Old 04-15-2016, 11:48 PM   #1751
swarb
^That ain't meaty.
The Following User Says Thank You to swarb For This Useful Post:
Clipdat (04-17-2016)
Old 04-16-2016, 12:06 AM   #1752
CBR600RR
Drives: Raven Black
Why do you think that?
I think they are meaty.
Old 04-16-2016, 12:25 AM   #1753
Cooperdh
Hot Lava Lover
Cooperdh's Avatar
Drives: 2013 Scion FR-S- lava
Originally Posted by ATL BRZ View Post
255/40/17 Maxxis VR-1 on 17x9 +42 Mach V Awesome's
I got those same wheels but in stainless. How lowered are you and you experience any rubbing? Just asking to see what tires I may get when mine wear out. The black looks good.
Cooperdh is offline   Reply With Quote
Old 04-16-2016, 12:34 AM   #1754
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Because 225. That's only 10mm wider than a stock GT86 here and stock width for a TRD86.
255 is the start of "meaty" really.
nzer is offline   Reply With Quote
The Following 2 Users Say Thank You to nzer For This Useful Post:
ATL BRZ (04-16-2016), PeterFRS (04-16-2016)
Old 04-16-2016, 10:41 AM   #1755
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
They are narrow. Hardly wider than stock. How is hardly wider than narrow ass stock meaty?
The Following 3 Users Say Thank You to BlaineWasHere For This Useful Post:
Clipdat (04-17-2016), PeterFRS (04-16-2016), Tokay444 (07-01-2016)
Old 04-16-2016, 11:39 AM   #1756
toby714
Drives: whiteout
17x9.5 40 all around w/ 255/40/17 rs3. 5mm spacer in the front(35 offset now.) no rub =D
toby714 is offline   Reply With Quote
The Following User Says Thank You to toby714 For This Useful Post:
slow15frs (04-16-2016)
Old 04-16-2016, 05:51 PM   #1757
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
he is probably just referring to the look of sidewall/rim-not actual width. but yeah 225 isn't exactly meaty.
On a another note, the b14 Bilstein coilover up front is extremely wide i learned today- due to the giant progressive springs. A 18x9.5 +40 with a 255 continental DW with -2.1 camber up front with stock tophats adjusted camber with bolts will rub on the spring it self, had to add a 5mm spacer and pull out some camber-now purchasing top hats for that application (going with the velox ones)-figured this could be useful info as that is one of the best coilovers for the money if you want to go with that and a meaty setup i'd suggest top hats to avoid headaches in fitment.
Jive Turkey is offline   Reply With Quote
The Following User Says Thank You to Jive Turkey For This Useful Post:
Old 04-16-2016, 10:22 PM   #1758
CBR600RR
Drives: Raven Black
Ya I'm simply referring to the sidewall look. Not a stretched tire, a sidewall that is "plump" or "meaty"
Sure they aren't much wider, but the contact patch is about a inch wider than the stock Primacy HPs.
Old 04-16-2016, 10:30 PM   #1759
CBR600RR
Drives: Raven Black
Plus, I'm just on an e85 tune. So keeping a size close to stock is important for putting power down properly. Any sizes bigger is overkill unless you are boosted.
Old 04-17-2016, 12:12 AM   #1760
nzer
nzer's Avatar
Yep, may be what you meant but in this case "meaty" means wide.
Have a read of the original post - 255+
http://www.ft86club.com/forums/showp...00&postcount=1
The Following User Says Thank You to nzer For This Useful Post:
Old 04-17-2016, 12:47 AM   #1761
BlaineWasHere
Grip>Drift
Drives: FRS
It's not about rear grip. It's about front grip. I'm on stock power but I still run 17x9 and 255s for cornering.
Your setup still looks good! It's just not meaty.
The Following User Says Thank You to BlaineWasHere For This Useful Post:
Old 04-17-2016, 08:53 AM   #1762
CBR600RR
Drives: Raven Black
Maybe when the thread was first posted. But not recently. My bad.
Old 04-20-2016, 12:57 AM   #1763
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
18x9, 255/35/18
malubawla is offline   Reply With Quote
The Following User Says Thank You to malubawla For This Useful Post:
MisterSheep (04-21-2016)
Old 04-20-2016, 02:35 AM   #1764
CrispyCheddar
CrispyCheddar's Avatar
Drives: the white one
18x9 +30 255/35 RE71Rs pre alignment. rubbatub tub in the rear. Will get that fixed soon, hopefully
Sent from my SM-G920V using Tapatalk
If you can't win a race, beat the person in front of you
CrispyCheddar is offline   Reply With Quote
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
