Old 03-11-2016, 05:47 PM   #323
Amputechture
Drives: 2014 BRZ
-What do you recommend I pick up to make install easier, did you guys end up using any little here or theres (zip-ties, Loctite shit like that)?
Get the bumper bar and you won't have to cut the OEM crash beam. Everything needed comes with the kit. Just have tools and time.
hope this helps.[/QUOTE]
Thanks man, cleared up a few things for sure. I've decided to take a circular saw to the factory crash beam, I'm not willing to sacrifice the structural integrity of my car and possibly be denied a claim in the event I have a front end collision. Glad to hear that your tuning experience was a positive one!
Amputechture is offline   Reply With Quote
Old 03-12-2016, 08:21 PM   #324
bfsnail
bfsnail's Avatar
You realize that sentence contradicts itself right? The bumper bar is going to have much more structural integrity than a cut up factory beam.
bfsnail is offline   Reply With Quote
Old 03-13-2016, 11:40 AM   #325
Amputechture
Drives: 2014 BRZ
I'll take my chances on the factory beam with a piping's worth of metal cut out over a "drift bar". The cut up beam at least has a chinaman's chance in hell of being overlooked by someone inspecting the car in the event of a crash than the aftermarket bars.
Old 03-13-2016, 05:58 PM   #326
tumbla.jr
taicho
tumbla.jr's Avatar
Drives: The rEd Fr-S
I picked up a spare one. No need to chop up the one my car came with when craigslist has em cheap.
tumbla.jr is offline   Reply With Quote
Old 04-07-2016, 07:08 PM   #327
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
We now have oil cooler brackets that will now work with Fogs, Long Route IC piping, Short Route IC piping, OEM Bumper Bar, and our Bumper Bars.
We also switched to Investment Cast Stainless Steel Merge Collectors. Along with the smooth merge inside the collector the wastegate path has a bigger opening with no disruption of flow
JDLAutoDesign is offline   Reply With Quote
Old 04-10-2016, 07:54 PM   #328
bfsnail
bfsnail's Avatar
For those with the recirculated waste gate, does the dump pipe just go into the down pipe like a slip gasket? Are there no gaskets/clamps etc?
I have the two pipes that fit into each other, but they aren't especially tight and most other slip joints I've seen are double walled. I just want to make sure I'm not missing anything.
Old 04-14-2016, 01:00 PM   #329
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
So who's got a kit with the No Trim or Cutting FMIC option that's new for 2016?
I REALLY like the idea of a UEL GTX2867R kit with that option.
I'd like to see more pics if anyone has some. @JDLAutoDesign?
Old 04-15-2016, 02:29 PM   #330
GTHachiRoku
Big in Japan
GTHachiRoku's Avatar
Drives: turBRZ
If only this had an option that routed the dump tube out of the hood. You could have it peaking through one of your hood vents
Not that I have any chance to get one soon, but even still, I'm really torn between this kit, PTunning kit and the cheapo SBD kit.
I guess I have plenty of time to think about it.
GTHachiRoku is offline   Reply With Quote
Old 04-15-2016, 03:10 PM   #331
ft86me
ft86me's Avatar
Drives: 2013 FRS
Or get the crash bar they offer. I did that to save myself the cutting trouble and the intercooler mounts to it as well.
ft86me is offline   Reply With Quote
Old 04-15-2016, 03:17 PM   #332
xxscaxx
Drives: 2013 SWP BRZ
If I had to do it over again I would have definitely bought their crash bar instead of cutting up the stock one. You have to remove so much material on the stock bar that the structural integrity is compromised. I could literally bend the crash beam after cutting it.
Don't forget that your crash beam has a VIN sticker on it. If anything get a spare crash beam, have it cut and then welded up with some cut up piping to keep the integrity somewhat there. This was my original plan but a buddy of mine who was suppose to weld it up for me bailed so I installed it as is. I still may pull it out and have it welded up.
xxscaxx is offline   Reply With Quote
Old 04-15-2016, 04:03 PM   #333
ATL BRZ
ATL BRZ's Avatar
I would prefer not to replace my crash beam or modify it for the original version of the JDL turbo kit. Firstly, I like the peace of mind knowing that it's there in case of an impact. My Velox splitter rods are mounted to the front face of the stock crash beam and it would be tedious to adapt it to a tubular crash bar. Also I've heard from multiple professional tuners and kit owners (in the owners thread) that the MAF placement isn't ideal and can make it difficult to tune properly. Not impossible, just difficult. I know that HRI and Delicious have made it work, but the MAF pipe and sensor placement on the "no cutting" version seem to be a much better location/design and should be easier to tune without issues.
Old 04-15-2016, 04:17 PM   #334
ft86me
ft86me's Avatar
Drives: 2013 FRS
JDL turbo kit thread
I would prefer not to replace my crash beam or modify it for the original version of the JDL turbo kit. My Velox splitter rods are mounted to the front face of the stock crash beam and it would be tedious to adapt it to a tubular crash bar. Also I've heard from multiple professional tuners and kit owners (in the owners thread) that the MAF placement isn't ideal and can make it very difficult to tune. The MAF pipe and sensor placement on the "no cutting" version seems to be in a much better location and should be easier to tune without issues.
Just a little time and creativity for your splitter rods. I actually spoke to velox yesterday about doing that if I went with a splitter and they said they mounted rods to a drift armor bar and it came out really well. As for the tuning aspect , @DeliciousTuning and [MENTION=11779]Zach[/MENTION @DeliciousTuning are professional tuners with some extensive tuning history and have been able to tune my kit with no issues. Hell, my tune was a flash and go with no dyno tuning on my part and it was ready to go upon flashing. Either way, both are great kits with amazing quality , but just wanted to clarify that the short tube kit can be tuned with no problems for those of you that are still interested.
Old 04-15-2016, 05:00 PM   #335
JDLAutoDesign
Drives: 13 FRS
The original kits with the BOV mounted a few inches from the MAF made things difficult from what we heard from select tuners. We changed that and anyone that had one was given the option to be upgraded to the new style pipe. As for the current location take a look at the Greddy, SBD, Full-Race kits and tell me the upper pipes and MAF's aren't damn near identical to ours. Even the MAP kit has the BOV just as close to the MAF as our original layout. I'd love to hear what makes ours so different. We do a lot of installs here at the shop and never have issues.
Either way it shouldn't be an issue, especially with the long route piping kit.
Old 04-15-2016, 05:06 PM   #336
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Ian,
FT86me is the car I mentioned to you on Facebook earlier
Sincerely,
Zach
MAPerformance turbo kit thread! MAPerformance Forced Induction 277 02-14-2023 02:49 PM
AVO turbo kit for BRZ - initial build thread AVOturboworld Forced Induction 3109 12-01-2019 03:55 PM
All TURBO kits compilation thread subatoy Forced Induction 112 04-10-2015 09:14 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 06:27 PM
Synack Turbo Drift/Drag/Road Thread Synack Tracking / Autocross / HPDE / Drifting 5 09-20-2012 01:20 AM
