View Poll Results: Do you have the described AT issues?
Yes, but I've ignored them 41 34.17%
Yes, TSB fixed it 14 11.67%
Yes, dealer fix did not help 12 10.00%
No everything is fine 53 44.17%
Voters: 120. You may not vote on this poll
Old 04-15-2016, 02:56 PM   #141
KalbiCool88
KalbiCool88's Avatar
Drives: 2005 SLK350, 2015 RS 1.0 FRS
Yeah I'm gonna go to a different dealership
Sent from my A0001 using Tapatalk
KalbiCool88 is offline   Reply With Quote
Old 04-15-2016, 03:51 PM   #142
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
Originally Posted by Cole View Post
I did my best. I've been so unimpressed with my local Toyota service department it's not even funny. From the tech telling me I'm not driving properly, to the service manager brushing me off as a kid, I can't wait until I'm out of free oil changes there so I can finally break off my relationship with them.
I'm debating on whether or not to use up my last free oil change.
Stupid new girl greeter stuck the number sign on the roof without paper on the bottom and scratched the clear coat. Didnt see it until next morning.
Then whoever changed my oil left their handprints all up the outside of A-pillar and my steering wheel. Also didn't notice until next morning.
Wish you the best of luck, hopefully you can get things settled.
The Twins make me smile
Old 04-17-2016, 01:08 AM   #143
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
Okay got my car back late this afternoon.
They didn't flash it because they said my VIN number was out of range and get this my ECU had the latest firmware for it. They said they test drove the car and didn't experience any hard shifting. I can't go to another stealership because Servco is the only dealer here in Hawaii for Toyota. They don't belong to Toyota USA as well. They have their own entity here. Oh, F@!#@ Me! other than that the car seemed fine after the service.
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 04-18-2016, 03:39 AM   #144
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
http://www.toyota.com/support/contact-us
Escalate this immediately, its totally dealer prerogative as to whether or not they are willing to flash your car when it's out of the VIN range, in fact mine was as well. Ask to report a dealership for not fixing the issue share them this thread if possible, there's no way your ECU could have the firmware as it is related to the TCM and the updated logic most likely came out much later than when your car was built.
Old 04-18-2016, 04:21 AM   #145
86geek
86geek's Avatar
Thanks FRSBRZGT86FAN. Servco Hawaii isn't part of Toyota USA. So I can't report to them. Servco Hawaii owns the Toyota Dealership here in Hawaii. They have their own entity they don't abide by Toyota USA. In short they can do whatever they want and they get away with it. I'll try calling the service writer again and tell him it's not the ECU as it's related to the TCM. I'm thinking when they test drove the car they didn't experience the hard shifting. Oddly enough by the time I drove back to town the hard shifting occurred. 36 miles round trip to the dealer.
I had better luck with Honda's in the past. LmaO! This will probably be the last time I buy any Toyota vehicle.
Old 04-18-2016, 07:35 AM   #146
soulreapersteve
Try to share the videos that people have posted on here about the hard shifting. Sucks that they wont accommodate you. My VIN was out of the range but they happily flashed the TCM with very little questions asked.
Best of luck.
The Following User Says Thank You to soulreapersteve For This Useful Post:
86geek (04-18-2016)
Old 04-18-2016, 08:04 AM   #147
Cole
Not a troll
Cole's Avatar
If you can, get on a test drive with them. I found the best way to reproduce it is to go over 80kmh and put on cruise control.
Cole is offline   Reply With Quote
The Following User Says Thank You to Cole For This Useful Post:
86geek (04-18-2016)
Old 04-22-2016, 08:32 PM   #148
KalbiCool88
Appointment made for next Monday at 8:15am. Will see if this time the dealer would perform the tsb reflash. Will keep yall posted.
Old 04-22-2016, 08:39 PM   #149
KalbiCool88
Just out of curiosity, how many people had their tcm reflashed and it did not help with this issue?
Old 04-22-2016, 08:46 PM   #150
FRSBRZGT86FAN
None, although someone was having severe torque converter slip completely unrelated to the issues we were describing
Old 04-24-2016, 12:46 AM   #151
euthqt
Drives: 2013 Scion FRS 10 Series AT
Just had TSB S-SB-0040-13 performed at the dealer for me and it seems this helped a lot. My shifts are buttery smooth! Hopefully it stays the same.
euthqt is offline   Reply With Quote
The Following 3 Users Say Thank You to euthqt For This Useful Post:
FRSBRZGT86FAN (04-24-2016), KalbiCool88 (04-24-2016), soulreapersteve (04-25-2016)
Old 04-24-2016, 01:42 AM   #152
FRSBRZGT86FAN
Awesome, and you have a 2013, that means all ATs can have better performance with that logic. If someone on here can get pay the money to get techstream professional diagnostic access we can get the rom file thats used to be flashed to the TCM so someone can figure out how to flash it using techstream.
Old 04-24-2016, 01:44 AM   #153
KalbiCool88
I have a 2015 that doesn't fall under the designated affected VINs, so its a bit Harder to get the flash done. However, Monday I'm not leaving until I get it done.
Old 04-24-2016, 01:45 AM   #154
KalbiCool88
I insist.
AT Transmission Hard Shifting MechEGR Issues | Warranty | Recalls / TSB 95 05-21-2017 11:54 AM
AT transmission hard shifting issues calic Issues | Warranty | Recalls / TSB 44 11-09-2015 06:17 PM
3 min fix for 2nd gear hard shifting Black Tire Engine, Exhaust, Transmission 22 03-23-2014 12:13 PM
Transmission noise when up shifting after hard rev 1Cor10:23 Engine, Exhaust, Transmission 2 09-03-2013 03:22 PM
Hard shifting into 2nd gear when cold BMWDavid BRZ First-Gen (2012+) — General Topics 35 06-24-2012 02:22 PM
