| Software Tuning Discuss all software tuning topics. |
Drives: 2015 HL FR-S
Rom tuning/changing =D
So I was wondering to make sure since its my first time editing the rom. I open Romraider, click on (see test below) and then choose my calid, then hit apply, then save. Then open up my corresponding tune i want to change. Hit the OK button since the check sum comes up etc. and then change what I want. Save and it as what i want, and then it fixes the check sum. Load the tune and upload to car.
Also I changed cold start and when my radiator fan turns on (so far). Those look ok? I followed the treads on here, and triple checked the values just in case =D (really worried its so easy to mis-enter a value haha) I was wonder why the colors differ then what i see others posting of the same values. Does this matter??? Thanks again everyone for all your help! |
#2 |
Drives: FT86
the colours don't matter, but make sure the values are correct and the axis on the tables.
| The Following User Says Thank You to steve99 For This Useful Post: | HLHachiRoku (04-16-2016) |
#3 |
Values meaning if I set 20.00 in the space and axis being in tthe correct spot like on plot point 14.0 1, 14.0 2 etc? I manually entered the number for these boxes as it was faster for me then just the arrows.
#4 | |
Did you edit the idle tables as well? You can lower them by around 100 other than the part that says 750. Also good job editing the fan curves to stop heat soak, especially with UELs I feel that's important to keep the engine bay vented
| The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | HLHachiRoku (04-16-2016) |
#5 | |
Also while you're at it why don't you edit the new OFH tunes as well and try them on your header and datalog?
#6 | |
I didn't edit the issue table yet, I felt like the motor would be ok with the isle being set as is for when it gets chilly here for now. I might lower them a tad though all its not as high though lol. |
| The Following User Says Thank You to HLHachiRoku For This Useful Post: | FRSBRZGT86FAN (04-16-2016) |
#7 |
Im going to try and change the vvt for the jdl header shiv posted awhile back, but they were running e85 I think though. So unsure, but should still be good I would think.
#8 |
Anything to worry about on these boxes? they have a red and blue border around them???=O I did change them do the JDL UEL vvt that shiv posted. Thanks!
#9 |
Honestly ignore the color coding it does to boxes., I believe blue is a lower value than what was originally there and red is a higher value than was originally there. Just double check it compared to shivs jdl tune to make sure everything is correct.
#10 |
Ohh i quadruple checked already, haha. Then double checked everything this morning XD lol I enter numbers on a daily basis, but i wanted to make indubitably sure I did it correctly XD. Thank you for your help again! =D
| Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps | DeliciousTuning | Software Tuning | 1213 | 06-17-2025 04:02 PM |
| Changing Tuning Software -BRZedit to Ecutek | COO86L | Software Tuning | 14 | 02-17-2016 09:23 AM |
| Mann Engineering 2nd Quarter Tuning Days April 25th & 26th by Bill (Delicious Tuning) | DesertFrs | Northern California | 14 | 04-24-2014 03:15 AM |
| Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) | DeliciousTuning | Announcements, Contests, Giveaways | 6 | 09-19-2013 05:55 PM |
| Visconti Tuning - Latest Forced Induction Tuning Info | Visconti | Forced Induction | 340 | 04-30-2013 06:33 PM |
