19-2014 04:13 PM
FR-S / BRZ side markers interchangeable? Slant Cosmetic Modification (Interior/Exterior/Lighting) 2 06-30-2012 07:26 PM
is this part interchangeable?? Staticfrost Scion FR-S / Toyota 86 GT86 General Forum 3 05-15-2012 07:37 AM
