Old 04-20-2016, 01:11 AM   #435
Deagle50
Drives: Ultramarine FRS, (MILA)
flashing back another tune wont help , each time you flash previous tune is totally erased first
no need to mix e85 .with anyhing .
is the high ltft only at low rpm or does it continue u to 3000 too 4000 as well
high ltft at idle is not that bad but 24% is quite high and unusual.
im thinking exhaust leak
HERE IT IS WHAT DO U THINK?
Exhaust leak?
http://www.datazap.me/u/deagle50/log...6?log=0&data=1
Deagle50 is offline   Reply With Quote
Old 04-20-2016, 01:31 AM   #436
HLHachiRoku
Drives: 2015 HL FR-S
Originally Posted by Deagle50 View Post
thanks alot dude!
Welcome, glad I can help with that =D. Im still learning about all this myself too so I'm unsure about your log. Steve99, wayno or one of the other more experienced people will have to chime in sorry.
HLHachiRoku is offline   Reply With Quote
The Following User Says Thank You to HLHachiRoku For This Useful Post:
Deagle50 (04-20-2016)
Old 04-20-2016, 02:00 AM   #437
steve99
Drives: FT86
Exhaust leak?
mate it looks like your running e85 on a petrol tune you afr is way lean 17 and the ltft is way positive.
can you post up tune you flashed , you will have to zip it or it wont post up as an attachment
Old 04-20-2016, 02:31 AM   #438
Deagle50
says that it exceeds size even though i zipped it. Lemme figure this out gimme one sec.
Old 04-20-2016, 02:36 AM   #439
Deagle50
e 85 tune im using.zip
Old 04-20-2016, 05:58 AM   #440
steve99
Drives: FT86
mate had a look at that tune you posted up its petrol injector scaling and petrol ignition timing ie its a petrol tune NOT E85
Old 04-20-2016, 12:57 PM   #441
Deagle50
thats strange. i downloaded these to my tablet directly from the open flash tablet website. What do u suggest i do from here? will my car blow up?!
Old 04-20-2016, 01:04 PM   #442
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
What process are you using to get the tune from your computer on your tablet, and what is the file name you are uploading to the tablet and flashing?
murdoc is offline   Reply With Quote
Old 04-20-2016, 01:17 PM   #443
Deagle50
download from site to my computer. Then plug in OFT.
Then upload file from OTS_v2.076
then i click on OTSv2.076 again
then i click on BINs
then i click on C roms for US 6MT
Then stage 2 UEL E85
Then i use the D00C Bin which corresponds to my car
then for the writting process i plug the tablet to OBD port
i go to tuning.
i go to write
it tell me to turn on power so i do two clicks over
ask me which tune i want and i click on the one im mentioning.
starts to write.(note i do not open any doors or interrupt process)
writing finishes and it tells me to key off so i do
tells me to key back on so i do
tells me writting is complete and to turn off and then start ignition and let idle for 45 secs before driving so i do.
What am i doing wrong i feel dumb
Old 04-20-2016, 04:08 PM   #444
steve99
Drives: FT86
i go to tuning.
i go to write
maybe delete all the current tunes in tablet slots (except the original tune)
that way you know your actually loading new tunes
did you click "start" after specifying the tunes in the slots, start is what actually transfers tunes to tablet
that all looks correct, look like it could be tune problem
Old 04-20-2016, 04:11 PM   #445
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
I think the best bet is to manually load the tunes onto the tablet (instead of generating them when connected to the car) and loading the tune from there. They he can verify the tune is correct before flashing.
Luckrider is offline   Reply With Quote
The Following User Says Thank You to Luckrider For This Useful Post:
Old 04-20-2016, 05:05 PM   #446
Deagle50
I am going to try erasing everything but the stock file and then re-download the tunes from the site again and start all over and see hwere that gets me?
At this point im very concerned that i have a full tank of E85in my tank and its not burning correctly.
Luck rider could you elaborate a little more on this method? thanks
Old 04-20-2016, 05:10 PM   #447
steve99
Drives: FT86
contact the oft guys (ring on phone) if the tune you posted up is actually the E85 tune from oft then their an error
Old 04-20-2016, 05:33 PM   #448
Deagle50
"the checksum of file has been corrected"
WTH does that mean?
Stock FR-S Tune Just Done Zach3794 Engine, Exhaust, Transmission 67 11-05-2017 02:01 PM
stock BR-Z, much detonation during shifts: tune? elefunkd Engine, Exhaust, Transmission 69 07-26-2013 04:20 PM
Anyone have a stock tune from Visconti? Bleevin CANADA 3 07-03-2013 01:01 AM
My Initial (all stock) BRZedit tune mad_sb Engine, Exhaust, Transmission 6 02-16-2013 12:20 PM
Save stock tune with ecutek? gdrider77 Engine, Exhaust, Transmission 7 01-06-2013 12:50 AM
