Old 04-16-2016, 12:05 AM   #29
Cartman
Cartman's Avatar
Drives: 10 Series Scion FR-S
And here I'm using a Shorai with the OEM tie down...
Cartman is offline   Reply With Quote
The Following User Says Thank You to Cartman For This Useful Post:
SPCorBUST (04-16-2016)
Old 04-16-2016, 10:42 PM   #30
SPCorBUST
SPCorBUST's Avatar
Any chance you can snap a pic?
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 04-16-2016, 11:06 PM   #31
Blue Gt
Blue Gt's Avatar
Check out my post from today in STX prep
Blue Gt is offline   Reply With Quote
The Following User Says Thank You to Blue Gt For This Useful Post:
Old 04-17-2016, 02:40 PM   #32
Cartman
Cartman's Avatar
5lb shorai battery with OEM tie down, I just basically flipped it upside down... don't mind the corrotion... My OEM battery leaked massive amounts of acid, hence aftermarket battery clamp
The Following 2 Users Say Thank You to Cartman For This Useful Post:
smg1138 (10-23-2017), SPCorBUST (04-17-2016)
Old 10-23-2017, 01:35 PM   #33
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
I'm planning to get a Shorai battery soon and was hoping to use the OEM tie down. Do you have another link to that pic? It's not visible anymore thanks to Photobucket.
smg1138 is offline   Reply With Quote
Old 10-23-2017, 08:52 PM   #34
Cartman
Cartman's Avatar
I remade it and now use spacers betwin the nuts and the tie down.
smg1138 (10-24-2017)
Old 01-10-2021, 06:14 PM   #35
SubieDoo
SubieDoo's Avatar
Drives: a yellow BRZ
What's the point of adding the spacers? It looks like the Shorai battery just "sits" on the OEM battery tray. Is the OEM tie down able to secure the Shorai battery in place? What's the gray foam looking stuff?
I'd like to get the Shorai LFX36L3-BS12 battery but would rather use the OEM tie down and J hooks, if possible. However, it seems like most people either built their custom bracket or spent ~$100 on an aftermarket set. Just wondering if that's absolutely necessary?
As for the Shorai battery itself, I live in SoCal but sometimes only drive my car once every week or every other week. Anyone with experience in a similar situation?
SubieDoo is offline   Reply With Quote
Old 01-10-2021, 09:09 PM   #36
new2subaru
Weight Weenie
Drives: 15 FR-S
If you only drive your car every once and a while put the battery on a Shorai tender.
I'd say the same with the stock battery too.
The Following User Says Thank You to new2subaru For This Useful Post:
Ultramaroon (01-10-2021)
Old 01-10-2021, 09:38 PM   #37
The little battery is shorter so spacer is added to adapt the anchor bolts. I'd prefer to see a hunk of 2x4 under the battery but whatever works.
Please don't consider going without a bracket. For example, put a bowling ball in the passenger seat and then slam on the brakes. *
*Don't actually do this.
Spuds (01-11-2021)
Old 01-11-2021, 12:24 AM   #38
SubieDoo
SubieDoo's Avatar
But in his first picture, he didn't use any spacers and that seemed to have worked? Just wanted to confirm this method actually works to secure the Shorai battery.
Old 01-11-2021, 02:06 AM   #39
I saw that too. I'm sure that it didn't work. The anchor point on the firewall is is right up there. That's why I would raise the battery. Not so much because of the length of the bolts, but that rear anchor point is up so high. Hell, I'd raise the battery so the terminals are approximately at the same height as stock. That's what the harness fits.
Old 01-11-2021, 01:32 PM   #40
Cartman
Cartman's Avatar
I had the bracket flipped upside down to compensate for the lack of height... not the best option... the foam wrapping was so it would not cut the battery since the reverse side becomes 2 thin edges... The spacers are top compensate from the lack of thread on the J hooks
Anyway, I no longer have the battery that way...
Ultramaroon (01-11-2021), Wally86 (01-12-2021)
Old 01-11-2021, 11:46 PM   #41
SubieDoo
SubieDoo's Avatar
Thanks! What did you end up doing?
Looks like I might just have to pony up and get the P-Tunning bracket, which looks the cleanest and easiest from an install standpoint.
PTUNING Billet Aluminum Lightweight Battery Tray Mrc@ptuning Engine, Exhaust, Transmission 61 10-01-2016 12:24 AM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 09:26 AM
Installing Shorai Lightweight Battery and #Lighterisbetter CNC Machined Tray SaVaGeRaIn DIY (Do-It-Yourself) Guides 2 08-03-2014 09:55 AM
PTUNING Billet Aluminum Lightweight Battery Tray Mrc@ptuning Engine, Exhaust, Bolt-Ons 18 06-04-2014 02:07 PM
PTUNING Billet Aluminum Lightweight Battery Tray Mrc@ptuning Tracking / Autocross / HPDE / Drifting 5 12-07-2013 03:01 PM
