Old 04-14-2016, 06:02 PM   #295
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Originally Posted by headlikeahole View Post
This thread is getting really frustrating. No one is getting real questions/input because its impossible to sort through everyone who cant read.
This tune is specifically for OFH, 91 and 93 octane tunes and no other headers!!
EL = No
Other UEL = NO
E85 = No change
All of this is plainly obvious if you READ the OP
The OFH is pretty damn similar to a lot of other UEL headers, so it's not out of the question to think this tune will work ok with some of them. It's obvious Shiv was just covering his ass with those disclaimers. I would do the same thing in his position.
smg1138 is offline   Reply With Quote
The Following 3 Users Say Thank You to smg1138 For This Useful Post:
drew_kar (04-14-2016), Gutterboy (04-15-2016), mmmcambelsoup (04-14-2016)
Old 04-14-2016, 06:07 PM   #296
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by Ixz View Post
Flashed on my car today did around 200 km on it so far so good, sound a bit more aggresively, having an UEL Tomei header and no other exhaust mods.
Here is data logs of some highway cruising/traffics jerking lol and street driving:
http://www.datazap.me/u/ixz/stage-2-...i?log=0&data=1
Could do some runs this night if needed.
Do you have an intake? At some points you get super rich that may just be overrun so it's ok , if you have an intake you should try scaling the maf.
But I don't see many issues with knock like what shiv said to look out for, it looks safe to me
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Old 04-14-2016, 06:08 PM   #297
FRSBRZGT86FAN
Only on other uels, some people are asking stupid questions like
"WILL THIS WORK ON A STOCK HEADER CAR durrrrrrr"
Old 04-14-2016, 06:25 PM   #298
steve99
Drives: FT86
Originally Posted by oldgunfan View Post
Anyone know if I should use my MAF scale I had tuned for the old stage2 Uel tune. I'm gessing no but just thought I would ask.
should be fine as you not changing intake or maf, maf scaling is to calibrate the maf sensor.
oldgunfan (04-14-2016)
Old 04-14-2016, 06:29 PM   #299
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Going to flash this weekend and see how it goes...Using Tsudo UEL.
B-R-Z is offline   Reply With Quote
The Following User Says Thank You to B-R-Z For This Useful Post:
Old 04-14-2016, 06:47 PM   #300
Ixz
Drives: 2014 WRB Subaru BRZ
K&N drop in filter. Going to do 3 gear pull and see how it does. Thanks for reply and saying that everything safe so far.
Ixz is offline   Reply With Quote
The Following 2 Users Say Thank You to Ixz For This Useful Post:
D_Thissen (04-14-2016), FRSBRZGT86FAN (04-14-2016)
Old 04-14-2016, 06:59 PM   #301
mmmcambelsoup
mmmcambelsoup's Avatar
Drives: FR-S 10 series
@B-R-Z running tsudo uel catless with invidia catless fp, mp, n1. Running fine 100miles in. No logs to post unfortunately. But def feels peppier on lower end.
IG: @Lucky_FatPat
10 series // TRD x Turbo Build:
http://www.ft86club.com/forums/showthread.php?t=79474
mmmcambelsoup is offline   Reply With Quote
The Following User Says Thank You to mmmcambelsoup For This Useful Post:
B-R-Z (04-14-2016)
Old 04-14-2016, 07:09 PM   #302
FRSBRZGT86FAN
Hey Steve, How come when I try to edit the new tunes in romraider I get an error that stuff is disabled was that done on purpose? I used the provided definitions too
Old 04-14-2016, 07:10 PM   #303
FRSBRZGT86FAN
It looks perfectly safe then I wasn't looking at the throttle and RPM but looking back at it now, it's definitely overrun so it's safe. Make sure you just watch for knock and IAMs and such, so I guess that shows everyone that Tomei is confirmed to work fine so that means gruppe-s works fine as well @jawn I believe this is good for you lol
Old 04-14-2016, 07:44 PM   #304
steve99
Drives: FT86
do the tables look ok ? values and axis x and y ?
you might have to up the user level in romraider
if your getting the error from romraider when you open rom that romraider has disabled editing to table xxxxxxx then this is bad it means rom has tables that dont match, it possible if its B01C rom that its got flex patches in it what is exact error message
Old 04-14-2016, 07:45 PM   #305
FRSBRZGT86FAN
Yea I gave up on editing it way too many errors, also the tables would show up completely wrong like, everything would start at 32 then go negative then go postive
Old 04-14-2016, 07:49 PM   #306
steve99
Drives: FT86
eeek that mismatched rom and def, definitly do not edit.
so you sure your using the new rom and new definition ?, make sure you delete any other definition pointers to other def in romraider, make sure their is only one definition in romraider.
Old 04-14-2016, 07:50 PM   #307
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
That log only goes up to like 2800 RPM. I'll have to do some further logging to verify.
jawn is offline   Reply With Quote
The Following User Says Thank You to jawn For This Useful Post:
Old 04-14-2016, 07:52 PM   #308
FRSBRZGT86FAN
OK I fixed it, so I removed/uninstalled romraider then ONLY added the definitions for the new OFH tunes and did not add the ones for the normal ots stage 2 tunes and its fine now and perfectly editable.
Just how noticeable is OFT+OFH and stage 2 tune? BBYZILA Software Tuning 58 03-20-2018 11:56 AM
OFT 2.0 Stage 1 93 Tune MurderRider Software Tuning 57 03-21-2016 12:30 AM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 08:15 PM
FA20club.com Turnaround Times On Modified Tune Files FR-S Matt Software Tuning 103 11-13-2013 01:48 PM
So whate does stage 3 tune do? I already have 2 Frsexxxy Engine, Exhaust, Transmission 17 05-14-2013 06:30 AM
