go_a_way1
Old 04-18-2016, 10:49 AM   #155
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Originally Posted by Codythatsme View Post
Hey man! My fenders just arrived, by reading this thread I thought that you only had to cut the frame when you were running wide wheels, but after test fitting the fender, it hits the frame and won't bolt on down the bottom. Just wondering exactly what part you need to grind off?
Yep, that piece that it hits is what you need to cut. You'll end up cutting a good inch or so off that frame piece where the fender hits.
Old 04-18-2016, 06:39 PM   #156
nima314
Drives: Subaru BRZ 2017 (almost)
@TylerLieberman
Yeah, I thought 265's would be too much. Maybe I'll get 255's with a little less offset?
Sent from my Nexus 6P using Tapatalk
nima314 is offline   Reply With Quote
Old 04-18-2016, 07:27 PM   #157
TylerLieberman
Drives: '24 GR86
Originally Posted by nima314 View Post
@TylerLieberman
You can. Just gotta see what exactly you're trying to cheap and do some research on what will work best for your application.
At least now you know that you have a way to get what you're looking for. Coilovers to lower the car; just not too much. Front LCAs to widen your front track and fill up the Todoroki fenders, without affecting wheel offset.
You could realistically just buy some 18x9.5 +38 wheels with 255s or 265s and call it a day at that point. No need for spacers or anything like that. Just need the coilovers and arms to adjust the alignment, accordingly.
Old 04-18-2016, 07:46 PM   #158
nima314
Awesome man. Really glad I talked to someone. Thanks again for going through it with a noob. Sounds great. What brand tyre did you get? So I can check how many inches wide your 265's were and do a little maths to make sure my tyre doesn't stick out of the guard at all, or else I'll be screwed. So relieved that I can still get these fenders!
Old 04-19-2016, 12:00 PM   #159
TylerLieberman
Drives: '24 GR86
I used Dunlop DZ012s
Old 04-27-2016, 09:36 PM   #160
slammedstance
slammedstance's Avatar
Drives: 13FRS
whats the going rate now for these fenders? and where to buy?
slammedstance is offline   Reply With Quote
Old 06-07-2016, 06:01 PM   #161
Calbee
Drives: B8 A4
Originally Posted by TylerLieberman View Post
18x9.5 +40 Volk TE37SL
265/35R18 Dunlop DZ102 all around
-2.3 / -1.6 camber (f/r)
7,7,5,5mm Parts Shop Max Spacers (24mm total) front
3mm Part Shop Max Spacers rear
Final wheel spec: 18x9.5 +16 (front) / 18x9.5 +37 (rear)
Car rubbed a little bit all around under hard cornering. Also was damn near impossible to run the corner lights at this height with this wheel setup. If I did it again, I'd get LCAs up front to widen the track and go up to about -3 camber. More inward clearance, and I would be able to ditch the spacers.
Another pic to show how dead on the fitment was up front.
Very informative post.
I am planning on getting 18x10 +38 Meisters with O disk in the front. Was wondering what spacers I would need to get similar fitment. I am planning on running a 265/35/18 tire. My other concern is that I want to be able to fit STi brembos in the future, but do not want to go with the A/R/T disks options. I figure with the amount of spacers I would have, it would be enough to clear the brakes?
Calbee is offline   Reply With Quote
Old 06-07-2016, 08:49 PM   #162
TylerLieberman
Drives: '24 GR86
18x10 +38 will be 15.7mm sunk in compared to my setup, so you would need a 15mm spacer to basically have the same thing.
Keep in mind I also rubbed a little bit under compression when going around corners at higher speeds.
Old 06-07-2016, 09:53 PM   #163
nima314
Hey man, how's your car doing? You mentioned that going for a 255 over a 265 tyre won't affect the flush because the rim is still 9.5, are you sure it wouldn't make a difference at all? I was thinking of finding the exact inches/cm's width for the 265's vs 255's for the Dunlop's so I can make sure it's as flush as possible on paper.
Also, you said yours poke out a bit, but the front looks pretty perfect, did you mean the bottom pokes out because of the camber?
Lastly, I reread the laws and it says new rims can only be 1" wider than the biggest stock of that model, which is 7" I'm pretty sure. Pretty ridiculous seeing as there's no harm with wider rims. Also who checks that anyway, and would getting 8" wide ruin the flush as my LCAs will make it potentially +11 offset in the front?
Thanks again for all the help. It's so hard to wait for this car hahaha.
Old 06-08-2016, 01:34 PM   #164
TylerLieberman
Drives: '24 GR86
I sold my car almost a year ago. I don't even live in Oklahoma anymore, so I couldn't possibly even tell you how the car is doing with the new owner; even though I don't even know who bought it lol.
