Old 04-18-2016, 12:53 AM   #379
Elliott S
Elliott S's Avatar
Drives: 2015 Subaru BRZ
So this may clear up some long ending confusion for people wondering about the JDL UEL Catless Headers and the new tune Shiv has released.
My current setup is:
Invidia Overpipe
HKS Dual Resonated Front Pipe
Invidia N1 Catback
K&N Drop-In Filter
Mishimoto Inlet Tube w/ resonator attached
Excuse me for not having the Engine RPM attached to my datalog but I forgot to switch the settings as I had my daily driver settings on.
Quite happy with the results and other than one small spot of Knock Correction at the first big 3rd gear pull from 20 mph-60 mph, I have not seen any since.
http://www.datazap.me/u/elliott-s/ne...g=0&data=1-4-8
Elliott S is offline   Reply With Quote
The Following 2 Users Say Thank You to Elliott S For This Useful Post:
GT86meMR2 (04-18-2016), smg1138 (04-18-2016)
Old 04-18-2016, 03:15 AM   #380
Dru670
Drives: 2016 Scion FR-S
so I just installed a catted front pipe and here are my data logs. Still learning how to interpret this info. Do you guys see anything that I should be concerned about?
http://www.datazap.me/u/dru670/ofh-t...1-2-3-5-6-9-12
Dru670 is offline   Reply With Quote
Old 04-18-2016, 03:31 AM   #381
Elliott S
Elliott S's Avatar
This post is specifically regarding shiv's new OFT tunes. I cant be certain, but are you running it as well? If not, the standard "Data Logs" sub forum link is where you need to post.
Old 04-18-2016, 03:39 AM   #382
Dru670
Yes this is Shiv's latest OFH specific tune on my non-ofh uel header.
Old 04-18-2016, 07:04 AM   #383
Elliott S
Elliott S's Avatar
Cool deal. Might want to post up which one you're running as im sure users on here would like feedback on which one it is so they can have the peace of mind about using it themselves.
Old 04-18-2016, 11:15 AM   #384
Dru670
I did mention it earlier on this post. I have the 1320 uel header
Old 04-18-2016, 12:24 PM   #385
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Yes, way too much knock retard (neg FLKC) above 7k RPM. Those who live in CA, AZ and NV (who only get access to 91oct) should be especially careful with these new maps. They are aggressive!
Shiv@Openflash is offline   Reply With Quote
Old 04-18-2016, 01:26 PM   #386
Dru670
Yikes im in Nevada. I guess im flashing back to the stage 2 (non OFH specific) then.
Old 04-18-2016, 01:31 PM   #387
Dru670
@shiv will you be releasing an updated stage 2 tune for non OFH soon?
Old 04-18-2016, 03:27 PM   #388
RedFRS4me
RedFRS4me's Avatar
Drives: Firestorm '13
That should not have any effect, heaps of guys track all the time on E85 no issues.
I think you have a fault with possibly rear 02 sensor or some other issue.
when you back on petrol flash a stock tune and see if it does it.
So the o2 in the rear is the air fuel o2? My af goes rich after driving for a while and no stft like stuck on open loop. Wish i had a spare to try. Or i will just try a voltage reading check.
With the stock tune i should be getting the p0420 code correct? So if my rear o2 was bad it would throw the same code?
'13 Firestorm
RedFRS4me is offline   Reply With Quote
Old 04-18-2016, 03:37 PM   #389
RedFRS4me
RedFRS4me's Avatar
Hey shiv, im from the nw but made the trip to cental California this weekend and definitely saw what you meant. Even though im having my own issues with being stuck in open loop at the moment i saw more knock correction and my adv multiplier drop below 1 with 91 oct in cali. Back up here in Oregon with 92 it went back to normal.
'13 Firestorm
Old 04-18-2016, 05:00 PM   #390
Shiv@Openflash
Drives: 2013 FRS
it's impossible to do that unless I custom tune each non-OFH header on the dyno. The reason why the new Stage 2 OFH is stronger is because I developed the tune over a couple weeks in a local OFH3 equipped test car.
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
DocWalt (04-18-2016)
Old 04-18-2016, 05:01 PM   #391
steve99
Drives: FT86
The front 02 is used as the primary sensor for fueling. however the rear o2 is used for some fuelling adjustment during cruise and to detect if cat in header is working.
The ECU compares reading from front and rear 02 sensors to work out if cat in header is working, if it detect abnormal readings it will set CEL code P0420.
your problem sounds similar to this guy who did not install rear 02
http://www.ft86club.com/forums/showp...59&postcount=9
many people have damaged their sensors using excessive force to remove or install them in new headers, best to run a thread tap through new header bungs M18 by 1.5mm pitch.
In the stage 2 tunes P0420 is disabled so you wont get it. On stock tune its enabled, so you may get it or may not
Old 04-18-2016, 05:06 PM   #392
Dru670
Do you have a fix for my F00C not reading IAM and MAF voltage? I noticed when I flashed your new OFH tune my OFT was reporting the MAFv and IAM but when I reverted back to the Stage 2 UEL 91 OTS (Stg 2 UEL F00C dated 9/21/2015) I get no IAM and MAF voltage readings on the OFT. Could you pls help so I can find out if my car is running properly or not.
Just how noticeable is OFT+OFH and stage 2 tune? BBYZILA Software Tuning 58 03-20-2018 12:56 PM
OFT 2.0 Stage 1 93 Tune MurderRider Software Tuning 57 03-21-2016 01:30 AM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 09:15 PM
FA20club.com Turnaround Times On Modified Tune Files FR-S Matt Software Tuning 103 11-13-2013 02:48 PM
So whate does stage 3 tune do? I already have 2 Frsexxxy Engine, Exhaust, Transmission 17 05-14-2013 07:30 AM
