Old 04-20-2016, 11:33 AM   #13581
kch
Senior Misanthrope
kch's Avatar
Originally Posted by LOLS2K View Post
Did the panels go back on
Everything except the B-pillar trim that covers the seat belt upper mount.
The Following 2 Users Say Thank You to kch For This Useful Post:
LOLS2K (04-20-2016), VIP BRZ (04-20-2016)
Old 04-20-2016, 11:44 AM   #13582
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
I really need to stop spending money and you're not helping.
"Practice makes better. Only Senna is perfect." - CSG Mike
LOLS2K is offline   Reply With Quote
The Following User Says Thank You to LOLS2K For This Useful Post:
kch (04-20-2016)
Old 04-20-2016, 12:00 PM   #13583
kch
Senior Misanthrope
kch's Avatar
It's not a perfect solution if you're tall. Here's a copy-paste from my post on the fb group:
First day impressions:
I got the Essex bar over the agency power for two reasons: (1) so I could still fold my rear seats down; and (2) because you have to cut the bottom mount of the agency power bar if you want to move your seat all the way back.
On point (1), the bar is perfect. I can still lower the rear seats and have easy access from the front as well. It remains to be seen how much it will interfere with the many jugs of E85 I'll have to shove back there, though.
For point (2), it's mixed. It's true that I didn't have to cut or remove any of the bar to make it fit with the seat all the way back. Unfortunately, the bar is located further forward than the agency power bar. This means that when I have my seat in the normal position for DD, the bar rubs against the rear of the seat and creaks a little over bumps. It also means that I can only recline OR have the seat back; never both. Consequently, this isn't the solution for tall people that I hoped it would be.
One final point: I believe the agency power crosspiece can be removed fairly easily, meaning you can use your rear seats in a pinch. The Essex bar, however, isn't going anywhere. I'd have to tear out the whole interior to remove it.
It's really nice being secure in the seat. I'm happy I made the upgrade. That being said, I'm already looking at aftermarket seats so I can have a sub strap.
Edit: example of how close it is to the seat, and this isn't even all the way back.
The Following User Says Thank You to kch For This Useful Post:
LOLS2K (04-20-2016)
Old 04-20-2016, 12:03 PM   #13584
Ashikabi
Ashikabi's Avatar
Don't harness bars exist that fold up out of the way? Or am I imagining that?
Old 04-20-2016, 12:05 PM   #13585
kch
Senior Misanthrope
kch's Avatar
The agency power can allegedly be installed or removed in 15 minutes, if you have help. Not sure about others. This one isn't going anywhere--would probably take me 2 hours to remove by myself.
And I'd imagine that any folding part would just be a weakness in case of a crash.
Old 04-20-2016, 12:06 PM   #13586
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
I was just about to ask you why Essex over Agency bar. You read my mind. An Agency Power bar came up on Craigslist for cheap (has since been sold), but after reading your review, I'd go with the Essex bar if paying retail.
Old 04-20-2016, 12:12 PM   #13587
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Installed the Essex harness bar and some Schroth ProFi II FE ASM harnesses. I'm like a real racecar driver now. Or something.
Do you autocross or for looks?
The Following User Says Thank You to NyC Zn6 For This Useful Post:
Chrisgalactic (05-03-2016)
Old 04-20-2016, 12:19 PM   #13588
kch
Senior Misanthrope
kch's Avatar
HPDE. I wouldn't have gotten such beefy (and pricey ) equipment if I didn't plan to use it.
Edit: although the color choice was naturally for aesthetic purposes.
NyC Zn6 (04-20-2016)
Old 04-20-2016, 12:31 PM   #13589
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Installed my Sparco EVO seat, with Sparco base/sliders/side mounts.
Have to say I am kind of peeved that it only saves barely 5# of weight over the stock seats Needs some adjustment as well on the side mounts to get it lower, right now I cannot fit in the car with my helmet on, argh! They did a good job with the stock seats, I am honestly not sure I will even keep the EVO and might swap the stock seat back in.
It does, however, look very cool
justinco is offline   Reply With Quote
Old 04-20-2016, 12:32 PM   #13590
Ashikabi
Ashikabi's Avatar
Maybe I saw the adjustable rods on some of the other bars and thought they were gas pistons/shocks
Old 04-20-2016, 12:53 PM   #13591
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
5lbs? How much EVO seat weight?!?!?! Isn't OEM driver side seat weight 43.6lbs? Bride Vios III weight 12~15lbs (excluding the rails).
Old 04-20-2016, 01:21 PM   #13592
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
The EVO seat by itself is very light (I couldn't find exact weight).
With the side mounts/slider/seat base installed, my EVO weighed in at 37.4#. It's all the mounting hardware that is heavy, especially the base mount and side mounts.
My stock seat weighed in at 43.2#.
The Following User Says Thank You to justinco For This Useful Post:
ichitaka05 (04-20-2016)
Old 04-20-2016, 01:32 PM   #13593
NyC Zn6
NyC Zn6's Avatar
Definitely pricey but quality is amazing with the Essex harness bar.
kch (04-20-2016)
Old 04-20-2016, 01:32 PM   #13594
ichitaka05
Site Moderator
ichitaka05's Avatar
Sparco website claim EVO weight 6.2kg... that's 13.7lbs. That's damn light... but rail that kills you. That's crazy!
justinco (04-20-2016)
