Old 04-11-2016, 05:17 PM   #2255
renfield90
The Stig's German cousin
Originally Posted by DocWalt View Post
That all makes sense. I've never had the IAM drop on this tune, but granted I don't make it a habit to sit on the limiter on track or on the street, and I only just started seriously autocrossing it. I'll keep an eye on it.
That still doesn't explain the throttle closing. I'm thinking I should log the fuel pressure... or see if it goes away running more fuel in the tank.
If you saw throttle closing, try again without the pedal dance. AFAIK nobody has confirmed that this is an actual feature, a debug mode, or a safe mode...there may be other effects that aren't publicly documented.
But yeah, ruling out knock would be my first step. My tune has been rock solid on the street but I saw very minor IAM drop at an autocross, and it wasn't even that hot out. Still need to verify it can handle 95-100 degree temps without changes, or maybe I'll add some 100 octane on race day.
The Following User Says Thank You to renfield90 For This Useful Post:
DocWalt (04-11-2016)
Old 04-11-2016, 05:20 PM   #2256
e1_griego
e1_griego's Avatar
Drives: Many
No idea. I bought the strano bar and then ordered the endlinks separately.
These posts pointed me in the right direction:
http://www.ft86club.com/forums/showt...02#post1621802
http://www.ft86club.com/forums/showthread.php?t=76075
e1_griego is offline   Reply With Quote
The Following 2 Users Say Thank You to e1_griego For This Useful Post:
smg1138 (04-11-2016), strat61caster (04-11-2016)
Old 04-11-2016, 09:26 PM   #2257
Kostamojen
Originally Posted by smg1138 View Post
What coilovers are you using? Right now I'm using the stock bar and endlinks on my Tarmac 2's with no issues. I think the KW strut works better with stock endlinks than some other designs, but not totally sure.
Bilstein. The Endlink mounts are in a much different location so ya, had to use adjustables. I have zero clunks as well.
Old 04-11-2016, 09:35 PM   #2258
48Spoons
Drives: Ultramarine FR-S
Do you get any clunking from them? I had some last year but could never get rid of the clunking, so went back to the stock setup over the winter.
I have the whitelines and they clunked a lot when I first got them. Issue seems to be that you really need to tighten the crap out of the adjustable bit of them. Once i did that they have been totally fine.
48Spoons is offline   Reply With Quote
Old 04-12-2016, 11:36 AM   #2259
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Where did you order those shorter Whiteline endlinks from? I can't seem to find them in stock anywhere.
smg1138 is offline   Reply With Quote
Old 04-12-2016, 12:42 PM   #2260
e1_griego
e1_griego's Avatar
Drives: Many
I got mine from Summit.
The Following User Says Thank You to e1_griego For This Useful Post:
smg1138 (04-12-2016)
Old 04-13-2016, 12:00 PM   #2261
smg1138
smg1138's Avatar
Just a heads up for anyone else who might be looking for those shorter Whiteline endlinks. It looks like they're out of stock everywhere. If you order some, it's going to be about a 2 month wait.
Old 04-13-2016, 12:30 PM   #2262
e1_griego
e1_griego's Avatar
Drives: Many
Can build your own if you want to go that route:
http://forums.vwvortex.com/showthrea...-Sway-Endlinks
If the stock bar used m10-sized things then there are a few other universal options, but m12 is more limited.
Old 04-13-2016, 12:48 PM   #2263
Silverspeed
Drives: 2014 FR-S
Those build-your-own links look like the Hotchkis ones I'm using. I like them because of the smaller heads on the joints. Lot's more clearance. The Whiteline ones are beefy for sure. Maybe if I was running a much larger bar I'd be concerned that the Hotchkis links weren't strong enough... They have done the job for 2 years now.
Silverspeed is offline   Reply With Quote
Old 04-14-2016, 10:28 AM   #2264
smg1138
smg1138's Avatar
About how much rear toe are most people running in STX? Right now I'm at zero toe front and back, but feel like adding some rear toe could help with stability. Would 0.15 each side be too much?
Old 04-14-2016, 10:54 AM   #2265
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I'm at 1/8" total toe in. Seems fine, but I don't have enough experience with other RWD cars or different alignment settings to know what's best in this case.
The Following 2 Users Say Thank You to DocWalt For This Useful Post:
e1_griego (04-14-2016), smg1138 (04-14-2016)
Old 04-14-2016, 11:13 AM   #2266
cjd
cjd's Avatar
Drives: 2017 BRZ
I'm considering a little, but am running zero. I haven't found stability to be an obvious issue. Every setup is different in other ways too so different things may work for each of us.
Old 04-14-2016, 03:00 PM   #2267
Silverspeed
Drives: 2014 FR-S
My specs are shown at the link below. Much like last season's alignment so it should be good.
http://www.ft86club.com/forums/showt...=101262&page=3
Last edited by Silverspeed; 04-14-2016 at 03:03 PM. Reason: I'm dumb and forgot to post the reason for posting...
The Following User Says Thank You to Silverspeed For This Useful Post:
Old 04-16-2016, 09:29 PM   #2268
Blue Gt
Blue Gt's Avatar
Lightbulb The Blue GT lost 11 lbs today!
We installed a new battery from NAPA today, the original was weak after 4 years. I put in the spec battery for a 2013 Honda FIT, a 151R with 410 CCA. The new battery is just 19 lbs. net weight compared to the stock battery at 30 lbs and the terminal orientation is correct for the Twins.
I modified the existing hold down with two sections of 3/8" OD Aluminum rod just over 2" long. I drilled two 5/16" dia. holes in the front of the bracket and then drilled some 3/16" holes in the aluminum pegs. I used some self tapping screws to hold everything nice n tight. Total project cost was under $100.00.
New juice and less filling! !
Blue Gt is offline   Reply With Quote
The Following 3 Users Say Thank You to Blue Gt For This Useful Post:
DocWalt (04-16-2016), SPCorBUST (04-16-2016), strat61caster (04-16-2016)
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
