| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: 2015 HL FR-S
Diff oil
I was wondering I have 2 qts of this left over oil (unopened) I was going to use in my old car (traded in for my frs woohoo). Can i use this in my rear differential? its the 70W90 NS instead of the 70W90. We don't have clutch packs I don't believe in the rear, so didn't know if it was still ok to use. Thank you!
#2 | |
75W90 is the correct fluid for the Differential so it can be used, also the rear diff uses something like 1.3 quarts: http://www.ft86club.com/forums/showthread.php?t=19218
#3 | |
#4 | |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
For the transmission use Redline MT-85. I just put a mix of MT-85 and MTL in this evening... was working on shifter issue and had to pull the prop shaft...was time for fluid change in both the trasmission and rear differential anyways. Transmission is 2.3 quarts, Differential is 1.2 quarts...
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
#5 | |
#6 |
Thanks
I been really happy with motul
BUt yea 75w90 is the spec so if you got it use it
#7 |
Drives: 13 FRS Satin
Should be fine if I remember correctly, only thing I remember that was important was that the tranny took GL3/4 but not GL5 and diff was the one that took GL5 or anything else.
That's what I remember but last time I changed it was a year ago. |
#8 |
75W90NS is GL-5 and GL-6; the manual calls out GL-3 for transmission and GL-5 for the differential - I would not use the Redline 75W90(NS) in the transmission.
| Review soon:OS Giken Super Lock Limited Slip Differential + Greddy differential cover | mav1178 | Engine, Exhaust, Transmission | 5 | 02-11-2021 01:20 PM |
| '13 FRS Differential | Allaskew | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 03-11-2015 04:16 PM |
| Anyone have a differential pop yet? | slicktop | Engine, Exhaust, Transmission | 6 | 02-26-2014 08:22 PM |
| Differential adjustment | Dipstik-sportech | Engine, Exhaust, Transmission | 7 | 07-22-2013 11:16 AM |
| Eww rear differential goo | LeeMaster | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 13 | 04-10-2013 09:17 PM |
