Old 06-16-2012, 12:32 PM   #57
FT_Monk
Drives: Over the hill WRX
OP should keep the Z until a more powerful BRZ/FRS versions are here. Lazy Nissan mounted windshield washer bottle right on the front bumper does not help handling. Some weight reduction in the front will helps.
FT_Monk is offline   Reply With Quote
The Following User Says Thank You to FT_Monk For This Useful Post:
Z.Tune (06-17-2012)
Old 06-16-2012, 02:30 PM   #58
fatoni
Originally Posted by switchlanez View Post
Simple. When the car feels planted, the center of gravity is low. When the center of gravity is low, the car feels very close to the ground. Distance between car and ground = ground clearance. Lastly, I said "cruising" not "hovering." Two completely different meanings. Need any other clarifications?
yeah because that still doesnt make any sense. whether you are cruising or hovering, feeling like you are fractions off the ground is the exact oppsite of being planted. also i dont see any relation to feeling planted and feeling low. this car is never going to feel more planted than say an evo and yet its cog is much higer. making the car lower to the ground will lower cog but that doesnt mean that the opposite is true. my miata has more ground clearance and a lower cog. i think feeling close to the ground has more to do with how the the interior is designed than any other technical aspect
Old 06-16-2012, 03:05 PM   #59
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
I sold my c63 and got this as a track car and i have no regrets i can assure you, you will not regret it one bit.
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
The Following User Says Thank You to track_warrior For This Useful Post:
Z.Tune (06-17-2012)
Old 06-16-2012, 03:16 PM   #60
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Have you driven one of the twins?
Old 06-16-2012, 04:26 PM   #61
fatoni
Originally Posted by switchlanez;[URL="tel:261726"
261726[/URL]]Have you driven one of the twins?
just the frs but you dont need to drive anything to know that feeling planted and feeling like like you are fractions of an inch off the ground are not the same thing.
Old 06-16-2012, 06:56 PM   #62
switchlanez
I never said they were the same thing. I said they're related. Say you're riding a golf cart and then a go-kart. Which one would feel more planted and what is the main contributing factor that makes it so?
Old 06-16-2012, 07:01 PM   #63
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Originally Posted by eriktherod View Post
Tbomb, I'm going to assume you don't drive a FR-S/BRZ. This thing GOES even at low RPM, it's hardly like my Si was (that required 4-5k rpm to get moving). I still have the power to gain a good bit of speed in 6th gear at 2-3k rpm in the FR-S. So no, you don't have to "rev the guts out of it" to get it moving.
Honestly, this thing feels like it has the power of V6 at low rpm, it's quite fascinating really. Maybe not Z-style V6, but definitely doesn't feel like you need to spin it up good to gain momentum.
It's funny since your the first person that has ever said this. I also have a hard time believing this unless you are used to a 2.2L V6 from 1989 or something.
SUB-FT86 is offline   Reply With Quote
Old 06-16-2012, 07:45 PM   #64
fatoni
Originally Posted by switchlanez;[URL="tel:261950"
261950[/URL]]I never said they were the same thing. I said they're related. Say you're riding a golf cart and then a go-kart. Which one would feel more planted and what is the main contributing factor that makes it so?
not only are they not the same thing, they are the exact opposite. im going to say that a go kart feels more planted. on account of the fact that there isnt suspension, its hundreds of pounds less, designed to be sporting and has way grippier tires.
the miata has a lowe cog. the c4 corvette too. are those cars more planted or floating or whatever youre trying to say?
Old 06-16-2012, 09:01 PM   #65
switchlanez
pfft Really. That's not even *one* factor; that's a list that collectively don't compare to the one factor. I see I'm trying to shoot arrows through a brick wall here. I give up on you.
Old 06-16-2012, 09:41 PM   #66
fatoni
okay maybe its a communication thing. azz=back, planted=not moving. do we agree? back not moving = understeer. so if you think the frs has more understeer than the 370z. i think youre wrong. if you dont, i dont understand what you are trying to say. the 370z is a much more stable car because it is designed to be driven at much higher speeds. i dont think anything mentioned is beyond reason
Old 06-17-2012, 12:15 AM   #67
eriktherod
Drives: 2013 Scion FR-S Firestorm Red MT
Oh, hm well.. I'm not used to a sports car V6 but.. compared to the other V6's I've driven I feel like it's similar to the 'lazy' power at lower rpms compared to many 4cyls.
eriktherod is offline   Reply With Quote
Old 06-17-2012, 12:32 AM   #68
switchlanez
I used to drive a G35 and its V6 has plenty of pickup on tap from a standstill. Also used to have a Celica GT-S, Mk2 MR2 (2.2L), and Mk3 MR2. The BRZ feels like it has a bit more punch (its hp/tq figures are higher) at low RPMs than those inline-fours but you still feel a gradual increase in pull as the revs build.
Old 06-17-2012, 01:15 AM   #69
Juan@aePerformance
Juan@aePerformance's Avatar
Drives: Raven Scion FRS
Originally Posted by shadoquad View Post
The fuel starve issue is the only one that hasn't been solved, and it can be avoided if you keep a full tank before tracking.
The oil and brake cooling issues can be fixed for less than 1000 dollars.
I'm not sure but i think we added a secondary tank to our 370 and we hardly ever get fuel starvation issues anymore. Only thing thats sucks is that our fuel gauge is a little off now.
Juan@aePerformance is offline   Reply With Quote
The Following User Says Thank You to Juan@aePerformance For This Useful Post:
shadoquad (06-17-2012)
Old 06-17-2012, 01:33 AM   #70
Liquidsnake
Drives: "I drives like a Porsche"
I don't know man my Z always scared me on turns. A few people who drove my old car told me they didn't trust it. I kind of agreed with them. Straight line no problem. 0-120 in a straight line put a smile on my face. With the FRS I trust that car with my life on turns. It's just my experience and opinion with both cars. Z was a little sloppy and it didnt feel tight to me.
Liquidsnake is offline   Reply With Quote
FR-S vs. 370z, end all be all of discussions OldSkoolToys FR-S / BRZ vs.... 1491 09-25-2012 06:58 PM
Did anyone trade in the TC for FRS/BRZ csaba Scion FR-S / Toyota 86 GT86 General Forum 14 06-05-2012 11:47 PM
Trade in RX8 for FR-S?? ng01 Scion FR-S / Toyota 86 GT86 General Forum 72 05-10-2012 01:00 PM
Autocar: BRZ vs. MX-5 vs. 370Z Levi BRZ First-Gen (2012+) — General Topics 183 04-12-2012 05:30 PM
FT 86 & 370Z similarities blur FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 11 10-05-2010 12:39 AM