In regards to tires, yes. The WHEEL is what is the determining factor in how flush it sits to the body, specifically the offset. While the tire can have a role in the clearance, or the overall look of the setup, the wheel and alignment spec are what is going to have the final say.
Take a look at this: http://www.willtheyfit.com/index.php...culate#content
I put in 18x9.5 +40 for the wheel size on both. The tire size is 265/35 on one, and 255/35 on the other. Notice that the wheel itself doesn't change, because the WHEEL specs didn't change. Because of the tire size changing, it minimally altered the overall diameter and the clearance, but that's it.
Here's another one, but the tire sizes are 265/35 and 225/40: http://www.willtheyfit.com/index.php...culate#content
Again, wheel remains in the same spot, but the tire fitment onto the wheel itself has changed quite a bit. The stretching of the sidewall would allow for less camber, due to the added clearance, compared to a squared tire (265/35), but the wheel itself still hasn't changed in how it "fits".
The Todoroki fenders are a bit weird. Look at the picture of my car from the front. It looks like there's a bit of clearance under the front fenders. Then look at it from the rear. The front wheels look like they're dead on flush, maybe poking a couple mm's. The Todoroki's have this curve in them, that can alter the appearance of the wheel fitment, depending on where you look at it from. It was pretty much 100% flush with the fender, MAYBE poking a mm or two, but that's it.
Here's my setup, compared to a 18x8 +11 setup: http://www.willtheyfit.com/index.php...culate#content
As you can see, your setup would 14.1mm away from having the same fitment that mine did. I think it was said earlier that spacers aren't really an option, but I don't know. It also depends with what offset the wheels are before you even adjust the LCA.
On another note, if you could squeeze a 9j wheel, a +11 would be 1.3mm away from what mine was. I mean, I've seen a load of people in AUS using 9.5 and 10j wheels on their cars.
No problem.
Old 06-09-2016, 08:47 AM   #165
nima314
No problem.
Yeah, my friend had 10.5 in the back but for another car. Really thanks a lot for that, it really helped clear a lot of things up.
Hopefully my final questions are, how were the fenders? Did you feel like they were worth it? Did it make a big difference and you fell in love, or was it more of a meh moment? Also, does the extension allow for body kits or just splitters to be installed? Even if it supports a body kit, I guess it might look weird all together because of how the extension looks.
Let's say I don't get the fenders. Strictly legal speaking I could use LCAs in front and rear to get perfect fitment on 8" wheels, and because they're 8" and I'm widening track width, would that mean less camber, or/and no fender rubbing?
Once again, thank you so much and I really appreciate all the help. What're you driving now by the way?
Old 06-09-2016, 06:37 PM   #166
TylerLieberman
Drives: '24 GR86
Todoroki's are the best for this car in my opinion. All the Rocket Bunny, Lux Motion etc etc stuff look like absolute sh*t to me. Tacked on, and don't even flow with the body lines. The only other ones that come close are Victory Function, but those are disgusting on these cars. They look way better on the Evo's.
In regards to the track width, I can't answer that. It all comes down to how much the track width is increased. When you increase track width, you're going to increase negative camber. To counter that, you'll have to adjust the camber plates to balance it out. By doing that, you'll find what works best to get the desired results.
And I'm driving a '16 STI now. Have had it for almost a year now.
The Following User Says Thank You to TylerLieberman For This Useful Post:
nima314 (06-10-2016)
Old 06-10-2016, 01:22 AM   #167
nima314
Alright, awesome, thanks. I'll probably get the fenders then. Okay so the 1" maximum rim width is a section for raising 4WD cars. I can get a tyre up to 275 and thus a rim up to 10.5/11". So looks like 255 with a 9.5 is possible.
However, I reread the laws and the track width is a maximum of 25mm, thus a 12.5mm offset each way, which probably means no widening with LCAs.
Awesome, hope you're enjoying the STi.
Old 06-10-2016, 11:06 AM   #168
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
Customer car I did the paint and install on
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
WTB: BRZ PS headlight, hood, front wide fenders, front bumper/ body kit Guildjs Want-To-Buy Requests 5 10-31-2013 08:35 PM
WTB :OEM front fenders zERoTu Want-To-Buy Requests 0 08-14-2013 04:44 AM
Looking for 85 GTS OEM front fenders ft86me Exterior Parts (Aero, Lighting, Etc.) 0 03-17-2013 03:16 AM
Question About Front Fenders on FRS c0rbin Scion FR-S / Toyota 86 GT86 General Forum 18 05-28-2012 02:40 PM
