Old 12-06-2013, 05:42 PM   #1
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
Pro-Tip: rejuvenate your wiper blades
Take a bit of scotch-brite and rub the blade ends lengthwise with a bit of pressure. A few back and forths will do. It'll extend the life of your blades a good bit. I'm OCD about windshield cleanliness.
Old 12-06-2013, 08:23 PM   #2
w.k.s.
Drives: 14 SWP BRZ, 07 SWP STI, 05 LGT
Very clever. I will try this.
w.k.s. is offline   Reply With Quote
Old 12-07-2013, 12:36 AM   #3
6speed_Sam
Thumper
6speed_Sam's Avatar
Drives: 2013 FRS
[/img]
This is a great trick. I experimented with this years ago and found it to take the streakiness(from grime) away from old blades. Works great! Everybody should do this every time they wash their cars.
Car is gone - parts for sale
6speed_Sam is offline   Reply With Quote
Old 12-07-2013, 09:43 AM   #4
Suberman
Drives: Subaru BRZ Sport Tech Satin White
You'd be surprised at the gunk that accumulates on the sides of the blade right down at the edge. This tip will address this issue. Any debris or gunk on the side of the blade right near the edge will create an unswept water line as the edge lifts at that point. That can be really annoying. If enough gunk accumulates the blade will begin to leave a band of water where the gunk lifts the blade.
Eventually UV radiation and heat kills the blade.
Depending on your local climate fitting new blades every two years may be the only solution.
Up here at 1,000 meters and with our tough winters pitting the windshields from road sanding debris, wiper blades wear out in less than 24 months.
Suberman is offline   Reply With Quote
Old 12-07-2013, 12:19 PM   #5
Pizzman
Crap another obsession.
Drives: 2013 BRZ Limited
Yeah I give them a scrub when I was my car. Phoenix heat and sun kills wiper blades. We only use them like 2 time a year. Costco has the best deal on the best blades.
Pizzman is offline   Reply With Quote
Old 01-04-2014, 12:31 PM   #6
Respect BRZ
Old Mechanic
Drives: 2013 Limited BRZ
Originally Posted by Pizzman View Post
Yeah I give them a scrub when I wash my car. Phoenix heat and sun kills wiper blades. We only use them like 2 time a year. Costco has the best deal on the best blades.
Amen to costco blades, and they go on sale 2 for 1 every once in a while. thats when i change mine. they are goodyear beam blades. and they work great...
Respect BRZ is offline   Reply With Quote
Old 01-05-2014, 01:46 AM   #7
HapaHaole
Drives: Grocery cart
Don't they sell OE wiper inserts for $3 each? Costco is good but it costs around $1X each.
HapaHaole is offline   Reply With Quote
Old 03-16-2014, 11:57 PM   #8
Respect BRZ
Old Mechanic
Nope 8.95 each. That's way better than 30+ for rain-x blades at the auto parts stores.
Sent from my DROID RAZR using Tapatalk
Old 03-17-2014, 02:39 AM   #9
Yep, and a little rubbing with alcohol will take most of the other stuff off ....
Old 05-01-2014, 09:02 PM   #10
Chri5
Hey all, I just got a set of new wiper inserts from Toyota and wanted to let you know they come with the metal stabilizers as well. Here are the part numbers and a pic for reference.
(Left side part# SU00304213)
(Right side part# SU00304214)
Chri5 is offline   Reply With Quote
Old 03-24-2016, 06:14 PM   #11
Tien0227
Tien0227's Avatar
Drives: FRS 10 Series MT
Thanks for the info!
Sent from my Samsung Galaxy Note 3
Tien0227 is offline   Reply With Quote
Old 04-06-2016, 02:42 AM   #12
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Important note as well, getting the inserts may be the best bang for the buck option vs completely new wipers, the set is only $22 off ebay from a toyota parts department which is quite good.
Old 04-13-2016, 10:36 AM   #13
WNDSRFR
Drives: FR-S,GTI
Yeah I just replaced my wiper blade "rubbers" with the Toyota OEM blades. They cost 10 bucks apiece but I wanted to keep the OEM "wiper covers". It took awhile to figure out how to install them but it always does.
Old 04-13-2016, 04:10 PM   #14
FRSBRZGT86FAN
Just so you know those are generic beam wipers, alot of aftermarket ones have that look as well.
Windshield Wiper Marks StOpNG0x Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 13 05-09-2013 07:27 AM
Windesheild wiper blades dem00n Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 4 04-06-2013 07:32 PM
Wiper Blades FRSFirestorm Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 01-10-2013 10:11 PM
Wiper axss Scion FR-S / Toyota 86 GT86 General Forum 8 12-22-2012 08:10 PM
