#43 |
Ok so I'm noiby as fuck with audio... I have the zypr head unit...if I wanted to add a powered sub... what else do I need. A wiring kit I suppose. Do I need some kind of controller to divide up the frequencies or will the head unit do that for me? Anything else I need?
#44 | |
Drives: GR Corolla
![]() Let's just put it this way, I tried listening to "Bass I Love You" by Bassotronics, and the factory woofers couldn't produce any of the bass notes. So I skipped that song every time it came on. With the basstube, I can actually hear, feel, and see (rear mirror) the bass. Granted, it's nowhere near the 10" Type R, but like I said, sufficient enough for a low cost way to fill in the lows. |
| The Following User Says Thank You to Kaotic Lazagna For This Useful Post: | finch1750 (04-15-2016) |
#45 | |
Drives: GR Corolla
And when you say divide up the frequencies, are you talking about a high-pass filter, or equalizer settings? |
#46 | |
Drives: GR Corolla
#47 |
#48 |
Drives: FRS
You'll need a wiring kit, which should come with rcas. The aftermarket hu should be able to set your passes.
Idk about anyone else, but for me I have an aftermarket hu, and have the front crossed at 100hz -6db and the rear at 125 -12db. I have my sub set up at 80hz with -12db lpf For those without an aftermarket hu, a similar set could be done with hardware without too much work. From the factory amp you could wire in a loc to the amp input lines, and 2 caps on the output lines. With the metra male and female kits, you don't even have to touch stock wires even
#49 | |
Drives: 2016 Cosworth 2.2 BRZ
Article referring to dynamic headroom: So if you are using an amplifier with an unclipped power output capability of 100w, and you are listening to music with a crest factor of 20db then the average output you would be able to obtain from the amplifier and avoid clipping the dynamic peaks is 1w. The same amplifier with a crest factor of 10db, the average output would be 10w.Another thing... because a subwoofer has a lot of moving mass, an amp must be able to provide enough current to pull the cone back. True, while turning down a high powered amplifier decreases the wattage output, it does not decrease the amp's headroom capability. While an underpowered amp may be pushed close to clipping, the properly sized amp will be able to push the subwoofer and have enough reserves to account for any dynamic peaks. The underpowered amp will almost always go into clipping under certain transients and this clipping will cause distortion to the output signal. Can you run a sub off an underpowered amp? Yes. Will it damage the sub? Not unless you clip so badly that you overheat the voice coil. Will it produce accurate waves, equal to the source of the audio? Not always. Depending upon how underpowered you are, you will have to reduce the gains of the overall system to avoid clipping the signal. You may end up turning the entire system down so much that it is no longer enjoyable to listen to. Eventually, as always, someone will turn up the gains to get the volume they want and clip the amp. It's better to just buy the properly sized amplifier from the beginning. You can always turn a powerful amp down while keeping all your headroom. You can't turn an underpowered amp up though... Last edited by sly; 04-15-2016 at 08:54 PM. |
#50 | |
Most of the tuning can be done by your head unit. It should have subwoofer outputs. I'm not familiar with the Scion head unit but most have settings for the crossover. You will probably set it to low pass around 80Hz for the subwoofer and high pass around the same for the rest of the speakers. Send 80Hz and below to the sub and send 80Hz and above to the rest of the speakers. You can buy an amp wiring kit from Crutchfield. This would be the easiest solution. It comes with the amp wires, remote wire, fuse and remote wire. They have several to choose from. Just pick one that comes with the RCA cables if you don't already have any, fuse and holder, power and ground wires and a remote wire. http://www.crutchfield.com/g_711/Sin...ts.html?tp=635 Here's a subwoofer installation guide: http://www.crutchfield.com/learn/lea....html?pg=2&c=3 |
| The Following User Says Thank You to sly For This Useful Post: | Ashikabi (04-15-2016) |
#51 | |
#52 |
so from what I understand after reading that sub installation guide, I want a powered subwoofer if I don't want to run wires from the battery to the subwoofer? but regardless of that, I still have to run cables from the back of the headunit to the subwoofer, and possibly wires from the amp (aftermarket or OEM) to the subwoofer? I am a complete novice to sound systems so sorry if this sounds like basic information lol
#53 |
#54 |
I assumed that the powered subwoofer gets the power from the amp... but I have no idea lol. the only experience I have with a subwoofer is for my TV setup but that subwoofer only connects to the receiver with no separate power plug. I am assuming the receiver in a home theater setup acts similar to an amp in a car. I am a complete novice in this area if you haven't noticed lol.
#55 | |
#56 |
I mean from the OEM or aftermarket amp in the car, which connects to the subwoofer to supply power.
| Looking for help adding sub and amp to existing 2016 FRS sound system and head unit | Sonicp9 | Electronics | Audio | NAV | Infotainment | 2 | 02-27-2016 10:24 PM |
| Adding satellite radio to base pioneer system? (FR-S) | redwing634 | Electronics | Audio | NAV | Infotainment | 5 | 12-08-2015 10:20 AM |
| 4 Sale - Stock FRS exhaust system & stock mid pipe | mikeg7827 | Engine, Exhaust, Bolt-Ons | 0 | 01-04-2015 10:05 PM |
| Adding Subwoofer to stock HU | RAN94A | AUSTRALIA | 49 | 05-20-2013 07:53 AM |
| WTS: Airaid Intake System, Stock Exhaust, Stock Radiator Hoses | Sony | Engine, Exhaust, Bolt-Ons | 0 | 11-20-2012 11:10 PM |
